3.73 gears - Mustang Evolution
Old 08-15-2012, 10:30 PM   #1
geepoons's Avatar
3.73 gears
Im thinking about putting in 3.73s in my car. I currently have 2.73s and was wondering how big of a difference it is . I have a tune so I'm set with that just wondering what installation would run me ?
geepoons is offline   Reply With Quote
Old 08-15-2012, 10:41 PM   #2
ColeJohnson's Avatar
Install can be anywhere from $250-$500 depending on how hard you look.
Going from 2.73 to 3.73 it'll feel like you got kicked in the ***. It's gonna feel like you added 100rwhp.
2016 Comp Orange GT (current)
Old 08-16-2012, 12:22 AM   #3
NicholasP's Avatar
What about 2.73-4.65?
NicholasP is offline   Reply With Quote
Old 08-16-2012, 02:34 AM   #4
fultonboy09's Avatar
Too much! You will come out of the gate fast but you will have a top speed of like 60! Lol
fultonboy09 is offline   Reply With Quote
Old 08-16-2012, 02:35 AM   #5
NicholasP's Avatar
Why is that? Haha
Old 08-16-2012, 03:16 AM   #6
Red Stallion 11's Avatar
What about 4.10's
Red Stallion 11 is offline   Reply With Quote
Old 08-16-2012, 03:20 AM   #7
Depends on what you want the car to do! If its just a drag strip monster then go with 410! But with our v6s 373 is a good place for our rpms to fall. I'll be getting 373 eventually and i like to road race and drift mine.
Old 08-16-2012, 04:02 AM   #8
alrefire's Avatar
After my driveshaft I'm getting 373 gears and LSD
Old 08-16-2012, 04:33 AM   #9
Re: 3.73 gears
Do you have any clearance issues with a one piece drive shaft,,Im dropping 1 1/2 also,,all the around
mymustang is offline   Reply With Quote
Old 08-16-2012, 09:03 AM   #10
Sanguin's Avatar
Re: 3.73 gears
Why do you want an LSD? These cars already have LSDs. They're not a torsen, but they work. If you have a locking diff, then you have a locking diff. It's not going to matter to 90% of the driving conditions you'd put it through.
'13 'Stang V6 - MT82 - GHIG Ordered: 5/31 Pickup: 7/3
35% Tint, Homemade Intake (1, 2), GT500 Heat Extractor/Splash Guards, Custom Gas Cap
Barton Shifter Bracket, GHIG Shift Knob
'98 Grand Prix GTP - New Project for DD
Sanguin is offline   Reply With Quote
Old 08-16-2012, 09:59 AM   #11
pwrby4d's Avatar
Re: 3.73 gears
Ya the Torsen, Eaton etc. are different designs and the weak link in the T lock is the S spring. The tabs usually tear off and well everthing comes apart then. But that said they are pretty strong and I have seen them only break on hard launches at the track and most of the time with slicks. As for road course I have yet to see someone break one but hard cornering does put stress on the rear end. Personally, If you arent going to track your car hard and frequently I think money would be better spent on having the axle tubes welded to stiffen them up and help keep them from bending or walking out and put the money into suspension upgrades to make the car handle better for the type of driving you will encounter on whichever form of racing you decide to participate in.
---------- Post added at 10:51 AM ---------- Previous post was at 10:34 AM ----------
My last one had the stock T lock in it with 430 gears (automatic), CHE axle bracing, Strange 10 Way adjustable drag shocks, Cobrajet drag springs, Steeda billet LCA's with the race bearings, FRPP girdle, J&M exteme adjustable UCA, and all the suspension bars by Steeda, Eibach, 1 DS etc. It was run at the track many times with street tires and slicks and it held up fine. This was way extreme for most and honestly drove like a drag car on the street. You will need to decide a good balance if you are going to drive the car on the street and the track. I built it for the 1/4 mile but it was not a good ride for the street.
If I had to do it all over I think I would have just welded the axle tubes and changed some of the suspension parts for the car to handle on the street better as it saw far more street use than it did 1/4 mile at a time on the track.
---------- Post added at 10:59 AM ---------- Previous post was at 10:51 AM ----------
Also, The trade off for more gear is that it will create more torque but uses horsepower to do that. So your torque numbers will go up but your whp will go down. Rotation mass such as flywheel, driveshaft, wheels, brake rotors if lightened using lighter or smaller diameter pieces will increase hp/trq and the car will rev up quicker as well. This is important if you are going to gear it as well because it could very well make first gear completely useless. So choose your setup as a whole before you decide to gear it. Tire width and height can play an integral roll (no pun intended) in getting the setup dialed in right for the track and the street when gearing a car.
pwrby4d is offline   Reply With Quote
Old 08-16-2012, 12:45 PM   #12
Originally Posted by Red Stallion 11
What about 4.10's
4.10s are amazing. Read the info in my signature.
Old 08-16-2012, 12:58 PM   #13
Lorraine's driver
ab_mach1's Avatar
+1 You won't even believe what you feeling.
Instagram: @ab_mach1
Old 08-16-2012, 03:20 PM   #14
It'll be like a Trojan commercial. But real.
Old 08-16-2012, 04:12 PM   #15
Lorraine's driver
ab_mach1's Avatar
Lmao!
Old 08-16-2012, 06:29 PM   #16
alrefire's Avatar
Re: 3.73 gears
well if you put it that way......
you saved me about 250 bucks. thanks
Old 08-17-2012, 05:03 PM   #17
ak_stang's Avatar
Region: Alaska
These cars already have limited slip diffs, why buy a new one?
ak_stang is offline   Reply With Quote
Old 08-17-2012, 06:24 PM   #18
Lorraine's driver
ab_mach1's Avatar
Do the 2011+ V6's have the 8.8 rear diff?
Old 08-17-2012, 06:59 PM   #19
CYCLON37's Avatar
Yes
CYCLON37 is offline   Reply With Quote
Old 08-17-2012, 07:52 PM   #20
Lorraine's driver
ab_mach1's Avatar
Originally Posted by CYCLON37
Yes
Thx! That saves a lot of mod money.
Old 08-19-2012, 07:24 PM   #21
alrefire's Avatar
Re: 3.73 gears
i heard the stock dif whines with the ford racing 3.73 gears
Old 08-19-2012, 07:41 PM   #22
Sanguin's Avatar
Re: 3.73 gears
No. No differential whines unless your installer did a bad job. All that is in a diff is ring, pinion, carrier, and bearings. You're replacing half the major components when you do a gear swap. If it whines when they're done, they didn't set the pinion depth correctly.
06:15 PM
