Ok so going through this forum like 12 pages worth, and I didn't find what I was looking for. If there is please send the link. No need to repeat if it's been said before. But on to the main questions
1. Is upgrading the stock throttle body worth it? If it is, do I go with anTB and spacer or just the TB? I could say with the research I've done so far is that I've seen it's basically 50/50. To be completely honest my main goal for my V6 'stang is efficiency. If power comes with what I plan to do then awesome if not really oh well. I plan on upgrading the coils and the injectors so the engine itself is working at a good street level. I don't race but Turing heads and ripping through gears is fun. It's a DD but it's a total of maybe 5 miles a week at the very worst.
2. What is the general thought on the what short throw shifters work well on the 3.7? Barton? Or something else. Like I said earlier efficiency is the name of the goal. Super effective and subtle changes to make my car, my dream.
If it helps already installed on the car:
Roush CAI
Roush Axle back
Ford Racing off-road X pipe
19" premium wheels
Roush Lowering Springs
May I give you a piece of advice: if your goal is to increase efficiency none of the changes you are planning are going to do that for you.
A larger throttle body will allow more air to enter the engine and can give you a HP bump but you will only see that at WOT in the upper rpm range. Anything below WOT and the throttle is regulating the air flow to provide a certain level of power, a bigger throttle body just means the throttle will be closed more for a given speed.
Throttle body spacers are mostly for looks on a dry intake, any power or efficiency improvement is going to be so small that you won't notice it.
You would have to increase the air flow into the engine dramatically (cams, forced induction,etc) before upgrading injectors would be needed. Putting a larger injector on an otherwise stock engine is just going to make it harder for the ECU to control the injector at low duty cycles where you spend most of your time. If you injectors are acting up stock replacements would be the way to go.
Coils are going to be the same situation. If you haven't done some extensive mods to the engine you will not realize any benefit from aftermarket coils. Again if the the coils are acting up stock replacements would be the way to go.
A larger throttle body will not give any gain in HP over stock without other modifications. You will simply allow more air in quicker, essentially allowing you to experience wide open throttle (WOT)quicker.
To gain anything with the intake side of an engine you must first make sure the exhaust is in check. The heads are where the gains come from. With restrictive heads you will only free up a small amount of power with injectors, intakes, plenum, and manifold. An engine's heads are where the power is at.
One easy way to increase efficiency is to run a little higher air pressure in the tires. Still within the safe range the tire is rated at of course. With too much though the center of tires will wear out quicker. This reduces rolling resistance. Lighter rims help as well will less rotating mass.
Eh really it's just an itch I want to scratch. I figured that those would help. But I do also intend to cruise it around town and to meets and such. I'm really looking for advice on what to do since I got the car with slight mods already I just wanted to put some things that I felt like get over looked. But thank you I'll check those shifters out
I have a bigger TB on my 4.0. If you buy a bigger one, you have to get a tune. The engine has to be programmed for the larger intake. You case I would stick with the stock. Also tuning the larger TB is a pain.
An idea for efficiency would be to buy a single piece aluminum drive shaft. The single piece helps with putting power to the rear wheels instead of the factory 2 piece drive shaft. It also weighs 45lbs lighter then the factory. Less weight and better power delivery.
Before I forget; a tune is really only adjusting the timing. There is a small amount of air / fuel mixture adjusted, but that is in regard to the timing. Horsepower is gained through a tune due to the timing adjustments. When you add other bolt on parts you can tune to add more fuel to the added flow of air.
This is still done in regard to the heads. Timing is all about piston stroke, combustion, and valve timing.
If you change the cams you can now adjust the timing and air / fuel ratio to meet the needs of the valves being open for a longer duration.
Lol well I've got the same weight issue so... I'm ****ed í ½í¸‚ But I do see the lighter drive shaft as helping. I truly appreciate the help.
Related Threads
Mustang Evolution Forum
2.1M posts
50.8K members
Since 2003
