09-17-2012, 08:46 PM
#1 | | Registered User
| GT500 Style Strut Mount
Does anyone have the GT500 Style Strut Mount on their car does it make a big difference i need to upgrade my front struts
Borla catback s-type Borla Long tube off road x pipe
Jlt carbon fiber intake / BBk TB
J&M panhard bar J&M extreme lower control arm /relo
koni STR.T RTR wheels NT555
DSS Aluminum 3.5/3.73 gears https://www.youtube.com/watch?v=1cm4Di-zmZA |
09-17-2012, 09:08 PM
#2 | | Registered User
| Re: GT500 Style Strut Mount
If you're upgrading front struts I highly suggest you get the gt500 mounts, even if you weren't upgrading struts, I'd still suggest a gt500 upgrade. The stock ones are cheap, like the base speakers in these cars.. Makes all the difference.
09-17-2012, 09:45 PM
#3 | | Registered User
| Quote: |
Originally Posted by w4fang22 If you're upgrading front struts I highly suggest you get the gt500 mounts, even if you weren't upgrading struts, I'd still suggest a gt500 upgrade. The stock ones are cheap, like the base speakers in these cars.. Makes all the difference. | Where can I get a good price on them I swear AM had it for 85 now they went up I don't want to pay 110 when im getting the struts for 110 each
09-19-2012, 10:38 AM
#4 | | Registered User
They are worth every penny! I just installed them along with Eibach Sportline springs and the Pro-Damper kit. The stock strut mounts are so cheap and puny compared to the GT500 mounts. cjponyparts has them for $98. Here's a pic off of AM to show how stock (right) compares to the GT500 mounts (left)
2012 Kona Blue V6 Premium: Pony Package, Pype Bomb Axle-back, Airaid CAI, MMD Rear decklid panel, Staggered Black '10 GT500 style Wheels, Nitto NT555s, Stack Racing STB, Eibach Sportline Springs, Eibach Pro-Damper shocks/struts, J&M Adjustable Panhard Rod, Whiteline rear LCA relocation brackets
09-19-2012, 06:57 PM
#5 | | Registered User
Why didn't you put the Struts and Springs from the V6 Performance Package?
09-20-2012, 06:18 PM
#6 | | Registered User
Because I bought the whole Eibach Sportline kit which came with the springs, shocks, struts, and sway bars
09-20-2012, 08:16 PM
#7 | | Registered User
| Quote: |
Originally Posted by Florida3.7L They are worth every penny! I just installed them along with Eibach Sportline springs and the Pro-Damper kit. The stock strut mounts are so cheap and puny compared to the GT500 mounts. cjponyparts has them for $98. Here's a pic off of AM to show how stock (right) compares to the GT500 mounts (left) | I heard that the GT500 strut mounts didn't mount with the eibach damper kit? I might have gotten them if I knew that.
09-20-2012, 11:39 PM
#8 | | Registered User
| Re: GT500 Style Strut Mount Quote:
Originally Posted by CYCLON37 I heard that the GT500 strut mounts didn't mount with the eibach damper kit? I might have gotten them if I knew that. | That's what I thought at first too because most sites say that to use them, Ford Racing lowering springs and struts are required. Then I found reviews where people had all kinds of different setups like Eibach, Tokico, Koni, and Roush, all with the GT500 style strut mounts. If I had to guess, all that's really needed is some sort of lowering spring/strut combo because these mounts are a bit beefier compared to the stock mounts and wouldn't allow enough of the top nut to be threaded onto the struts.
09-24-2012, 09:35 PM
#9 | | Registered User
So here's a quick correction. The reason that worked with my Eibach set-up is because I was sent the '05-'10 style dampers rather than the '11+ that I had ordered. Physically the two look identical except that the silver portion of the strut is slightly narrower on the '05-'10 dampers. Since they're already installed on the car and I'm happy with them, I'm just gonna keep things the way they are. The difference in cost between the two is small enough that I don't feel the need to make any angry phone calls. Although I might anyway just to give them a heads up in case I'm not the only one this has happened to. Sorry about the confusion guys lol.
09-27-2012, 01:29 PM
#10 | | Registered User
Ahhhh, I see
10-09-2012, 11:19 AM
#11 | | Registered User
So i received my gt500 strut mount and is the bottom suppose to spin on them?
10-09-2012, 08:54 PM
#12 | | Registered User
Yes, that allows the strut assembly to rotate with the wheel/hub
10-09-2012, 11:15 PM
#13 | | Registered User
| Quote:
Originally Posted by Florida3.7L Yes, that allows the strut assembly to rotate with the wheel/hub | ok cool because one of them weren't moving then i twisted it then it popped
