how many miles per tank does ur mustang get. - Mustang Evolution
Old 07-08-2012, 05:08 PM   #1
cheelyb09's Avatar
So I recently bought a 2013 v6 and when I first filed it up it said I was getting 303 miles per tank but I filled up my tank today and it said I only get 274 miles per tank.I always fill it up on a half a tank or a 1/4,I never wait till its on empty.it said I'm supposed to be getting 19mpg but now it says I get 17mpg.it changes from time to time.
How many miles per tank and how many MPG does your mustang get.
Old 07-08-2012, 05:41 PM   #2
Jgill1992's Avatar
My 05 GT gets about 315 per tank and like 22-26 mpg highway and that's with a 93 octane race tune.. Shouldn't your v6 be getting like 28 ish?
2015 Mustang GT Premium. No mods yet.
Jgill1992 is offline   Reply With Quote
Old 07-08-2012, 06:00 PM   #3
cheelyb09's Avatar
I thought so.maybe I should take it to the dealer ship.
Old 07-08-2012, 06:08 PM   #4
Jgill1992's Avatar
Yes I would. It should deffenatly get more than 20 unless you are going WOT at every stop lol.
Old 07-08-2012, 06:27 PM   #5
Gtzzoom's Avatar
Re: how many miles per tank does ur mustang get.
that and put your right foot on a diet...
you must have a ton of stop and go driving....mine gets 23-24 around town...but havent had a good hwy run yet...
---------- Post added at 06:26 PM ---------- Previous post was at 06:24 PM ----------
second idea...something my ol Man taught me...fill up at night when the sun is gone and its cooler...if not then as early in the morning as possible on way to work..like pre-7am and pack it full slowly. there's a burp stop....youll get more in there...heat expansion will help with the rest.....
has worked for me since high school...
---------- Post added at 06:27 PM ---------- Previous post was at 06:26 PM ----------
or pre 8am at least...
"Slimer" 2013 V6 Premium 6MT
"What you have here sir, is a class 5 full roaming vapor, a real nasty fella!" Ray Stanz (Dan Akroyd) in Ghostbusters
Gtzzoom is offline   Reply With Quote
Old 07-08-2012, 06:31 PM   #6
MustangDUB's Avatar
My 2011 gets an average of 20.1 mpg. However I recently went on a road trip to PA (from NJ) and put it on 75 MPH on cruise control and had over 30 MPG.
MustangDUB is offline   Reply With Quote
Old 07-08-2012, 06:53 PM   #7
cheelyb09's Avatar
I should have mentioned these are city miles or more like errand miles.i havent taken it on a rode trip yet.i mostly just use it to go to the store,school and work.
Old 07-08-2012, 07:47 PM   #8
Gtzzoom's Avatar
that will have a lot to do with it.
Try my suggestion on the fill up....pack it full. then reset your mpg readings and try from there
Old 07-08-2012, 07:51 PM   #9
cheelyb09's Avatar
Thank you,i will try that.
Old 07-08-2012, 07:52 PM   #10
Gtzzoom's Avatar
you have nitrogen in the tires..or not?
Old 07-08-2012, 07:53 PM   #11
aegischief's Avatar
The MPG reading the computer gives is off quite a bit. I have an App on my iPhone to calculate my fuel mileage. My car shows around 28.5 MPG but my actual mileage is a little over 30 MPG.
This is 100% stock. I drive 41 miles to work one way. Half is straight highway and the other half is stop and go traffic. I get close to 35 MPG on rode trips. I also have a light foot.
aegischief is offline   Reply With Quote
Old 07-08-2012, 08:52 PM   #12
The best way to check is the old pencil & paper method.
Take the miles you drive and divide the amount of gas you put in.
It is more accurate if you go about 500 miles or so before doing your calculations.
Just keep track of how much gas you buy in the 500 or so miles.
Old 07-08-2012, 09:18 PM   #13
05MUSTANG4.0L's Avatar
I get 226 on afull tank (87) 05 v6 which is like 15-18 mpg ...but with a has treatment I get like 30 miles extra, 19 mpg
05MUSTANG4.0L is offline   Reply With Quote
Old 07-08-2012, 09:47 PM   #14
syas07's Avatar
Send a message via Yahoo to syas07
I'm around DC so it's all stop/go and I get 19mpg and roughly 300(ish) a tank. Went for a raid trip to FL and got 460 miles and 31mph. That was doing between 80-85 most of the time.
syas07 is offline   Reply With Quote
Old 07-08-2012, 09:57 PM   #15
NicholasP's Avatar
Your engine hasn't fully broken in yet trust me had the same problem with my car when I first got it after a while the mpg goes up naturally without changing driving style
NicholasP is offline   Reply With Quote
Old 07-08-2012, 10:33 PM   #16
cheelyb09's Avatar
I'm not sure if I do or not.
Old 07-08-2012, 11:24 PM   #17
CYCLON37's Avatar
I recently got 23 mpg's the past 1000miles. Best I've gotten since I got her. That's all highway btw. I'll never see anything close to 30.
CYCLON37 is offline   Reply With Quote
Old 07-09-2012, 06:23 AM   #18
Gtzzoom's Avatar
green tire valve caps from factory if you do...if not, bring your tire pressure up to 35 all around..regardless of that dumb inflation tag
Old 07-09-2012, 06:39 AM   #19
slow281
sixpac's Avatar
Region: Nebraska
+1 make sure they psi matches your tire.. And all the tires match
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 07-09-2012, 06:43 AM   #20
A.K.A. Baby-D!
mine gets around 305 miles, averaging 21-22 MPG each tank. but i have a lot of stop and go miles in the city. i've seen 30mpg highway before as well.
Current:
1989 GT--the project
Previous:
2004 V6--my first pony
1988 GT--July 2010 MOTM
Old 07-09-2012, 07:10 AM   #21
Red Stallion 11's Avatar
I find that shifting just at/under 2 k Rpm in the city will get you 22-23 mpg. That seems to be the sweet spot. The more you mod the car it seems the better mpg you get as long as you get a tune
Red Stallion 11 is offline   Reply With Quote
Old 07-09-2012, 07:22 AM   #22
It's not me, it's you.
primer2tone's Avatar
I hover around 20mpg and just over 300 miles per tank. But that's a 5.0
Old 07-09-2012, 07:26 AM   #23
A.K.A. Baby-D!
i usually shift between 2-3k and it gets me 21-22 in the city...
what mods do you have?
Current:
Previous:
Old 07-09-2012, 11:24 AM   #24
Jgill1992's Avatar
I usually get like 14 mpg avg in my gt it's fun tho!
Old 07-09-2012, 12:19 PM   #25
Mustangs's Avatar
285 - lots of city stop and go driving
Mustangs is offline   Reply With Quote
Old 07-09-2012, 01:14 PM   #26
I have a 2013 with 1200 miles on it I have only averaged 22 - 23 mpg. I drive a lot of rural, that is 55 - 60 mph for 5 - 6 miles, stop, then same thing. I fully expected to get at least 27-28 mpg, so I also am concerned about this.
CanaanStang is offline   Reply With Quote
Old 07-09-2012, 10:00 PM   #27
cheelyb09's Avatar
Mines has about 1,300 miles on it.but I just drive around the city a lot but I thought that it was suppose to be getting atleast 22 or 23mpg for the city.
Old 07-10-2012, 08:57 AM   #28
Motorcity67's Avatar
I have 4500 miles on my 2012 V6, getting 19 city 300 per tank.
Motorcity67 is offline   Reply With Quote
Old 07-10-2012, 11:37 AM   #29
Quikstang's Avatar
I get about 330 miles out of a topped off tank. I have an 87 Performance Tune and an Airaid CAI. I make lots of trips back and forth from Philly to DC, so the highway driving helps a lot. Also, no scoops or louvers makes a big difference.
2012 V6 Premium MCA
3.31 Limited Slip
Black 3.7 MGP Caliper Clips
Boss Tower Strut Brace
Airaid CAI
Bama 87 Performance Tune
Quikstang is offline   Reply With Quote
Old 07-10-2012, 11:58 AM   #30
Son_of_Zeus's Avatar
I also have a 2013 v6 (manual) and I have basically 900 city miles. Barely any highway miles, a lot of stop and go driving. I get like 260 miles per tank and my car says I get about 15 average miles per gallon
Son_of_Zeus is offline   Reply With Quote
Old 07-10-2012, 12:05 PM   #31
Quikstang's Avatar
It's all that City Driving. I was getting 18 mpg driving primarily through the city. Once I moved out to the burbs, the mpg boosted by 50%
2012 V6 Premium MCA
3.31 Limited Slip
Airaid CAI
Old 07-10-2012, 12:16 PM   #32
Mustangs's Avatar
I can't tell if your being serious about the louvers and scoops haha
Old 07-10-2012, 01:13 PM   #33
D2theJ2theC's Avatar
I get about 22-23 on my 2013, but that's with the performance package and 19inch wheels. The sad part is my wife get 3 or 4 MPG less than I do. I'm chalking it up to her braking more.
D2theJ2theC is offline   Reply With Quote
Old 07-10-2012, 06:13 PM   #34
I'm in a similar boat. I have less then 1k on the odo and I'm getting around 17.8 mpg and about 273 miles a tank. I live on post, so 90% of my driving is stop and go in 2nd, 3rd, or rarely, 4th gear. I figure my mileage is just due to the type of driving I'm doing.
davewes is offline   Reply With Quote
Old 07-11-2012, 10:24 AM   #35
ID:	58516[ATTACH]Click image for larger version
09:45 PM
