05-08-2012, 11:01 PM
#1 | | Registered User
| Mustang base and premium interiors
Just ordered leather seats for my car and am crazy excited. Other than that I think I actually like the color of the dash in the base ( darker ) then the brushed aluminum in the premium. Other than that is there anything else to do to the interior to try to get rid of some of the cheap plastics they used ?
05-09-2012, 04:34 AM
#2 | | Registered User
What about the door inserts? Quilted leather or a matching color to the interior or exterior could help a lot
2012, Performance Package, C&L CAI, Magnaflow catbacks, Katzkin Cream leather interior
05-09-2012, 04:58 AM
#3 | | Registered User
| Re: Mustang base and premium interiors
Door sill inserts if you dont have them, upgrade your steering wheel (base model ones look like something out of a tractor) and if i didnt have the premium id opt for a carbon fiber dash :p it looks great even though its totally non functional
Heres my interior |
05-09-2012, 11:07 AM
#4 | | Registered User
I like the door insert idea , what would color it ? Paint ?
05-09-2012, 11:48 AM
#5 | | Registered User
Mine is leather. Idk if paint would work or look very good. Another guy just started a thread about the same thing he put in orange inserts. Ask him how he did it and what it costs. I didn't do mine the previous owner did.
05-09-2012, 12:45 PM
#6 | | Terminator Owner
add a boss 302 steering wheel (tousleyfordparts.com I was quoted like 225 shipped)
__________________ 2003 Cobra Vert (Redfire) #3938 of 5082 @ 05/27/2003
472rwhp/493rwtq - Modification List - Dyno Sheet 2012 Mustang 3.7L M6 (Kona Blue) 2011 Ford Edge Sport (Red Metallic) |
05-09-2012, 01:38 PM
#7 | | Registered User
| Quote: |
Originally Posted by the_stig Door sill inserts if you dont have them, upgrade your steering wheel (base model ones look like something out of a tractor) and if i didnt have the premium id opt for a carbon fiber dash :p it looks great even though its totally non functional
Heres my interior
| How much did the illuminated door sills run?
05-09-2012, 01:57 PM
#8 | | Registered User
I brought illuminated door sills for my car from blue oval industries for $100 and they 10x better than the plastic ones. But had to wire them up to my dome lights which means you can't change the color of them once installed.
05-09-2012, 04:40 PM
#9 | | Registered User
| Re: Mustang base and premium interiors Quote:
Originally Posted by Rcary How much did the illuminated door sills run? | mine are stock, i got the interior upgrade pckg
05-09-2012, 10:52 PM
#10 | | Registered User
Hey what is the best way to tap led lights for under the dash into the dome lights . What is the easiest point of access because I tried tracing if out but I kept loosing the wire when I got under my dash
05-10-2012, 05:51 PM
#11 | | Registered User
I have some blue LED strips under my dash but I simply connected it to my headlight switch so they turn on/off when the door open/closes and when driving along at night when my headlights are switched on. also they dim with the dimmer switch.
05-10-2012, 07:52 PM
#12 | | Registered User
Originally Posted by Grabber Blue I have some blue LED strips under my dash but I simply connected it to my headlight switch so they turn on/off when the door open/closes and when driving along at night when my headlights are switched on. also they dim with the dimmer switch. | Clever
05-10-2012, 10:08 PM
#13 | | Registered User
Your headlights come on at night automatically
05-10-2012, 11:11 PM
#14 | | Registered User
| Quote: |
Originally Posted by geepoons Your headlights come on at night automatically | Interesting. What model does that? Mine does not. (2013 Premium V6 manual.)
2013 Mustang V6
Premium Package, Comfort Package (Yay pony lights...), Appearance
05-11-2012, 09:41 AM
#15 | | Registered User
i think the package that gets the fog lights has auto headlamps
05-11-2012, 09:53 AM
#16 | | Moddin' ain't easy...
I like the illuminated cup holders.
__________________ |
05-11-2012, 10:36 AM
#17 | | Registered User
Originally Posted by geepoons i think the package that gets the fog lights has auto headlamps | You are right. I should have just looked it up in the first place. If anyone else is curious, both the Pony Package and the MCA Package have auto headlamps included.
05-11-2012, 01:46 PM
#18 | | Registered User
All our cars are fitted with a light sensor in the dash, its just take ford didn't put the switch in the base and premium mustangs. I was told you can just put in the GT headlight switch?
05-11-2012, 02:57 PM
#19 | | Registered User
Originally Posted by Grabber Blue All our cars are fitted with a light sensor in the dash, its just take ford didn't put the switch in the base and premium mustangs. I was told you can just put in the GT headlight switch? | New guy here, I changed my switch to an automatic switch about a week ago, one of the best and cheapest mods I've ever done to the Stang. Here's a summary that i copied from another forum:
As many of you know it is very simple to get the Auto headlight feature in a vehicle that did not come with it stock. You must simply change out the switch. It was mentioned that the only drawback being that you would not be able to adjust the delay, since it isnt built into the messege center like vehilces that came factory equipped. Follow the steps below and you should be able to set the delay timer for any amount of time up to 3 minutes.
NOTE: The time delay can be programmed through the message center using the message center buttons (if equipped) or using the following steps.
NOTE: Steps 2 through 5 must be carried out within a 10-second period.
1. Start with the ignition switch off and the headlamp switch in the AUTOLAMPS ON position.
2. Place the headlamp switch in the OFF position.
3. Place the ignition switch in the RUN position.
4. Place the ignition switch in the OFF position.
5. Place the headlamp switch in the AUTOLAMPS ON position. The exterior lamps turn on at this point.
6. Wait the desired amount of time and place the headlamp switch in the OFF position (maximum of 3 minutes). The exterior lamps turn off and the autolamp time delay is now set.
Part information:
$27.00 including shipping from Rockauto.com
Part # SW6659
05-11-2012, 03:01 PM
#20 | | Registered User
Thanks I thought you could do that!
05-11-2012, 03:02 PM
#21 | | Registered User
For those who want the auto headlamps for the 2013s, it might be worth asking the dealer about activating that, or adding whatever switch is needed. My Premium V6 appears to utilize the light sensor simply to know when to bring up the nighttime lighting for the instruments and accents.
Personally, I don't care to have automatic headlamps.  I got my car exactly the way I wanted it driven straight over from the factory back on March 30. I'm still in that new-owner haze where everything is good.
Love my interior and the little touches. I was in the market for a fun, strong car and Ford won me over from buying a Camaro this year (I might not always be a Ford guy, but I'm always an American car company guy). And that was comparing a 2012 Camaro I could see and feel to a 2013 Mustang I could not, at the time.
05-15-2012, 08:01 PM
#22 | | Registered User
How do you change out the switch? Is is difficult to remove the surrounding panel(s)? Is is already prewired, so all you have to do is unplug and plug, or is it more involved? Thanks!
05-16-2012, 01:51 PM
#23 | | Registered User
Originally Posted by melwana How do you change out the switch? Is is difficult to remove the surrounding panel(s)? Is is already prewired, so all you have to do is unplug and plug, or is it more involved? Thanks! | It is extremely easy- Just pull out the surrounding plate, unplug the switch from the wiring, reverse, enjoy.
05-16-2012, 03:56 PM
#24 | | Registered User
Mine had a screw behind my switch at the bottom when I pulled it out
05-17-2012, 06:53 AM
#25 | | Registered User
| Quote: |
Originally Posted by geepoons i think the package that gets the fog lights has auto headlamps | Yes pony package has auto lights
05-18-2012, 10:01 PM
#26 | | Registered User
Thanks, Guys! It really works! followed apocalypto's instructions, and Presto! It works! Awesome! And the part only cost me $22.30, shipping included! 5 minutes and I was done! That was the easiest and coolest mod I've ever done! Cool!
05-20-2012, 08:09 AM
#27 | | Registered User
Mayhem....what did you pay for that custom interior? Local guy that I trust had a lime green ultra sof UV resistant vinyl that was gonna get up centers of all 4 seats and door panels...was 700 estimate.....thank goodness for matching seat cover set on eBay..LOL! It will work for now....
