Please HELP... At WOT feels almost like it’s in neutral. Just replaced clogged cats - Mustang Evolution
Old 01-29-2018, 04:51 AM   #1
2010 4.0 auto.
Please someone help. Let me start by saying I’m a die hard Ford guy. I bought this car for my little girl for her 16th bday about a year ago at the Ford dealership that I had been the F&I director for years. It only had 55k miles on it now has 61k and is immaculate . It all started a few months back with a slight rattling sound at start up and idle. I didn’t think it was a big deal at that point but it progressively got worse. I finally got some extra time and decided to try and locate the cause. I got under the car and tapped the pipe with a rubber mallet and found it was coming from the cats. I knew that they were covered for 8 years/80,000 miles and since the in service date was in early 2010 it was covered by Ford. Just a few days before taking the car in,my daughter said when she pressed the gas pedal and it got to around 3,000 Rpms it wouldn’t go. I figured the cats had completely clogged at that point and was restricting the engine from breathing. I took the car to a local dealership and they replaced the cats under the emissions warranty . The service advisor called and said it also needed a evap solenoid and that was letting it dump excess fuel in the exhaust and was probably what caused the cats to clog and that the repair would be $198. I told the guy I would pick the up and replace the part myself, I’m mechanically inclined ,I service my our diesels and have maintained and made all repairs to all our vehicles. I have the Autoenginuity scan tool with the Ford enhancement package that I normally use to diagnose and repair the vehicles but I’m at a loss , got frustrated and started and just started replacing parts and needless to say it’s getting costly. I started with the basics and replaced the plugs,wires,coil pack,both solenoids on the evap system,TPS,MAF and also the rear O2 sensor on the passenger side because the other one wasn’t completely seated. I ended up have to clean the threads so I went ahead and replaced that O2. If you slightly press the pedal the car will shift thru the gears as it should. The problem is if you get on it or go wot trying to go into passing gear,it revs and feels almost like it’s in neutral. Please help
2010 4.0 is offline   Reply With Quote
Old 01-29-2018, 08:12 AM   #2
I take it this car is an automatic? Have you checked the fluid level in the transmission?
Old 01-29-2018, 09:52 AM   #3
Check the transmission fluid level as Guard suggested.
I don't know if your scan tool has the capability to scan for transmission codes, but your description of the symptoms certainly points toward a failure of some sort.
Rather than continuing to throw parts at it, I recommend paying to have the car professionally diagnosed by a competent shop.
Old 01-30-2018, 03:44 AM   #4
David Young's Avatar
I agree with the others. Its your transmission. Torque converter or shift solenoid. Maybe.....
David Young is offline   Reply With Quote
Old 01-30-2018, 05:59 AM   #5
If the engine won't rev past 3 grand it sounds like you have a missfire somehow. Especially if the exhaust is no longer clogged. Does it do this when you floor it or does it rev all the way, but feels like it's in neutral?
If it never goes past 3 grand you could have bad injectors dumping too much fuel which would have caused it to burn the cats out . If you check the fuel trims it may give you some direction on this. Injectors that be drop tested to make sure they are all giving a even amount of fuel. Could also be excessive fuel pressure issue. Are there any codes?
Sent from my SM-J327P using Mustang Evolution mobile app
Mhenry13 is offline   Reply With Quote
Old 01-30-2018, 06:07 AM   #6
https://youtu.be/oRX2V6_a3dc
No Power at Wot, Revs fine in Neutral NewHillBilly 1979-1995 Mustang GT 25 10-10-2015 08:52 AM
Clogged cats. Grimace96 1996-2004 Mustang GT 37 05-29-2014 05:29 AM
Clogged Cats buickregal79 1996-2004 Mustang GT 11 09-03-2013 12:47 PM
2000 v6 possible clogged radiator? HELP! 200v6 New Member Introductions & Greetings 7 01-27-2011 04:26 AM
07:59 PM
