Opinions on best turbo/SC? - Mustang Evolution
Old 05-19-2012, 11:28 PM   #1
Missxalii's Avatar
Send a message via AIM to Missxalii
I'm looking to get one or the other. Any one have a TC or SC? What are the pros and cons of both? Feedback on what you have? I'm on a budget, but I want to get a pretty decent amount of power. What would be my best bet?
I have a 2010 V6 by the way.
2012 Dub Edition V6 Mustang
full borla exhaust / steeda intake / 3.73's / aluminum driveshaft
exedy stage 3 clutch / spec steel flywheel / steeda shifter bushings
Missxalii is offline   Reply With Quote
Old 05-19-2012, 11:30 PM   #2
2300turboford's Avatar
TURBO!!!!!!!!!!!!
Old 05-19-2012, 11:30 PM   #3
Missxalii's Avatar
Originally Posted by 2300turboford
TURBO!!!!!!!!!!!!
Well that helps! -.-
Old 05-19-2012, 11:33 PM   #4
Lol yeah thats what i would do more power and better sound
Old 05-20-2012, 08:56 AM   #5
Missxalii's Avatar
I do like the sound better. But why do you say more power?
Old 05-20-2012, 09:06 AM   #6
93slowstang's Avatar
Because a turbo doesn't have the parasitic drag from a belt turning it. A supercharger requires power to make power.
Old 05-20-2012, 09:07 AM   #7
Re: Opinions on best turbo/SC?
A TC system will cost more and is more complicated, BUT I think the benefits ultimately outweigh the extra cost and installation difficulties.
1. TC uses normally wasted exhaust heat and pressure to build boost to feed the engine.
2. A TC is "easier" on the engine as it does not introduce any side loading or unwanted harmonics into the crankshaft like a belt driven SC will do.
3. A TC has a lot less "parasitic" power loss than an SC. (i.e. It doesn't use as much engine power to make power.)
4. The waste gate (BOV) whoosh! is just plain COOL!
An ECO Boost engine swap into your car would be really cool, power and gas mileage, but probably prohibitively expensive at this point.
Old 05-20-2012, 09:46 AM   #8
Missxalii's Avatar
Hmm. I know how they work. Lol. Why would someone even bother getting a SC then? What are the benefits of having one? How much hp can you get out of a TC/SC. I'm worried about price, gas milage (I know it won't be great regardless), horsepower, and how much wear and tear it will do on my baby.
Old 05-20-2012, 10:30 AM   #9
1. Why would someone even bother getting a SC then?
They are cheaper and easier to install. Also depending on whether you choose a centrifugal or roots style an SC can make power from almost idle on up. A roots style supercharger is usually chosen for this reason as it will make power in the lower RPM ranges where street cars are normally driven.
2. What are the benefits of having one?
Same as a TC, they just won't make quite as much all out HP due to the parasitic loss differences. Also for power in the lower RPM ranges with the roots style superchargers.
3. How much hp can you get out of a TC/SC?
Depends upon how much boost your chosen forced induction can make and what your engine, fuel, exhaust and air intake systems can support. Normal low boost of 6-8 psi might net you between 50-100 HP gain. With properly built engine and configured systems, you are only limited by the cubic dollars you want to spend.
4. I'm worried about price, gas milage (I know it won't be great regardless), horsepower, and how much wear and tear it will do on my baby?
Price will be affected by system quality and capabilities. I'd start by researching to see what is available specifically for your car.
Gas mileage won't be a big issue unless you are constantly deep in the throttle and building boost. Normal driving will likely show very little decrease in MPG.
Wear & Tear will also be governed by how hard you run it.
Old 05-20-2012, 08:19 PM   #10
Missxalii's Avatar
Okay. Thank you so much, really appreciate the detailed answer. Are there any specific TCs you've worked with or used and like? What would you recommend for my car?
Old 05-20-2012, 08:58 PM   #11
I'd go turbo. That helps?
Blackedout is offline   Reply With Quote
Old 05-20-2012, 09:58 PM   #12
You are welcome.
I haven't any personal experience yet, but one of our members in the 79-95 forums Jay Kranz has used the On3 turbo kit on his car with decent results providing you upgrade the turbo when ordering.
If you go to the 79-95 forums there is a sticky thread on Superchargers and Turbos.
In the thread are some links to various manufacturers if you wish to check them out.
Old 05-20-2012, 10:05 PM   #13
Missxalii's Avatar
You are welcome.
Sounds good. I'll check it out!
---------- Post added at 08:05 PM ---------- Previous post was at 08:04 PM ----------
Lol. Sorta? I love the sound of a spooling turbo butttt supercharged sounds a lot more bad ***. From what I've heard (outside of this forum) they generate more power. I'll have to do my research though.
Old 05-25-2012, 05:16 PM   #14
It doesn't make more power it doesn't have the drag from the belt take a car with 10lbs with a supercharger and 10lbs with a turbo the turbocar will always make more and if sized right the spool up is really quick
Old 05-25-2012, 05:42 PM   #15
gqsmash's Avatar
Don't know much about either but if the turbo is better at making power why doesn't Shelby turbocharge instead of supercharge? I think the supercharger is the simpler choice...
gqsmash is offline   Reply With Quote
Old 05-25-2012, 05:46 PM   #16
Cost less and easy to install
Old 05-26-2012, 01:14 AM   #17
Enorym's Avatar
First...does your car need to pass smog?
Second...does it need to be reliable?
Third...are you going to install it?
Enorym is offline   Reply With Quote
Old 05-26-2012, 06:55 PM   #18
Missxalii's Avatar
That's why I was like whattt? Saleen, ROUSH, ford, they all have supercharged mustangs, never turbocharged.
---------- Post added at 04:55 PM ---------- Previous post was at 04:55 PM ----------
I'm not sure.
Yes it does.
I have someone who can.
Old 05-26-2012, 07:27 PM   #19
Enorym's Avatar
Are there smog regulations in the state you live in? Do you have to take your car to a testing station after the first 6 years of owning it?
Old 05-26-2012, 08:09 PM   #20
Missxalii's Avatar
Honestly I have no clue. I'm 19 and this is the first car I've ever owned. When I got in inspected they just pulled it up and out a sticker on it because it's a new car.
Old 05-30-2012, 11:58 AM   #21
shadow commando's Avatar
Where is a good place to find a used TC?
shadow commando is offline   Reply With Quote
Old 05-30-2012, 12:12 PM   #22
One of a diesel works good
Old 05-30-2012, 01:12 PM   #23
Any diesel or a specific one?
02:56 AM
