Problems with alignment after lowering? - Mustang Evolution
Old 08-26-2017, 07:11 PM   #1
tjpfab's Avatar
anyone having problems with a good alignment after lowering? I lowered my 2005 vert about 1.5 inches and haven't been able to get a good alignment since and have gone to a couple places.
Anyone think an adjustable panhard bar might help bring it all into alignment?
other ideas?
tjpfab is offline   Reply With Quote
Old 08-26-2017, 07:13 PM   #2
Revvv's Avatar
Camber castor plates are likely needed.
Old 08-26-2017, 07:23 PM   #3
tjpfab's Avatar
I was thinking that too but they didn't think so. They think they got it close but it still tracks to the left so I'm kind of at a loss. Read and heard about the rear axle going off center when lowering which could affect alignment so I figured bringing it back to center might help.
Old 08-26-2017, 07:24 PM   #4
Revvv's Avatar
You may need a set of adjustable rear control arms.
Old 08-26-2017, 07:48 PM   #5
Adjustable panhard bar.
Pick your poison.
Old 08-26-2017, 07:51 PM   #6
Revvv's Avatar
Pick your poison.
I'm glad you corrected that. Lol. It didn't register thay I said LCA until you said otherwise.
Recon to the rescue.
Old 08-26-2017, 07:55 PM   #7
It'll take some time to get the rear centered so just be aware of that. Took me awhile to get mine right with a 1.75in drop in the rear. Installed my lower control arms as well, but didn't get relocation brackets like I should've.
Ironically I just noticed today my rear end is off center again. Must've settled, not a problem though.
Pick your poison.
Old 08-26-2017, 07:57 PM   #8
Revvv's Avatar
It's just a few turns of a wrench and it is all back to center.
Old 08-26-2017, 08:16 PM   #9
Yes, but raising it up, making adjustments, then setting it back down, check, and repeat. Just very tedious. Worth noting my Roush wasn't out of alignment suspension wise, excluding the off center rear end. Cast, toe, and camber all in the green. Much to our surprise.
Pick your poison.
Old 08-26-2017, 08:30 PM   #10
Revvv's Avatar
Most suspension work is tedious, finese work. I normally enjoy suspension tuning. It is almost relaxing with the right tools.
Old 08-26-2017, 10:33 PM   #11
tjpfab's Avatar
Thanks. Appreciate the info. Kind of like you Recon, all my numbers were within range but the problem remained. Adjustable panhard bar is in my future for sure!
Thanks again...
Old 08-27-2017, 12:44 PM   #12
Gil05GT's Avatar
Region: Oregon
Adjustable panhard bar. Mine was out quite a bit, with the adjustable panhard bar came right in.
'05 Mustang GT, KB Supercharger, (10 PSI), detuned to 400 RWHP for longevity, PA Street Fighter Transmission & Torque Converter, BMR LCA & Adj Upper, BMR Adj Panhard Rod, BMR Strut Tower Brace, etc, etc.
Gil05GT is offline   Reply With Quote
Old 08-27-2017, 01:06 PM   #13
Hellish Horse's Avatar
I had that issue on my 08 after lowering. They sell after market Camber Bolts on Ebay for about $10.00. You use one in the bottom hole on the bottom end of the struts (near your brakes). That will fix your problem. they're kind of oval shaped instead of round like the stock ones and allow you the extra adjustment needed from lowering.
Hellish Horse is offline   Reply With Quote
Old 08-27-2017, 03:39 PM   #14
You lower the car you HAVE to get an adjustable panhard bar or the rear will be permanently cocked to one side and that'll bind up the control arms too. Also get CC plates. Then you'll be able to get the alignment good.
Lowering springs and alignment Agraulis 2011-2014 V6 Mustang 14 07-14-2017 02:47 PM
When to get alignment after lowering Fax22 2011-2014 Mustang GT 9 07-16-2015 11:16 PM
13 v6 alignment problems supersixx13 2011-2014 V6 Mustang 12 02-13-2014 07:05 AM
Alignment after lowering robin_gt 1996-2004 Mustang GT 10 12-15-2013 11:33 AM
Alignment problems. Bosaliniee 1996-2004 Mustang GT 9 04-16-2012 08:29 PM
01:31 AM
