First N/A 2011 v6 in the 12's!!! - Mustang Evolution
Old 09-28-2012, 09:37 AM   #1
silvrbullet2012's Avatar
This popped up on my Facebook and wow. Just bolt ons. Not even a procharger. I'm very impressed.
silvrbullet2012 is offline   Reply With Quote
Old 09-28-2012, 09:40 AM   #2
Sanguin's Avatar
Yep, happened a couple days ago. All he's running is full exhaust, tune, slicks, aluminum driveshaft, and spec 1 clutch (stock flywheel it seems). Very impressive.
'13 'Stang V6 - MT82 - GHIG Ordered: 5/31 Pickup: 7/3
35% Tint, Homemade Intake (1, 2), GT500 Heat Extractor/Splash Guards, Custom Gas Cap
Barton Shifter Bracket, GHIG Shift Knob
'98 Grand Prix GTP - New Project for DD
Sanguin is offline   Reply With Quote
Old 09-28-2012, 09:53 AM   #3
I'm already halfway there with my exhaust.
Old 09-28-2012, 11:58 AM   #4
pwrby4d's Avatar
Awesome. Very impressive considering what little mods are done.
pwrby4d is offline   Reply With Quote
Old 09-28-2012, 01:41 PM   #5
BlackedStang's Avatar
Wow that is very impressive. The new 3.7 is a sweet engine.
2012 V6 Performance Package
BlackedStang is offline   Reply With Quote
Old 09-28-2012, 04:06 PM   #6
I run 13.04/.06 with radials....I don't know what the spray did, it hasn't been tracked since adding it. I will say that it outran a 12.70ish Lightning from a 20mph roll
Grabber Blue "Betty" 2012 V6 Six Speed, 3.55, BBK cai/throttle body, longtubes, x-pipe, axle back w/oem tips, Lugo Performance Dynotune, Zex 100 dry. I need factory v6 foglight housings, and the stock 11/12 gt grill with the light housings.
WtFDiesel is offline   Reply With Quote
Old 09-29-2012, 09:44 AM   #7
We went to the track last night...I did not take Betty, but rode with some one else. However, I saw 3 different v6 11-12 mustangs run the same 13 flat passes. Two were 6speeds, they were modded for sure. One was modded similar to mine, with the exceptions that he did not have the, spray, throttle body or the dyno tune, he was on a canned tune. With drag radials, he made a 13.12 pass at best. The other six speed did some really nice 12.99's with cai, cat back, can tune, drag radials and a 100hp dry shot. The auto trans guy did some 13.1x passes, he was cai, header back, 3.73 rear, throttle body, bama tune, 75 shot and stock rims and tires. That was what made me talk to him. He had little traction through 2nd gear. I had a blast!! I also got to see a turbo '11 5.0 run some nice tens with a conservative tune, stock suspension, drag radials, 6speed, 3.31 gears, cai, through a STOCK AXLE BACK!!!! It was actually quieter than a stock five oh, simply because of the exhaust being routed through the turbo, then the depth of the x pipe, then stock mufflers and tips. This car would be mistaken for stock if not for the drag radials being on it. With the radials and the clutch he had great launches, great 60 footers, and consistent (for the four runs I saw) 10.2x times. I think that was also at ten pounds of boost and with the necessary mods just to get the turbo on. Other than that, the car was stock. So nasty. I was as much amused by the younger ricer crowd that was hating on him. The guy (Mark Reynolds) in the 5.0 was in his 50,s and was just playing around with his DD!!
2011 v6
02:00 PM
