Rpm launch - Mustang Evolution
Old 03-30-2012, 09:51 PM   #1
eswinty's Avatar
Rpm launch
Hey to all of you who drag ur 3.7's what Rpm do u launch at?
eswinty is offline   Reply With Quote
Old 03-31-2012, 06:03 PM   #2
9000 rpms
iwalkaline58 is offline   Reply With Quote
Old 03-31-2012, 08:52 PM   #3
Re: Rpm launch
Lmao
the_stig is offline   Reply With Quote
Old 03-31-2012, 08:55 PM   #4
It's not me, it's you.
primer2tone's Avatar
Originally Posted by iwalkaline58
9000 rpms
Only if you've Plasti dipped your clutch.
Old 03-31-2012, 09:25 PM   #5
Im auto so i just rev up to 9k then throw it in drive. I mixed bondo with the oil and trans fluid so it will automatically fix anything i break.
Old 03-31-2012, 09:36 PM   #6
Las0mbra's Avatar
Smart man. Although plastidip is said to work even better, might try that next time.
Old 03-31-2012, 10:39 PM   #7
Re: Rpm launch
LOL ive got the manual, proudly made in china, so i usually launch at 8500. Ill push to 9k once i break my car in.
Seriously though does anybody have an answer? Like were just being pricks now. Its hilarious though.
Im no drag racer but isnt half the fun of it figuring out that stuff for yourself? The real question is should stability control be turned off?
Old 11-29-2014, 03:42 PM   #8
I'd like to see this answered as well... bump
Ppkonablue12 is offline   Reply With Quote
Old 11-29-2014, 06:39 PM   #9
rob.james.arias
Guest
Posts: n/a
There are several variables that will affect the answer to this question.
Are you using the stock wheels and tires or slicks?
Are you a manual trans or auto?
Do you have a stock suspension?
If you are using stock wheels and tires your RPM's will need to be much lower to avoid wheel spin. You may find that for the track that day lowering your rear tire pressure down to 28 will help with launching. I would not suggest anything above 2700 rpm.
If you are using slicks you can go much higher and have seen guys launching in the 4500-5000 range. This of course is paired with shocks and springs designed for the track.
If you are in a 100% bone stock auto your best bet is to floor it from just a hair above idle...
If you are in a bone stock manual rev it up to 1700 and quickly feather it in to avoid any wheel spin.
****I am not an expert in these things, I drive a modified 3.7 with a mt82 trans. Your results may vary as well as the opinions you gather here. The best best is to try in 500 rpm increments until you find what works best for you and your set up.****
Old 11-29-2014, 09:16 PM   #10
Sakib's Avatar
I can attest that this worked very well for me on the track.
Sent from my HTCONE using Mustang Evolution mobile app
Sakib is offline   Reply With Quote
Old 11-29-2014, 10:35 PM   #11
VIG
VIG's Avatar
Region: Delaware
Rpm launch
For my automatic with just a 93R Bama tune, I found that pedal to the metal from idle was the same if not better than any other RPMs I tried launching at.
Plus us auto guys aren't doing our transmissions any favors by power braking.
IG: workshardplayshard
VIG is offline   Reply With Quote
Old 11-30-2014, 03:10 PM   #12
somedopebeats's Avatar
I honestly cant even tell if you guys are joking or not haha
somedopebeats is offline   Reply With Quote
Old 11-30-2014, 03:13 PM   #13
Voltwings's Avatar
Tried the same thing: Came off idle, staged at 1500, 1750, 2000 with no change in 60' or ET. I imagine if i really tried to stand on it and come out at 2500 or so it might have helped, but like someone said > The trans probably wont like that.
Old 11-30-2014, 05:13 PM   #14
If you have a turbo whistle, there's no need to rev.
Mikeyt03 is offline   Reply With Quote
Old 12-01-2014, 07:31 AM   #15
Voltwings's Avatar
got that woo WOOOOO
Old 12-16-2014, 07:26 AM   #16
RaceRed3.7's Avatar
This is true! I've raced many cars on the street and they all do that rev launching and I just sit quietly waiting for the light. Then when the lights green I floor it. Ive tried both ways a little over idle might be okay but anything over with stock tires I just loose traction.. Depends on your setup.
-SOLD-13.246s@107.81 RaceRed 2013 v6 Mustang, 3.73 gears, MPT 91Race Tune, Axle-Back Straight Pipe, Tower Brace, BMR LCA's, BBK Shorty Headers, BMR Relocation Brackets, Lethal Performance X-Pipe Catless.
-2008 Civic SI...
RaceRed3.7 is offline   Reply With Quote
98 gt (NPI) choking on top end of rpm's leviz79 1996-2004 Mustang GT 14 04-12-2012 08:14 AM
RPM Lubrication Sobersucks85 2005-2010 Mustang GT 7 03-30-2012 12:47 AM
Rpm gauge install!! Help.. 89 Foxloco 1979-1995 Mustang GT 6 03-26-2012 07:20 PM
Quick question about RPM's Mustang_Madness 1996-2004 Mustang GT 29 02-23-2012 05:55 PM
GEAR HEADS HELP! Rapid exhaust popping @ WOT high rpm Brad.krieg SVT Mustang 1 02-22-2012 02:06 PM
03:44 AM
