Plasti Dip Wheel Tip - Mustang Evolution
Old 08-21-2012, 02:12 AM   #1
Kandy's Avatar
Did my stock rims this weekend. Very happy with results. Make sure you clear the dip from the lug nut mating surface. I used a pick to rub along the top edge and then removed the dip.
Kandy is offline   Reply With Quote
Old 08-21-2012, 06:53 AM   #2
dgrum04's Avatar
Re: Plasti Dip Wheel Tip
It turned out great, nice job! How did the process go? Pretty smooth?
2011 Kona Blue 3.7L. Stock motor. Roush Axle-Back. 19" x 8.5/10" Charcoal AMR's. GT500 Spoiler. Smoked Raxiom Tail Lights. MCA grille. Shorty antenna.
An outstanding DD
dgrum04 is offline   Reply With Quote
Old 08-21-2012, 07:49 AM   #3
probably best if you take the rims off and do it vs doing it on the car
Old 08-21-2012, 08:09 AM   #4
Kandy's Avatar
Wheels where removed. When I put the wheels back on the lug nuts grabbed the dip on the mating surface and started to pull the dip from the socket. I used a razor knife to cut the lug nuts loose and repaired the dip. When I did the second side I removed the dip and install was very simple. One other thing I did was keep a rag handy and every couple of sprays I would wipe the tip off to stop it from clogging up.
Old 08-21-2012, 10:57 AM   #5
pwrby4d's Avatar
look great. nice job.
pwrby4d is offline   Reply With Quote
Old 08-21-2012, 10:31 PM   #6
geepoons's Avatar
Dont do the dip on a hot day . If its too hot out the dip will dry too fast and it leaves a flakey finish on the wheels , not a good look : (
geepoons is offline   Reply With Quote
06:07 PM
