Staggered wheels question - Mustang Evolution
Old 08-05-2012, 11:52 AM   #1
fordfan100's Avatar
I am looking at putting a staggered whell setup on my car going with 18x9 up front and 18x10 in the rear. these come from American muscle already mounted and balanced but what concernes me is that the height of the 18x9 tire is 255/45 and the rear is 275/40 I am concerned because the stock tires are 245/50 will this cause any issues on the car
fordfan100 is offline   Reply With Quote
Old 08-05-2012, 12:33 PM   #2
Gil_T2's Avatar
Re: Staggered wheels question
Stock is not 245/50 it is a 235/50 if you are refuring to 18". The tires AM is putting on should be ( 255/45 & 285/40), they are the same Dia as stock GT500. The stock GT 235/50 is only .24" taller than the GT500 tires
BBK LT's, Catted Xpipe, Sniper tune, UDP's GT500 TB, Ford Racing CAI, CM delete, 4.10, TR6060, 1 piece DS
Gil_T2 is offline   Reply With Quote
Old 08-05-2012, 01:09 PM   #3
CYCLON37's Avatar
I have the same wheel and tire setup on mine from AM. 18x9/10 with 255/45 and 275/40. No problems. I'd recommend a drop though.
---------- Post added at 03:09 PM ---------- Previous post was at 03:05 PM ----------
Actually I'd recommend 19's. I'll be swapping to them. They look perfect. 20's are too big imo.
CYCLON37 is offline   Reply With Quote
Old 08-05-2012, 01:49 PM   #4
fordfan100's Avatar
I thought about 19s but don't you have to adjust something with a tuner for the bigger wheels?
Old 08-05-2012, 01:54 PM   #5
Gil_T2's Avatar
Regardless of the rim size the tire Dia should stay the same, unless you go over sized. No tune change is needed, you are limited with 19, and 20" as far as tires go.
Old 08-05-2012, 01:58 PM   #6
fordfan100's Avatar
Cool I did not know that however the wheels I want only come in 18 or 20 I might just go with a standard setup instead of staggered
Old 08-05-2012, 03:46 PM   #7
Sanguin's Avatar
There are tire calcs out there to compare two tire sizes. Punch in your stock tire size, then punch in the width/diameter of the tire needed for your rim, then play with the sidewall height. It will tell you what you need to be as close to stock mph readings as possible.
'13 'Stang V6 - MT82 - GHIG Ordered: 5/31 Pickup: 7/3
35% Tint, Homemade Intake (1, 2), GT500 Heat Extractor/Splash Guards, Custom Gas Cap
Barton Shifter Bracket, GHIG Shift Knob
'98 Grand Prix GTP - New Project for DD
Sanguin is offline   Reply With Quote
Old 08-05-2012, 03:50 PM   #8
pwrby4d's Avatar
Keep in mind (may not matter to you) but you will not be able to rotate your tires and also a car with the same tire width at all four corners will be more predictable and handle better on the street or road coarse. On a drag track you would want the big meats out back and smaller tires up front for weight transfer and traction on the rear wheels. It does look awesome with the rear tires wider too imo.
pwrby4d is offline   Reply With Quote
Old 08-05-2012, 04:42 PM   #9
fordfan100's Avatar
Yep that convinces me to get standards
Old 08-05-2012, 04:59 PM   #10
davidn7488's Avatar
You could always do 25mm hubcentric spacers for the back. I did that on mine because I wanted to keep my 19s that came with the performance package. Pretty much same effect as staggered plus you can still rotate them
davidn7488 is offline   Reply With Quote
Old 08-05-2012, 06:36 PM   #11
Cherry_Stang's Avatar
I keep seeing more and more options for 19"s. I'm looking at staggered 20"s for mine, just because I really dig the look.
2011 V6 6 speed. Cervini IV Hood, Xenon louvers, JLT CAI. More on the way.
Cherry_Stang is offline   Reply With Quote
Old 08-06-2012, 08:25 AM   #12
pwrby4d's Avatar
Also for some reason odd numbers like 17" and 19" tires have much hire prices vs. 18" and 20"... Why? Does anyone know?
Old 08-06-2012, 08:34 AM   #13
KATO's Avatar
Because of Odd/uncommon use. Most shops/stores do not have a large variety, if any variety of 19" wheels. Uncommon use equals uncommon prices.
Old 08-06-2012, 08:41 AM   #14
davidn7488's Avatar
The 18s and 20s sizes are more commonly found in other vehicles. Our wheel wells are much bigger than an average car so it takes a fatter tire to fill it. Most cars with 17s for example run 225/45/17 while ours run 225/60/17. Just not a common size. Same thing with the 19s.
Putting 20s on the mustang make it look really good but ride rooouuugggghhh. I have the factory 19s and eibach pro kit springs. I get a lot of compliments and how it sits. on rouch pavement it'll beat you up quite a bit. There's no way I would put 20s on it if its your daily driver.
Old 08-06-2012, 08:41 AM   #15
AmericanMuscle.com
Sponsor
AMDanBailer's Avatar
firdfan100,
Great choice I'm a huge fan of the staggered wheels, I love the look of the big tread out back! As far as fitments goes, you won't have any problems at all. We've test fit every possible package we offer on all of our 14 project cars, everywhere from 79 to 13' with no issues.
Let me know if you have any questions or need assistance.
- Dan
Old 08-06-2012, 02:19 PM   #16
pwrby4d's Avatar
makes sense. thanks!
---------- Post added at 03:18 PM ---------- Previous post was at 03:16 PM ----------
yeah 20's are a not enough tire in between the road and the rim. My last one had 18"s on it and I found that to be perfect.
---------- Post added at 03:19 PM ---------- Previous post was at 03:18 PM ----------
Old 07-07-2013, 02:24 AM   #17
Bonnie12V6's Avatar
I have a question. If I get a wider tire than stock, will that have any effect on the acceleration or pull of the vehicle. I would think with a heavier wheel and tire it would slow it down a bit.
Ryan
'Sally' 2014 Mustang GT 5.0, Black
Shelby GT500 Axleback, Res delete, Barton shift bracket.
United States Air Force
Bonnie12V6 is offline   Reply With Quote
Old 07-07-2013, 03:52 AM   #18
RocknCali's Avatar
wider tire = more ground surface = more friction = less MPG
RocknCali is offline   Reply With Quote
Old 07-07-2013, 04:03 AM   #19
Bonnie12V6's Avatar
Ok so MPG will drop. Acceleration? Vehicle working harder to pull larger tires.
Ryan
Old 07-07-2013, 08:03 AM   #20
dgrum04's Avatar
I upgraded to a AM staggered 19" set up about four months ago and I wouldn't go back. No issues with the odo, and the true staggered set up looks amazing.
I wouldn't worry about fitment, rotation, or anything else. It's worth it all.
2011 Kona Blue 3.7L. Stock motor. Roush Axle-Back. 19" x 8.5/10" Charcoal AMR's. GT500 Spoiler. Smoked Raxiom Tail Lights. MCA grille. Shorty antenna.
An outstanding DD
dgrum04 is offline   Reply With Quote
Old 07-07-2013, 08:32 AM   #21
curtin1991's Avatar
Send a message via ICQ to curtin1991
I didn't notice a difference in acceleration . If anything at the track a little more traction .
It did kill my MPG though ...
Corey
curtin1991 is offline   Reply With Quote
Old 07-07-2013, 09:49 AM   #22
RocknCali's Avatar
The tire size isn't THAT much larger. you're not slappin' on freight truck tires. Theres not much of a weight difference to be noticed
Old 07-07-2013, 09:54 AM   #23
Bonnie12V6's Avatar
Ok that was my concern. Thank you!
Ryan
12:12 PM
