Howdy, So my mustang has a license plate on the front, which is good...and bad. Good for i wont be pulled over, bad for its not looking good i wanna remove it and put my license plate on the dash. But i have the black license plate holder (i dont know what it called), how can i remove it without leaving holes on my bumper? Or where can i go to remove it..? thanks
If you put it on your dash be sure to secure it somehow, if you just tuck it underneath your windscreen it can become weaponized in a crash and take off your head
I requested the dealer to not install the bracket and give me a bracket that tucks the plate away under the bumper, but the kit didnt fit, id have to cut into my bumper apron, so i ended up installing the factory bracket damn laws
I have the two holes in mine from the previous owner. So nice of them to take the damn thing off. I would rather have the bracket and a plate on there then two holes. Anyone have a OEM bracket they want to sell?
alright so go to bumperplugs.com they have push pins there that will fill the holes in your bumper and will match the paint color on the head of the push pins for any make or model even ones that aren't posted to the website. I would recommend hide away plate instead of mounting your license plate to the wind shield. The manual operating one only cost 50 bucks and just pull it and push it to operaterate it.
That's what my dad did with his challenger then got pulled got a verbal warning. With a 96 trans am he had he got it licensed in a state that didn't require front plates because it never had one on it after 15 years.
I have had a car without front plates since 1997, and I have never gotten as much as a warning. That's in Santa Cruz/Capitola California. Knock on wood.
If you want to live in Cali and avoid all the issue... have a residence in another state and make it your permanent residence then just reside in Cali. I'm sure it makes things a lot easier.
I have the resolution for this but I need to do some searching and find the name. I used to hang out with a Camaro guy who had his plate bracket off the front, and they make one that installs under the number that you can fold and tuck under for shows. Gonna try and find it, gimme a bit.
FOUND IT!!! Search for Altec retractable front license plate cover. There's vids and pics with these on Mustangs. Can get remote controlled ones too lol. In the Camaro world they called it "Show-N-Go" when it first came out, that's the Altec brand one.
---------- Post added at 10:36 PM ---------- Previous post was at 10:32 PM ----------
And to add to that, I suggest also surfing the Camaro/Dodge forums for ideas because they didn't come with front mounting brackets, so people were trying to figure out alternate ways to display their front plate. In one Camaro forum someone said he saw a guy with his plate inside the cabin on the passenger side visor flipped up towards the window to display it. Just giving you some ideas.
But for those who do want to take off the front bracket or got an aftermarket bumper, if you can get the Altec retractable plate holder, that's a very nice modification to keep the clean look. I want to get one myself at some point.
Thanks for the post. Just got mine Saturday, and I told them not to mount the front. CT requires them, so I need the lower brackets. Never heard of a retractable one though. Will definitely look into it.
Can anyone give me an idea how I might remove this bracket? I've checked behind the grille, but the back of these are not exposed at all. Will these need to be drilled out? I've read where people have done that with the plastic rivets...
I am not familiar with this arrangement!
Did you try to turning them?
I would start with CCW first.
You can put 2 nuts on the threaded end. One nut will lock against the 2nd nut allowing you to put a bit of force on it.
I'm, sure someone will chime in.
When I bought my Mustang new, I told the dealer not to put the holder on and no holes in the bumper. I bought my own bottom mounted holder.
I've never seen that before. Mine was held on with two self threading bolts.
2014 Sterling Grey FP6 w/ Tech package
Current Mods: Gibson exhaust; MMD hood scoop and side scoops; Tinted head lights, tail lights and all reflectors.
Those are rivets. Punch that center part in with a punch and hammer, then hit the hole with a drill bit just a little bit bigger than the hole your left with once those center pieces are gone. It will pop off. I've never seen them rivet them on like that
Thanks again for your help oxford, so essentially, I am going to be knocking these suckers out with the punch and hammer? Should I worry at all about the plastic cracking or whatever behind the rivets?
No kidding. But he used the search function, so I like him already haha. It is odd they used rivets instead of self- tapping screws. I lucked out and got one that didn't have the front bracket. Just ziptied the plate to the lower grill. Before car shows, I just cut the zipties.
This kinda looks like how mine is. I noticed on the back side of the bumper I have a crack in it originating from the rivet or whatever it is. Guess I'll be keeping my front plate on...
Related Threads
Mustang Evolution Forum
2.1M posts
50.8K members
Since 2003
