rear axle moving? - Mustang Evolution
Old 05-24-2012, 09:16 AM   #1
davidn7488's Avatar
rear axle moving?
I'm curious as to whether I did something wrong or if this is normal. I installed the Eibach pro kit lowering springs about a month or so as well as h&r spacers on the rear. It handles great and looks good and everything however... the rear axle sometimes moves from side to side a little bit. I noticed it when I turn into a parking space to park, sometimes one rear wheel will be sticking out and the other side has moved in. I read that with the mild drop, I wouldn't have to replace the panhard bar so I didn't. Could this be it or any other suggestions?
davidn7488 is offline   Reply With Quote
Old 05-24-2012, 12:49 PM   #2
CYCLON37's Avatar
Grab a panhard
CYCLON37 is offline   Reply With Quote
Old 05-30-2012, 09:42 AM   #3
davidn7488's Avatar
Originally Posted by CYCLON37
Grab a panhard
Any suggestion as to which? It looks like bmr is the most popular but most expensive
Old 05-30-2012, 10:29 AM   #4
CYCLON37's Avatar
I've got the J&M off AM. I bought it when it was on sale for $100. It's $115 now. Not too bad
Old 07-11-2012, 08:32 PM   #5
davidn7488's Avatar
I ordered the BMR adjustable pan hard bar. It should arrive tomorrow hopefully. I read a couple reviews about the cheaper ones having to be replaced a few months after install. Did you install it yourself?
Old 07-11-2012, 10:29 PM   #6
CYCLON37's Avatar
Nope had it installed the same time the shop installed all my other suspension parts. No problems with it. And I saw the BMR, would've gotten that if it was on sale back when. The cheaper aluminum ones probably have to be replaced on cars being tracked often and pushed hard. They're more for street use. If your looking to do track days then grab a steel.
Old 07-14-2012, 12:03 AM   #7
Red Stallion 11's Avatar
1+ panhard bar will fix that
Red Stallion 11 is offline   Reply With Quote
02:52 AM
