07-17-2012, 11:59 AM
#1 | | Registered User
| Help
I added some louvers on my stang a while back but 1 started coming a little lose. When I pulled it off to add new mounting tape the old tape is stuck on the side of my car. This is a
Major problem. How
Can I get it off?
__________________ |
07-17-2012, 01:33 PM
#2 | | Registered User
| Re: Help
NO...NO PROBLEM.....
was typical 3m double sided right....just easily roll it off starting with an end...what doesnt go...use goo gone.....
mine are holding but slowly loosening at top in small area...but waiting until they get worse to change out to the better, thinker 3m
"Slimer" 2013 V6 Premium 6MT
"What you have here sir, is a class 5 full roaming vapor, a real nasty fella!" Ray Stanz (Dan Akroyd) in Ghostbusters
07-17-2012, 02:27 PM
#3 | | Registered User
| Re: Help
What ever you do, DON'T use a scraper or any other tool. Take your time with it and scrub with goo gone and it will come off! Easy peasy
But on a side note...why did the louver start to fall off? Manufacturer or installer error?
2011 Kona Blue 3.7L. Stock motor. Roush Axle-Back. 19" x 8.5/10" Charcoal AMR's. GT500 Spoiler. Smoked Raxiom Tail Lights. MCA grille. Shorty antenna.
An outstanding DD |
07-17-2012, 02:30 PM
#4 | | Registered User
| Quote: |
Originally Posted by Bighebs10 I added some louvers on my stang a while back but 1 started coming a little lose. When I pulled it off to add new mounting tape the old tape is stuck on the side of my car. This is a
Major problem. How
Can I get it off? | Use wd40 it take it right off
#5 | | Registered User
| Re: Help
I noticed mine flex with the expansion and contraction in the heat here in the south...after time its worked its way loose (only a 1 inch area at the top) but not really noticeable....gonna wait til it gets way worse...and I cant stand to look at it that way..
07-17-2012, 02:37 PM
#6 | | Registered User
| Re: Help Quote:
Originally Posted by Gtzzoom I noticed mine flex with the expansion and contraction in the heat here in the south...after time its worked its way loose (only a 1 inch area at the top) but not really noticeable....gonna wait til it gets way worse...and I cant stand to look at it that way.. | Holy cow! They expand and contract that much? A inch is quite a big deal...
An outstanding DD |
07-17-2012, 08:39 PM
#7 | | Registered User
Spray some adhesive/grease remover and let it soak in for a while. Use your thumb to roll it off
07-17-2012, 08:43 PM
#8 | | Registered User
| Re: Help Quote:
Originally Posted by dgrum04 Holy cow! They expand and contract that much? A inch is quite a big deal... | Nah. He's just saying an inch of adhesive has come loose. Wonder if they stick better if you let them heat in the sun before install... seeing as they're already expanded at that point and will contract/expand closer to the rate of the car.
07-17-2012, 08:56 PM
#9 | | Registered User
| Re: Help
bad part Sanguin...thats what I did.....
so when they contracted when the sun went down...is when the fun really started....
07-17-2012, 11:13 PM
#10 | | Registered User
My car is black so I used some black silicon to fill the cracks and hold it on. I'm sure clear silicon would work well on all color cars. It's so thin u can't even notice its there. Just a option to help hold it on
07-18-2012, 12:24 AM
#11 | | Registered User
Thanks for the help everybody! And it just started getting a little loose so I decided I would re-do it over risk if flying off
08-07-2012, 09:30 PM
#12 | | Registered User
Plus I also have the 4.0 and not 3.7
