which heats up faster? - Mustang Evolution
Old 08-14-2012, 01:10 PM   #1
alrefire's Avatar
so i've been looking into it, and apparently, a twin turbo setup would heat up alot faster than a s/c. is this true?
Old 08-14-2012, 01:25 PM   #2
The Blue Dragon
GrabberBlue5.0's Avatar
Depends on what kind of sc you're talking about, twin screw will heat up very hot very quickly, as does the turbo, so long as they're spooled, centri produces least heat
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 08-14-2012, 01:35 PM   #3
Sanguin's Avatar
Re: which heats up faster?
What does it matter? Both, if done right, have intercoolers.
'13 'Stang V6 - MT82 - GHIG Ordered: 5/31 Pickup: 7/3
35% Tint, Homemade Intake (1, 2), GT500 Heat Extractor/Splash Guards, Custom Gas Cap
Barton Shifter Bracket, GHIG Shift Knob
'98 Grand Prix GTP - New Project for DD
Sanguin is offline   Reply With Quote
Old 08-14-2012, 02:22 PM   #4
alrefire's Avatar
So, If done right I won't have to worry about the heat causing wiring problems?
Old 08-14-2012, 02:24 PM   #5
The Blue Dragon
Key words, if done right. Really I would worry more about heat soak and overheating than messing up wiring. As long as you're not laying wiring on hot components ( I'm talking a few hundred degrees, 300 plus) it would be fine anyways
Old 08-14-2012, 10:04 PM   #6
alrefire's Avatar
Is there anything I can do to he wires to make them more eat resistant?
Old 08-14-2012, 11:26 PM   #7
Sanguin's Avatar
All you're worrying about is wiring? Superchargers don't make anymore heat than the engine block. Turbos, especially twins, result in more exhaust routing in the engine bay that you have to worry about, but neither should pose a real threat unless the pipe bender/welder is retarded. Just route it away from the exhaust areas and put loom on it. Wiring is rather resilient.
Old 08-15-2012, 12:21 AM   #8
alrefire's Avatar
Okay
Thanks!!
I'm setting up my car now and I didn't want something as stupid as extra heat ruin the project ;p
12:04 AM
