high flow catalytic converter - Mustang Evolution
Old 09-20-2012, 02:16 PM   #1
Flashjmg's Avatar
Has anyone here looked into changing out the stock catalytic converter on the 2013s? I saw a thread on the 2010, and they said it was pretty restrictive. looked up in AM and didn't see anything through a quick search.
Flashjmg is offline   Reply With Quote
Old 09-20-2012, 03:12 PM   #2
Schram1's Avatar
Re: high flow catalytic converter
just go off road x pipe it will be fine
Borla catback s-type Borla Long tube off road x pipe
Jlt carbon fiber intake / BBk TB
J&M panhard bar J&M extreme lower control arm /relo
koni STR.T RTR wheels NT555/ Shelby Baer 6P
DSS Aluminum 3.5/3.73 gears
https://www.youtube.com/watch?v=1cm4Di-zmZA
Schram1 is offline   Reply With Quote
Old 09-21-2012, 02:22 PM   #3
pwrby4d's Avatar
Ya the thing is you would have to cut the factory ones out and then get a set of Hi flows and have them welded in and it would not really be that less restrictive for the cost of it all.
You could easily just swap back your catted pipe when you need to go through inspection too or if it is too loud for you.
pwrby4d is offline   Reply With Quote
Old 09-27-2012, 12:53 AM   #4
Flashjmg's Avatar
How's the catback magma flow streets catback w and without a cat? MAy not b worth the hassle.
» Members Mustangs
Candy
OneBad3.7
007Stang
prm
Add your Mustang
02:34 PM
