mph in a 3.7 - Mustang Evolution
Old 03-07-2012, 09:32 AM   #1
A.K.A. Baby-D!
mph in a 3.7
Ford must want to make ppl buy a tuner.... Only 117-118 mph when I have all that extra on the speedometer sucks!
Current:
1989 GT--the project
Previous:
2004 V6--my first pony
1988 GT--July 2010 MOTM
Old 03-07-2012, 09:34 AM   #2
deadsp0t's Avatar
Go speed racer!!
That's unimpressive
Old 03-07-2012, 09:40 AM   #3
The Blue Dragon
GrabberBlue5.0's Avatar
If you feel the need to go faster (I know I do) then a tuner is about the only way to get it done. Just make sure that you have tires that can handle the speed
Part of the reason they do that is so they can put lower speed rated tires on a car. Lower cost for lower performance tires.
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 03-07-2012, 09:49 AM   #4
stampde's Avatar
Re: mph in a 3.7
THERE'S A VID ON YOUTUBE WHERE A DUDE WITH A 3.7 runs it up too 130 mph and his driveshaft blows apart ..... so be careful
2011 GT Auto
Old 03-07-2012, 09:52 AM   #5
deadsp0t's Avatar
I'm convinced that something had been done with that car, like someone had to have had that DS out and not re torqued it correctly. Who knows though I guess
That's unimpressive
Old 03-07-2012, 10:13 AM   #6
A.K.A. Baby-D!
Omg!
Current:
Previous:
Old 03-07-2012, 10:38 AM   #7
deadsp0t's Avatar
Omg!
For less then $50 you can get a DS safety loop to prevent damage if it were to fail.
That's unimpressive
Old 03-07-2012, 10:56 AM   #8
stampde's Avatar
Re: mph in a 3.7
+1
2011 GT Auto
Old 03-07-2012, 11:16 AM   #9
silvrbullet2012's Avatar
That's what I'm getting on mine this coming up paycheck! Then saving up for a new ONE piece DS.
---------- Post added at 12:16 PM ---------- Previous post was at 12:05 PM ----------
Perfect example
Even on the dyno!!!
silvrbullet2012 is offline   Reply With Quote
Old 03-07-2012, 12:03 PM   #10
Titus Wadicus
svtlx's Avatar
Re: mph in a 3.7
and this is y ford has the crappy warranties....
i swear, my heart droped when that driveshaft snapped...musta had my speakers up too loud..lol.
kinda defeats the purpose of buying a stang in the first place. i think i will stay in proven fox era stangs or buy a camaro...
bbk ssi, 70ml t.b., bbk adj.reg., bd11-a 11psi, e-cam,
racing aod, 2700 stall, 3.42 gears, ported e7, 308ci, 1.7rr, comp .560valve springs, gear drive, high dwell module, msd 6a & coil, bbk off road xpipe, mac cat back, 30lbs inj, pro-m 90mm, welded subframe connectors, boxed upper & lower trailing arms, spherical axle bushings, 255/50/16 tires, 255lph pump, 456hp
Old 03-09-2012, 11:18 AM   #11
Pstang5's Avatar
you guys think ford would do something abkut it if we start complaing and taking them to the dealership?
Pstang5 is offline   Reply With Quote
Old 03-09-2012, 11:25 AM   #12
deadsp0t's Avatar
First off these cars that are breaking are NOT under warranty. Dyno tune or hand held voids the warranty. These are the risks YOU assume when modding a car out of factory specs, simple as that.
That's unimpressive
Old 03-09-2012, 06:57 PM   #13
Titus Wadicus
svtlx's Avatar
Re: mph in a 3.7
this is true... but tuners and snapp'n driveshafts are two differnt things....
so then it makes u ask.... wut other stuff did they "under-engineer" on the car.
if u "under-engineer" a simple drive shaft.... are there more complicated "under-engineered" issues....safety issues???
my firebirds and cameros all came with driveshaft loops and i had those puppies up to 140+..... u break a driveshaft at 130 wit no driveshaft loop on a stang...
ur not just riskn your life.. but anyone remotely close to u (ur vehicle) rather u r drag racing, road course, parkn lot slalom, or driving in an un-lawful manner on a public roadway.....
if u know the driveshafts r crap.... put a loop on them (from the factory)..y jeapordize someone's life.
im not yelln at anyone in particular.... but that video scared the crap outa me, and i been trained to drive in reverse at pretty high speeds.
Old 03-09-2012, 07:08 PM   #14
deadsp0t's Avatar
Never herd of or seen one break at a speed or situation where the factory speed limiter was not bypassed. Meaning its my understanding that the ones I know of we're over the 118 factory limit. I personally won't consider them 'under engineered' until they start breaking regularly on stock applications, which has not happened that I know of. Please feel free to correct me if I'm wrong about that.
That's unimpressive
Old 03-09-2012, 07:13 PM   #15
Lol
Blackedout is offline   Reply With Quote
Old 03-09-2012, 07:15 PM   #16
A.K.A. Baby-D!
I agree. But it still sucks. I wanna see over 130mph. Safely. But as mentioned, what else has a potential of breaking? They should have manufactured the car to handle more than stock being a muscle car. Jmo.
Current:
Previous:
Old 03-09-2012, 07:20 PM   #17
I got up to 140 but I backed off. You just need to find and research the speed limiter from ford and avoid that speed by -20 mph to be safe.
Old 03-09-2012, 07:20 PM   #18
deadsp0t's Avatar
I too agree, just wanted to say its not fair to call it 'under engineered' when the stock configuration is perfectly safe.
Also I'd be inclined to add the loop when I started modding. Especially if I planned on bypassing factory speed limiter, that goes for any car IMO. The 6 is geared toward a different customer the GT, always has been and always will be, it's how the mustang has endured.
That's unimpressive
Old 03-09-2012, 07:23 PM   #19
Titus Wadicus
svtlx's Avatar
Re: mph in a 3.7
u r absolutly correct on wut u r sayn.... but ford knows its a mustang, and wut the nature of ppl r.
im just lookn at it from a customer or potential customer stand point.
the mustang is the most modifed car in the world....
y put urself in a postion to lose a potential customer base by not implementing more safety (driveshaft loop) or a better driveshaft.
cause if someone gets hurt... noone is gonna care bout the 118 limit or wutever it is..
im just sayn... i love my mustang, im on my 5th one. but id be lieing to u if if i said that driveshaft video made me wanna reconsider purchasing a new stang.
i know, im not the only person that thinks this way.
especialy anyone that builds their motors, puts their own u joints in, etc.... u r lookn at that thinkn... r u fukn kiddn me???
moreover ppl that r less mechanicaly inclined.... cause all they see is a catostrophic failure in a late model stang.
who wants a stang that u gotta drive like a focus...come the fuk on yo...v6 or not.
Old 03-09-2012, 07:25 PM   #20
A.K.A. Baby-D!
Agreed.
Current:
Previous:
Old 03-09-2012, 07:26 PM   #21
Titus Wadicus
svtlx's Avatar
Re: mph in a 3.7
again, if ur gonna put a crappy driveshaft in it, put a effn loop in it. all my cameros and firebirds all had factory loops...
Old 03-09-2012, 07:26 PM   #22
A.K.A. Baby-D!
Gotta agree here. Especially you go and make a 300+ HP V6. People are gonna push limits and see what it can do. They should be prepared for that.
Current:
Previous:
Old 03-09-2012, 07:28 PM   #23
deadsp0t's Avatar
Your v6 commodes and fire chickens had loops? I don't know that any V8 mustangs have came with loops, why would they have a loop on the 6 and not the GT?
That's unimpressive
Old 03-09-2012, 07:37 PM   #24
Titus Wadicus
svtlx's Avatar
Re: mph in a 3.7
wutever dude... like i said, im not the only person to look at that and think wut im thinkn.
u say wut u want bout the "f bodies" but they came wit effn loops.. is all im sayn...
up to 155 (in mexico)i have not had a failure...
Old 03-09-2012, 07:44 PM   #25
deadsp0t's Avatar
Don't get upset. All I'm saying is there is no precedent for claiming they 'should' come with a loop.
That's unimpressive
Old 03-09-2012, 07:59 PM   #26
Titus Wadicus
svtlx's Avatar
Re: mph in a 3.7
ok, prolly true.... but if gm put in a loop in the 80's with a powerplant half as capable of todays cars
and like i said, from a customer stand point... all ur gonna c is da equipment failure.
half da warranty of other manufactures and equipment failures... thats wut a customer is lookn at.
we here are aware of mechanical limitations...
joe blow customer is only gonna see a equipment failure, not that they shouldnt drive over 118.
on top of that, it will make ppl think that stangs blow up past 118 (they will quickly lose focus over v6 versus v8, all stangs will get lumped together). obviously thats not the case....
but from a customer stand point, thats wut they see, thats wut will make them choose a camero... thats wut will make them choose a challenger.
and even though i build my own engines.... it makes me question the integrity of the rest of the car...118mph or not. v6 or not....
dont think of urself as a stanger when i make these statments....
think of urself as joe blow customer and ur 16yr old kid showed u that youtube video..and u r type of person who takes ur car to dealer to check oil, windshieled washer fluid, and air pressure.
Old 03-09-2012, 09:50 PM   #27
Lol fire chicken I'm gonna have to use that one one day
---------- Post added at 10:50 PM ---------- Previous post was at 10:48 PM ----------
Since we are talking driveshafts I got a question... Can an aluminum driveshaft help this problem?
Old 03-09-2012, 09:52 PM   #28
deadsp0t's Avatar
Yes because it's one piece not two, they use a two piece for ride quality.
That's unimpressive
Old 03-09-2012, 09:55 PM   #29
Ok explain?
Old 03-09-2012, 10:00 PM   #30
deadsp0t's Avatar
The S197's have a two pice driveshaft.
That's unimpressive
Old 03-10-2012, 01:20 AM   #31
Pstang5's Avatar
baam!
Old 03-10-2012, 05:42 AM   #32
Re: mph in a 3.7
I was on the fence about buying my car for almost a year becsuse of the manual transmission issues and driveshaft videos. I still am sort of unessy that i bought this car. I considered even buying a 2010 gt or even v6 becausw i figured the powertrain was more reliable.
I would agree that most people who have problems like these could ve modders and abusers...but stock vehicles should be able to handle some minor modifications. I bought my stang but i was considering a used lexus is350, an audi a4, or bmw 3.....all luxury sport cars....and ive bren driving an infiniti suv for 6 years. Ford is attracting NEW buyers, new people to the brand...but dumb things like this really are hurting them and their stock.
But 04trv6...are you on the track or something? I wont dare do more than 120km/h here (75mph) because you get a big ticket and if you get caught over 150kmh (93 mph) the police destroys your car...yep impounds it then crushes it.
We have helicopters and planes in the sky tracking speeders on the highway...no more speed traps..if you see a cop hes already looking for you. Take it easy speed kills.
And if you want to go really fast youll have to spend alot more than 30k. Bugattis go over 200mph....
the_stig is offline   Reply With Quote
Old 03-10-2012, 05:47 AM   #33
deadsp0t's Avatar
speeding has become less and less socially acceptable in recent years, 70mph is the highest speed limit in NC that I know of.
That's unimpressive
Old 03-10-2012, 07:17 AM   #34
Lol. Over here in south Texas they just raised the speed limit to 75-80!!!!
Old 03-10-2012, 07:21 AM   #35
deadsp0t's Avatar
It's 65-70 on my way to work. I rarely pass 65 because my mpg changes @ 2k and up lol
That's unimpressive
any body in illinois Robbiemustang96 Regional Mustang Discussion 36 04-21-2012 09:03 PM
if you could have ANY stang in the world, which one would it be?? zeltik General Car Discussion 80 03-14-2012 08:46 PM
Any mustng ppl in florida or tampa Famouz 2.3 Mustang 4 03-08-2012 04:53 PM
Goodies in garage :-D Silversky545 2005-2010 Mustang GT 17 03-07-2012 11:36 AM
04:37 PM
