Exhaust heat shield 3.7 - Mustang Evolution
Old 03-02-2012, 09:12 AM   #1
Hey all just curious as to if anyone is missing an exhaust heat shield over the headers on the passenger side? Called the dealer and they said it was supposed to be like that but sounds a little fishy. Let me know if you have one heat shield or both..
iwalkaline58 is offline   Reply With Quote
Old 03-02-2012, 09:32 AM   #2
Titus Wadicus
svtlx's Avatar
Re: Exhaust heat shield 3.7
i know a while back there were issues wit passeger side manifolds getn cracked by a/c condensation... but not sure how its set-up on the newer cars
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 03-22-2012, 06:04 PM   #3
CurbRash's Avatar
My 2012 has both, FWIW.
2012 V6 Premium
w/Performance Package
Kona Blue + Saddle Brown
CurbRash is offline   Reply With Quote
Old 03-22-2012, 08:44 PM   #4
Whats ur manufacturing date? Found another forum seems to me so have them and some dont...
Old 03-23-2012, 08:56 AM   #5
CurbRash's Avatar
Roughly, April 2011.
2012 V6 Premium
exhaust
New 3.7 member question iwalkaline58 2011-2014 V6 Mustang 12 03-07-2012 04:24 PM
99 v6 mustang, exhaust, muffler, flowmaster Ajmt719 Pre-2005 V6 Mustang 18 03-05-2012 10:09 AM
Wheels or Exhaust? BlackHorse1911 2011-2014 V6 Mustang 9 03-01-2012 08:11 PM
help with decision about full exhaust angelofrat42 2005-2010 V6 Mustang 11 03-01-2012 09:35 AM
Heat Edition Mustangs 07 heat mustang Other Special Edition 32 03-01-2012 06:01 AM
04:41 AM
