Rough idle while a/c or heat is on? - Mustang Evolution
Old 05-30-2012, 07:17 PM   #1
Mayhem48's Avatar
As anybody noticed this? My car seems to idle fine around 800 rpm but if I have the a/c on the rpm will drop off a bit and rev back up to close to 1000 then settle back to around 800. It does it ever couple of minutes while at a stand still. Obviously when I'm driving I don't notice anything. Wondering if this is normal and if so, why?
2012, Performance Package, C&L CAI, Magnaflow catbacks, Katzkin Cream leather interior
Mayhem48 is offline   Reply With Quote
Old 05-30-2012, 07:26 PM   #2
Whitelightning's Avatar
Does the exhaust skip? Mine kinda gets loud when you crank if then idles around 7-800. When the ac or heat is on it gets loud for a good 30 seconds then quiets down. Is this similar to you?
Old 05-30-2012, 08:26 PM   #3
The Blue Dragon
GrabberBlue5.0's Avatar
All that is happening is your idle is readjusting to the power being used by your a/c compressor. Compressors run in cycles (not sure if it's an on/off cycle or low/high pressure). Every car does it. Compressors have been proven to use as much as 25 hp in some cars.
Many newer models will use a/c compressor for heat and cold to help dry out the air that comes into the cabin
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 05-31-2012, 10:11 AM   #4
Mayhem48's Avatar
Good enough for me! I knew it was something along those lines
Old 05-31-2012, 10:42 AM   #5
Re: Rough idle while a/c or heat is on?
I would blame the MAF, but you have a new car so it couldnt be gunked up. Your idle is probably a bit to low at idle so when the AC kicks on it take a hit and idles a bit lower and thus the shake.
Old 05-31-2012, 10:49 AM   #6
Lorraine's driver
ab_mach1's Avatar
You could try the idle re-learn. This made it so my idle is the with or w/o the A/C on. You just hear a little different growl from the engine.
Disconnected NEG from battery for 30 minutes.
Reconnected battery and started car letting in idle while the engine gets to temperature, then wait one minute.
Turn the AC to Max a little over one minute, then turn off.
Then go drive the car for at least 10 miles.
This made a dramatic impact on idle smoothness and drivability (manual tranny) with my car.
Instagram: @ab_mach1
Old 05-31-2012, 02:36 PM   #7
Mayhem48's Avatar
Very interesting. Where did you get this idea??
Old 05-31-2012, 03:07 PM   #8
Lorraine's driver
ab_mach1's Avatar
Seen it in various Mustang forums, including this one. Apparently, it's in our owners manual, but I couldn't find it. I think this applies to 99 and newer. Somebody correct me if I'm wrong about that. This worked really well for me.
Old 06-01-2012, 05:18 AM   #9
Mayhem48's Avatar
I'll try it and let you know how it works. Thanks!
Old 06-01-2012, 06:35 AM   #10
illestdomer2005's Avatar
That's the idle relearn that I got from BAMA when they sent me my tunes too.
2011 Mustang 3.7L, 6A, MCA Pkg, Ingot Silver w/ Stone
Perf Mods: FRPP 3.73 Gears, 87 Octane Performance Tune from BAMA, Airaid CAI, Magnaflow Comp Axle-backs
Ext Mods: Lower chrome billet grille, Tint
Upcoming Mods: Lowering springs
illestdomer2005 is offline   Reply With Quote
Old 06-01-2012, 07:34 AM   #11
Lorraine's driver
ab_mach1's Avatar
Right on!
Old 06-19-2012, 10:17 AM   #12
Mayhem48's Avatar
I finally tried the idle relearn and it didn't work I guess I didn't do it right. When u say let the engine get to temp do u mean when it revs down after turned on or when the temp gauge is in the middle? That's my only confusion I think
Old 06-23-2012, 10:29 AM   #13
The Blue Dragon
the car must be at normal operating temp...
Old 06-23-2012, 11:54 AM   #14
Malonjao's Avatar
my rx-8 used to do that, somehow my safety toggle switch plug was lose. Just had to reconnect it. Not sure if that applies to mustangs.
(Sold) 04 RX-8 2nd Motor,
(Sold) 94 Jeep Wrangler 5" Lift Decked, & 07 Jeep Liberty
(Sold) 2012 V6 Stang Convertible.
2005 Chevy S-10
2007 Hyundai Tiberon GT
2016 ECOBOOST Stang w/ Performance Pkg
Malonjao is offline   Reply With Quote
01:56 PM
