Noise from Differential? - Mustang Evolution
Old 08-15-2017, 03:53 PM   #1
Hi guys,
Hope you can help me out. I live in Denmark and "newer" mustangs like my 06 is not that common here, so i figured i could try and ask you guys.
I bought a 2006 4.0 V6 auto a couple of weeks ago. It has about 124.000 miles on it, i don't know the service history of it.
It makes a really weird sound from the rear and i can force the sound doing 90-100 miles an hour. The sound is like when your tire touches the fenders, but at the height of the car, that's deffenetly not the issue
Today we lifted it at tried driving in free air (that was fun...) and the mechanic said it sounds like its comming from the rear differential. But the sound when we tested was more like a metallic chirping sound instead of the usual "rubber-meets-fender" sound.
Anyway, the oil is completly black in the diff. and should be changed no matter what. At the same time we will change the auto tranny oil.
Do you have any suggestions on what this sound could be? Maybe there is a known issue with the v6's you know better than me. It seems to follow the gas, meaning when i put it in neutral it will stop (mostly).
As mentioned it can be forced doing highway speeds but can also appear when doing 5-10 miles per hour randomly.
And at last, i found a local who is a distributor of Royal Purple, should i get that for the tranny and diff? How many liters do i need for the tranny and the diff? And are there any gasket and filters that needs replacement?
LowDog is offline   Reply With Quote
Old 08-17-2017, 08:20 PM   #2
It does seem pretty likely it's a bad rear dif, bad oil or low on oil. When you get the oil changed and find out its low you maybe able to get away with refilling it back to full to stop the noise.fresh fluid may do the trick if it's just a matter of old fluid causing higher friction. If there is a lot of metal shavings in the oil its likely the dif is near the end of its life. It likely just sounds different in the air since there is no load on the tires allowing the gears to chatter.Fast changes in load at low speed could explain why it noisy at low speeds at time. A mechanic could easily tell with it on a lift running around 50mph where the noise is coming from. It should get louder at higher speeds.
Royal purple trans fluid and dif oil is a premium fluid, but with a premium price tag. Any good synthetic will do though. They don't break down under the high temps in the transmission and rear end can see.
Mhenry13 is offline   Reply With Quote
Old 08-17-2017, 08:24 PM   #3
8.8 swap time! 👍
Pick your poison.
Old 08-18-2017, 01:05 AM   #4
Thanks a lot for your advise. Do you by any chance know how much oil that gois into the diff and gearbox? And also where do i buy a new gasket, i can see there are different sizes.
Old 08-18-2017, 06:30 AM   #5
The diff takes 2 quarts and the auto trans takes around 12 quarts. If you change the fluid by draining it from the pan you will only be able to drain near half of that. Since these don't have a dipstick to check the auto trans fluid it's usually best to measure the fluid drained from the pan so you know near what amount to start with to put back in. From there you can top it off it it was low. Only way to get all the trans fluid changed is to get it flushed. When you change the trans fluid you will want to change the filter as well. The diff will have a gasket, but black oil resistant rtv gasket maker works just fine too.
Old 08-18-2017, 06:33 AM   #6
As far as where to buy the gasket if you are looking to by it online rockauto is a good one. Just make sure you get the 7.5 in rear end gasket.
Differential? Vinny 2015+ Mustang Ecoboost (and V6) 0 08-26-2015 09:25 PM
Squeeky suspension noise and Differential Leak... Edd2016 2011-2014 Mustang GT 10 07-21-2015 06:17 PM
V6 differential tsteevs_foxbody 1996-2004 Mustang GT 3 02-05-2015 09:51 AM
Drove at 124mph... road noise? Or Differential / driveshaft issue? dubaighost 2011-2014 V6 Mustang 11 09-20-2014 01:07 PM
Clicking Noise kind of Squeeky Noise... braumab 2005-2010 Mustang GT 23 06-30-2008 12:24 AM
04:56 AM
