White smoke coming out exhaust - Mustang Evolution
Old 09-22-2012, 06:14 PM   #1
I have a 2012 mustang v6 and i took it to an abandoned airstrip and made about 10 really hard passes and a couple donuts. Right after i had white smoke coming out my exhaust. I checked the temperature before I shut it off and it was normal. The smoke stopped after a few minutes of just sitting there, but I'm just wondering if I broke anything because this is my only car.
greg70056 is offline   Reply With Quote
Old 09-22-2012, 06:17 PM   #2
pwrby4d's Avatar
Re: White smoke coming out exhaust
Did/does the exhaust smell sweet like coolant? Could have cracked a head or have a gasket that has a slow blow. Check the oil for coolant. Pull the plugs and see what they look and smell like.
pwrby4d is offline   Reply With Quote
Old 09-22-2012, 06:24 PM   #3
im not exactly sure what coolant smells like. it didnt smell very sweet, it was more of a burn smell
Old 09-22-2012, 06:31 PM   #4
pwrby4d's Avatar
might have just been some oil burning but that would have a bluish look to it. When your car cools open up the radiator cap and smell the coolant. Wait until it is completely cool otherwise it could burn you or spit out. It will smell the same as if it were being burned through the exhaust.
Old 09-22-2012, 06:40 PM   #5
ok thanks, you don think i broke anything?
Old 09-22-2012, 08:00 PM   #6
pwrby4d's Avatar
well.. no.... you said it stopped and I would jsut check the oil and see if you need to add any and look to make sure it is clean... but keep an eye on it over the next few weeks and see if the temps go up, loss of power, smoke, funny smell. You probably got some oil to blow past and it burned.
Old 09-22-2012, 08:49 PM   #7
Sanguin's Avatar
What pwrby4d is talking about is our pcv valve system, which keeps crankcase gasses from building up, has a tendency to allow oil to get sucked out of the valve cover and into the intake. This is especially true when you're pushing it hard.
'13 'Stang V6 - MT82 - GHIG Ordered: 5/31 Pickup: 7/3
35% Tint, Homemade Intake (1, 2), GT500 Heat Extractor/Splash Guards, Custom Gas Cap
Barton Shifter Bracket, GHIG Shift Knob
'98 Grand Prix GTP - New Project for DD
Sanguin is offline   Reply With Quote
Old 09-23-2012, 09:48 AM   #8
ok. thanks for the help. i won't be going back to that airstrip anytime soon
Old 09-23-2012, 05:44 PM   #9
Abominable Mustang
WhoDat's Avatar
Region: Alaska
So wouldn't an oil catch can help a lot with that issue? I know that AM sells some for our 3.7s.
2012 Kona Blue 3.7L V6:
Old 09-24-2012, 11:17 AM   #10
pwrby4d's Avatar
Yeah it will help. I run one. They work great. You can make one too on the cheap with a few parts from HD or Lowes.
---------- Post added at 12:17 PM ---------- Previous post was at 12:13 PM ----------
500 miles on car. I recommend you do this ASAP if you haven't yet
Old 12-16-2012, 07:27 PM   #11
Scream's Avatar
Don't wanna make a new thread but I haven't got on my car that bad I have an 02 GT and at idle I have white smoke coming out and smells like burning gas well like normal exhaust any ideas?
Scream is offline   Reply With Quote
Old 12-16-2012, 08:01 PM   #12
Aruiz42's Avatar
Is this when you first start up your car? Is it colder now (weather)?
If so mine does the same thing and i believe you only see the smoke now because of the cold and the smell of gas might just be the car running a higher idle to get warmed up in this colder weather. Thats the way i was explained it ayways!
Aruiz42 is offline   Reply With Quote
Old 12-16-2012, 08:40 PM   #13
Sanguin's Avatar
Colder weather will result in condensation and slightly more fuel being burned until the car has reached operating temp to come out the pipes.
If the smoke isn't black and it doesn't smell sweet (coolant), you're fine.
Old 12-17-2012, 05:20 AM   #14
bucko's Avatar
White smoke usually indicates coolant is getting into the cylinders and is getting burned with the fuel. In the old days, you could wait until the engine cools, remove the radiator cap, start the engine and look for bubbles, indicating cumbustion is getting into the cooling system (blown or leaking head gasket) and coolant is getting into the exhaust. One or more of the spark plugs would be squeaky clean, indicating where the head gasket was blown (which cylinder).
Remove the oil dipstick and see if the oil is brown or black. This will be good for you. If the oil on the dipstick is white or creamy looking, you have a head gasket failure.
Oil burning is usually bluish to grey in color.
Old 12-17-2012, 05:53 AM   #15
Scream's Avatar
Sweet thanks
Old 12-17-2012, 09:10 AM   #16
condensation could also be the cause (super hot cats might make it worse)
Old 12-20-2012, 06:55 PM   #17
Mustangs's Avatar
You didn't fall for this did you?
Haha
Mustangs is offline   Reply With Quote
Old 12-20-2012, 10:21 PM   #18
curtin1991's Avatar
Send a message via ICQ to curtin1991
Haha
Made me laugh .
Corey
curtin1991 is offline   Reply With Quote
Old 12-21-2012, 05:57 AM   #19
Scream's Avatar
Lol I ain't that stupid -.-
Old 12-21-2012, 07:35 AM   #20
Mustang Rider's Avatar
Oh man. I would feel really sorry for anyone who did that.
Mustang Rider is offline   Reply With Quote
Old 12-21-2012, 10:51 PM   #21
Sanguin's Avatar
Well... I bet he doesn't have moisture in his tank anymore.
Old 12-22-2012, 01:54 PM   #22
Whitelightning's Avatar
Silly Honda. Push yourself home. But would sea foam do anything in the gas tank though as far as say, ethanol being converted into water
Old 12-22-2012, 02:22 PM   #23
Charlie_santos's Avatar
I heard sea foam is only good for like when you take ur intake manifold off and want to clean the oil
Old 12-22-2012, 08:54 PM   #24
curtin1991's Avatar
I've used sea foam on everything but cars. But it's like a mechanic in a can . Never seen anything like it. Made my four wheeler run like new .
Corey
Old 12-22-2012, 10:19 PM   #25
So you put it in the car? Lol I've never heard of such a thing
Old 12-22-2012, 10:21 PM   #26
curtin1991's Avatar
Never seen a need the car is new and runs like a champ . 😄
Corey
Old 12-22-2012, 10:44 PM   #27
Never seen a need the car is new and runs like a champ . dde04
Oh yea I know it's still new. But you can put it in the car ?
Old 12-22-2012, 10:45 PM   #28
curtin1991's Avatar
Yeah boats too
Corey
exhaust
06:22 AM
