Will these wheels fit? - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs > 2010-2014 V6 Mustang
Closed Thread
Old 06-26-2012, 07:33 AM   #1
ohiomgman's Avatar
ohiomgman is unknown around these parts
Question Will these wheels fit?
I have the 17", charcoal bullet, aluminum wheels from my 2002 Mustang GT from when I traded it in on a new 2012 Mustrang V6 with the DOHC engine. My 2012 also has 17" mag wheels. Question... Will the 2002 wheels fit my 2012? I really like the charcoal bullets...
ohiomgman is offline
Old 06-26-2012, 07:45 AM   #2
CYCLON37's Avatar
CYCLON37 is unknown around these parts
They'll fit. I'm not sure how the offsets are on those but since they are stock they can't be too bad. They'll stick out closer to the fenders then your current but I think they should be good. Anyone know the offsets on those?
---------- Post added at 09:45 AM ---------- Previous post was at 09:41 AM ----------
Just put them on and see how they look. If they stick out and you don't like it, go back
CYCLON37 is offline
Old 06-26-2012, 10:29 AM   #3
Gtzzoom's Avatar
Gtzzoom is unknown around these parts
Re: Will these wheels fit?
sounds like a plan...an inexpensive trial and error....without buying wheels.
if they dont work, you can always sell em on ebay or craigslist...
"Slimer" 2013 V6 Premium 6MT
"What you have here sir, is a class 5 full roaming vapor, a real nasty fella!" Ray Stanz (Dan Akroyd) in Ghostbusters
Gtzzoom is offline
Old 06-26-2012, 12:54 PM   #4
Whitelightning's Avatar
Whitelightning is unknown around these parts
But the older stands had a smaller wheel well. So you'll need bigger tires than you had on the old one. I personally like a flush wheel then a wheel that comes on mine stock. Would a 19x10 fit the rear of these v6s?
Any Speed over 55 mph can kill you... thats why i drive 60
Whitelightning is offline
Old 06-26-2012, 01:41 PM   #5
CYCLON37's Avatar
Of coarse, as long as it's the right offset for our vehicles. I've got 18x10's on mine +45 offset and it's just about perfect.
CYCLON37 is offline
Old 06-27-2012, 10:25 AM   #6
ohiomgman's Avatar
I recall that if I had used 2005 and up, stock, Ford Mustang wheels on my 2002 'stang that I would have been required to use longer wheel studs and spacers between the wheel and the hub...or use wheel adaptors which would bolt to the hubs and create the correct offset for the 2005+ wheels. SO..the 2005+ wheels have less offset that the 2004- wheels right?
I purchased my 2004 Charcoal GT Bullets, off of e-bay for my 2002 GT so I would not have to go through all that jazz and they worked fine with no mods....so the 2005+ wheels have LESS offset than the 2004- wheels have?
I wanted to mount up some new soft, Summertime only, "stickys," on the 2004- charcoal bullets but now I dunno..... Hmmmmm.... What to do?
Looks like the 2004- wheels would stick out of the wheel wells to far... I will have to diddle with them and see...
Closed Thread
06:40 PM
