cabin exhaust smell. - Mustang Evolution
Old 09-24-2012, 03:53 PM   #1
MrMike's Avatar
Hello everyone, ever follow a car after they open it up and you get that smelly rotten egg smell? Well i notice when i sometimes open my 3.7 up i can smell it in the cabin? Ive read other forums with different cars, not fords, and say that it sometimes happens. What causes this? The sound tubes maybe?
MrMike is offline   Reply With Quote
Old 09-24-2012, 03:56 PM   #2
Rm360's Avatar
I know of two things that cause this smell , bad cats , or a dirty cabin air filter , if you don't have any codes I would start by changing the filter
Old 09-24-2012, 03:58 PM   #3
MrMike's Avatar
Really? Its a 2013 three months old!
Old 09-24-2012, 04:06 PM   #4
Rm360's Avatar
Do you smell the smell all the time or do you smell it when your using the AC or heat ?
Old 09-24-2012, 04:11 PM   #5
Blogger
99ford's Avatar
No your issue is something else.
Has this been going since you bought it?
Old 09-24-2012, 04:13 PM   #6
MrMike's Avatar
Sorry, Only at 6000 rpm, when i really push it.
---------- Post added at 06:13 PM ---------- Previous post was at 06:11 PM ----------
Never smell it under normal use. Ac, heater, etc.
Old 09-24-2012, 04:35 PM   #7
MrMike's Avatar
Is this a normal thing? Or should i be making a trip to the dealer?
Old 09-24-2012, 05:55 PM   #8
Rm360's Avatar
I did a little reading and it seems sometimes gas has to much sulfer in it as an additive, the engine doesn't burn it completely and the cat stores and then releases as hydrogen sulfide when you add enough load to the engine and force more air through the exhaust, a quick thing to try is buying gas from a different station and see if it stops, if not then the cat may be defective and you should take it to the dealer.
Old 09-24-2012, 08:13 PM   #9
NickAP12589's Avatar
Do you notice any sound difference when your up in the 6k's? Could be a bad exhaust manifold gasket. When you get those RPM's up there, theres a lot more pressure pushing out on that manifold and if the gasket is bad or the bolts aren't tight enough there could be a leak. Obviously if it's either of those, a new gasket is needed as gaskets are not reusable.
NickAP12589 is offline   Reply With Quote
Old 09-24-2012, 08:45 PM   #10
MrMike's Avatar
Thx ill try different gas, i usually go to shell but ill try something else. I have to gas up tomorrow so ill keep you posted!
---------- Post added at 10:45 PM ---------- Previous post was at 10:43 PM ----------
The sound is good, not any louder than the norm would be, but ill also keep a close eye on it tomorrow! Thx guys and ill keep you posted.
Old 09-24-2012, 09:10 PM   #11
Schram1's Avatar
It's the smell of victory my car smells like pure gas
Borla catback s-type Borla Long tube off road x pipe
Jlt carbon fiber intake / BBk TB
J&M panhard bar J&M extreme lower control arm /relo
koni STR.T RTR wheels NT555/ Shelby Baer 6P
DSS Aluminum 3.5/3.73 gears
https://www.youtube.com/watch?v=1cm4Di-zmZA
Schram1 is offline   Reply With Quote
Old 09-25-2012, 05:55 AM   #12
Blogger
99ford's Avatar
^ yeah that makes the most sense to me
Old 09-25-2012, 11:57 AM   #13
MrMike's Avatar
Different gas this morning, ran it hard till 6000 in third and got that smell again. Any ideas? Some people say its normal when you drive it hard.
Old 09-25-2012, 12:09 PM   #14
It's not me, it's you.
primer2tone's Avatar
Are you sure you're smelling carbon? When my '11 GT was new I used to get this smell, it was almost like carbon but had a plastic burning after smell. It only happened when I would go WOT and after about 15K miles the smell has gone away. I've got 32k on it now and still rip the throttle every chance I get and no smell.
Old 09-25-2012, 12:26 PM   #15
MrMike's Avatar
Im not sure its a carbon smell, the best way i can describe it is when the car in front of you pushes his car and you can smell his almost like burning hair from a hairdryer smell or rotten egg exhaust smell. Sometimes when i get out of the car in the garage i smell a faint plasticy or rubbery smell. The car has 5300km on it now.just started pushing it in the last 2000k...was getting used to clutch, and allowed a good 2500km for the break in. Engine sounds good pulling at high rpm, i just get that smell that normally the guy behide me should get. Lol
Old 09-25-2012, 12:29 PM   #16
It's fine man. Just check your fluids and periodically check under to hood for anything that might be out of place.
Old 09-25-2012, 12:33 PM   #17
MrMike's Avatar
O.k thanks, I'll be sure to keep an eye on them.
Old 09-25-2012, 11:30 PM   #18
Old 09-27-2012, 09:20 PM   #19
NicholasP's Avatar
Trust me did the same thing with my car I think it might be the exhaust breaking in mine went away
NicholasP is offline   Reply With Quote
Old 09-27-2012, 09:34 PM   #20
Blogger
99ford's Avatar
When did you finally notice it was gone?
Old 09-28-2012, 03:46 PM   #21
MrMike's Avatar
So how long did it take to go away?
Old 09-30-2012, 04:45 PM   #22
NicholasP's Avatar
I mean I honestly don't remember when but I do remember it gradually going away to where it would only happend if I really was booking it
Old 10-01-2012, 05:32 AM   #23
MrMike's Avatar
O.k thanks. I hope its sooner than later.
Old 10-01-2012, 07:40 AM   #24
wheelman's Avatar
Same here, no issue
wheelman is offline   Reply With Quote
exhaust
07:56 PM
