Tail lights - Mustang Evolution
Old 09-11-2012, 08:08 PM   #1
Whitelightning's Avatar
Tail lights
How do I take these little suckers out so I can paint them like 2013s? I took out the back carpet and kinda the plastic piece, now what?
Old 09-11-2012, 08:17 PM   #2
CYCLON37's Avatar
When you take out that platic piece or enough of at least, you should see some screws right behind the taillights. Unsrew them and it comes out easy. The hard part is removing the bulbs w/o breaking them (which I broke one..) You have to twist them to a point and they should pull right out. If you're pulling on it and it's not coming out then you gotta twist it more, so don't pull too hard.
CYCLON37 is offline   Reply With Quote
Old 09-11-2012, 08:28 PM   #3
What's the little rubber thing go to? It's right behind the carpet plastic thing. I didn't want to damage it. And where could I get replacement bulbs in the event I break one?
Old 09-11-2012, 08:39 PM   #4
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Re: Tail lights
These should help.
http://1.cdn.lib.americanmuscle.com/...146-2-cust.pdf
http://1.cdn.lib.americanmuscle.com/...taillights.pdf
2012 Kona Blue 3.7L V6:
Old 09-11-2012, 08:41 PM   #5
CYCLON37's Avatar
Yep, good links^^ And a new bulb from ford will run you around $75.
Old 09-11-2012, 08:57 PM   #6
A piece or set.... I was going to put plasti dip on my tail lights for $6. I wasn't expecting to pay almost $80 worst case scenario
Old 09-11-2012, 09:10 PM   #7
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Re: Tail lights
My suggestion, if you're scared of damaging a bulb, is to disconnect the harness and gently push the harness' rubber gromet through the opening it's mounted to so that you don't have to remove the bulbs from the housing. One of my links mentions doing this I think.
Old 09-11-2012, 09:53 PM   #8
It did. I'm going to to either man up and take them out to paint the squares on or just use newspaper around the deck lid and spray close. $75 for a bulb is hella steep.
Old 09-12-2012, 12:38 PM   #9
formulaDstang's Avatar
Just leave them on and plasti dip them or use a vinyl that doesn't bleed threw. I did mine about a month ago I plasti diped 5 layers so it doesn't show threw then I put smoked lense tint over it and put my bezles back on.
formulaDstang is offline   Reply With Quote
Old 09-12-2012, 01:35 PM   #10
How bad is the overspray, on a white car I might add. I'm putting squares in them but maybe 3 coats to resemble the 2013 lights. It's my first time with plasti dip too
Old 09-12-2012, 02:41 PM   #11
Since its plastidip overspray isnt a issue just peel or rub it off with your hand. As for the stencil as soon as your done spraying the last layer peel the stencil off before it dries or it will stick. Key tips are to spray evenly after every layer have someone step on the brakes until it doesn't show
Old 09-12-2012, 05:52 PM   #12
CYCLON37's Avatar
Should do the vinyl like formulaDstang. Looks better then the plasti-dip imo.
Old 09-12-2012, 07:03 PM   #13
First attempt. Not so well once the night came. But I have a feel for plasti dip. My gf loved peeling it off lol
ID:	68339   Click image for larger version
Old 09-12-2012, 07:24 PM   #14
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Re: Tail lights
Looks like you're getting the hang of things. I'd try to use formulaDstang's image as a template for the shape of the blackouts.
Old 09-12-2012, 07:46 PM   #15
alrefire's Avatar
Re: Tail lights
ebay. you can get a pair of replacement lights (pretty much take offs) for about 25 bucks
Old 09-12-2012, 09:26 PM   #16
That's the plan now lol if I can't get the 2013 look I'll just have a halo looking tail lights which I ant complain would look nice
03:49 PM
