Check Engine Light - Mustang Evolution
Old 05-08-2012, 10:04 AM   #1
Check Engine Light
I just got my 2012 V6 Mustang in October and haven't done much yet except get Borla exhaust put on. Over the weekend my check engine light came on and I have no idea what may have caused it. I always make sure I get my oil changed every 3,000 miles and I try and take really good care of the car. I called the dealer where I have the warranty and they were less than helpful. They told me to continue to drive it an hour each way back and forth to work all week until I can come in on Saturday. I'm a little nervous that depending on what the issue was it may just get worse.. Any ideas?!??
danir is offline   Reply With Quote
Old 05-08-2012, 11:41 AM   #2
aegischief's Avatar
Is the car running any different? Any changes in oil pressure or water temp?
Could just be a bad sensor of some kind.
aegischief is offline   Reply With Quote
Old 05-08-2012, 02:04 PM   #3
Re: Check Engine Light
It doesn't seem to be running with as much power as usualy, but everything seems to be fine as far as I can see. Hopefully it is just a sensor or something like that. This is the second time I've had to bring it back to fix something already, my air bag had to be replaced a few months back.
Old 05-08-2012, 02:44 PM   #4
aegischief's Avatar
That sucks. Had to bring mine in once to fix the A/C. Other than that it's been solid.
Old 05-08-2012, 02:45 PM   #5
its under warranty let the dealership fix it, also 3k may be FAR to often to change your oil as it can go up to 10k (has some sort of system that tells you when to change it etc) some do it at 5k or 10k~
Old 05-08-2012, 03:08 PM   #6
Yea I am bringing it in on Saturday, hopefully they cover it with the warranty.
Old 05-08-2012, 06:54 PM   #7
Pick up a $40 obd2 reader on ebay itll save you the unsure feeling you have right now next time this happens. 9/10 times its a generic code that the reader can tell how severe it is. Plus the ford dealer cant screw you, unless its a non generic code
the_stig is offline   Reply With Quote
Old 05-09-2012, 06:03 AM   #8
illestdomer2005's Avatar
Does it sound any different when you drive it? If you're saying you lost power, I am wondering if it's an O2 sensor that is jacked up and messing with your fuel tables. Could be starving the engine of power.
But yeah, definitely take it to the dealership...you paid too much to have to worry! And I wouldn't continue driving it until I go it figured out....or let Ford put it in writing that they told you to continue driving it...
2011 Mustang 3.7L, 6A, MCA Pkg, Ingot Silver w/ Stone
Perf Mods: FRPP 3.73 Gears, 87 Octane Performance Tune from BAMA, Airaid CAI, Magnaflow Comp Axle-backs
Ext Mods: Lower chrome billet grille, Tint
Upcoming Mods: Lowering springs
illestdomer2005 is offline   Reply With Quote
Old 05-20-2012, 08:06 AM   #9
Gtzzoom's Avatar
you want mine..? 600 miles on a brand new 2013 and check eng came on and set a left front O2 code...reset, and came back. have appt to take it in thursday while I work at the dealer just below them. Not happy.....was headed to a cruise in when it came back....turned around and went home...ashamed to let 'slimer' be seen with that on. Told ford dealer as much.....not good
Gtzzoom is offline   Reply With Quote
check engine
04:10 AM
