Tranny problems - Mustang Evolution
Old 07-04-2012, 07:49 PM   #1
Whitelightning's Avatar
Tranny problems
Does the automatic transmission supposed to shift semi clunky like the manual counter part?
Old 07-04-2012, 07:55 PM   #2
1slosix's Avatar
Re: Tranny problems
no...it's a nice smooth shift unless you have issues...are you throwing any codes? what exactly is it doing?
Old 07-04-2012, 08:06 PM   #3
I can feel the shifts and sometimes they are very harsh. My passengers don't however unless it's a downshift. When I kick it in retreat you can hear a solid clunk but there is no delay in the shifts. It's just loud
Old 07-04-2012, 08:13 PM   #4
1slosix's Avatar
Re: Tranny problems
i'd do a service flush and fill on the trans fluid...and spend the extra $15 on a new trans filter w/ gasket kit (might as well since you'll need a new gasket)
after you do the swap take a magnet to the old fluid and see if any metal gets pulled up and around by it. lets make sure nothing is sheared slightly in there
Old 07-04-2012, 08:25 PM   #5
How do you do this and check the fluid of the tranny with no dipstick. I have change the oil and checked the rear end fluid but other than that idk what about it
Old 07-04-2012, 08:30 PM   #6
1slosix's Avatar
Re: Tranny problems
what model stang do you have?
here's a simple vid on this
---------- Post added at 09:30 PM ---------- Previous post was at 09:29 PM ----------
not as easy as flushing and filling a 5 speed, but still pretty straight forward
Old 07-05-2012, 10:21 AM   #7
2011 automatic premium.
Old 07-05-2012, 03:49 PM   #8
Quikstang's Avatar
Re: Tranny problems
I had the same exact issues both downshifting and the upshift at low speeds. The problem persisted after a full transmission fluid refill. Solution? Get a Bama Tune and select the "Turn off Skip-Shift" option. (No I don't work for AM! haha) The V6 automatic transmission has a skip shift in the software that automatically skips 2nd and 3rd gear! (It helped them achieve their 32mpg benchmark) Once I had the bama tune, no more clunky auto shifting.
2012 V6 Premium MCA
3.31 Limited Slip
Black 3.7 MGP Caliper Clips
Boss Tower Strut Brace
Airaid CAI
Bama 87 Performance Tune
Quikstang is offline   Reply With Quote
Old 07-05-2012, 05:19 PM   #9
Idk if thy would do it. My fluid is fine and I figured it did that cause when I counted the gear shifts and it didn't add up to 6. Mine too had this weird shifting pattern at low speeds.
03:54 PM
