Clutch ...? - Mustang Evolution
Old 10-22-2012, 09:57 AM   #1
curtin1991's Avatar
Send a message via ICQ to curtin1991
Clutch ...?
Let the wife drive my car for a week or so got back in and it seems to shift rough when going in to the next gear . Is that the clutch going out? It didn't shift that bAd prior. I have to really try to work the clutch to make it shift as smooth as it did. If it is the clutch how much $ to replace one
Corey
curtin1991 is offline   Reply With Quote
Old 10-22-2012, 12:07 PM   #2
BlackedStang's Avatar
Does she know how to properly drive a stick? Your clutch should last a long time so I highly doubt your clutch is going out.
2012 V6 Performance Package
BlackedStang is offline   Reply With Quote
Old 10-22-2012, 12:11 PM   #3
curtin1991's Avatar
Corey
Old 10-22-2012, 12:24 PM   #4
curtin1991's Avatar
Corey
Old 10-22-2012, 12:29 PM   #5
curtin1991's Avatar
No , not well at all .
When she got home the other night there was a burnt smell . I didn't see anything under the hood melted or any of the above . When I got in in to drive it next I only felt it in first on slow take offs but it feels like the clutch it skipping or not grabbing . Not sure if that is a good way to explain it.
if I take off quicker it's not really that noticeable.
Not sure what it is just bothers me bc something is not rite .
Corey
Old 10-22-2012, 12:57 PM   #6
pwrby4d's Avatar
Sounds like she glazed it pretty good. How many miles on it? Price depends on if you are going to go with the Dual Mass Flywheel style clutch that is in it now ($$$) or convert it to a conventional clutch which IMO is better. Also depends on how much performance you want out of the clutch.
pwrby4d is offline   Reply With Quote
Old 10-22-2012, 01:03 PM   #7
curtin1991's Avatar
I don't really need a performance clutch just somthing to fix it lol.
I wonder how much labor will be ...
It's got 20,000 miles on it also
Corey
Old 10-22-2012, 01:14 PM   #8
pwrby4d's Avatar
The factory DMF clutch is probably close to $600 just in parts from Ford.. Just a guess.. The aftermarket is probably gonna run a little more than half of that. Figure 3 to 4 hours labor at $70 to $90 an hour. Aftermarket will eliminate the dual mass flywheel style clutch in it and it will perform better. If you want something high performance for High HP than the aftermarket will cost closer to the OEM pricing.
---------- Post added at 02:10 PM ---------- Previous post was at 02:08 PM ----------
You will have to replace the flywheel too with the aftermarket set up which will add to the cost however.
---------- Post added at 02:13 PM ---------- Previous post was at 02:10 PM ----------
You are probably looking at close to a grand either way unless you are doing it yourself which will probably save you 3 to 4 hundred...
---------- Post added at 02:14 PM ---------- Previous post was at 02:13 PM ----------
I would bring it to Ford and let them diagnose it. Maybe something failed under warranty...
Old 10-22-2012, 01:23 PM   #9
curtin1991's Avatar
It would be nice if it was somthing under warranty just don't think I'll be that lucky .
Also how long can I drive it with hot spots or glazed . Don't exactly have a grand . Lol
Thanks for the help
Corey
Old 10-22-2012, 01:51 PM   #10
pwrby4d's Avatar
You might even be able to drive it easy and get it feeling good again... Depends on how you drive. Dont beat on it. It might start grabbing again. Might not be glazed at all. Might be the DMF or something wrong. Bring it in anyway. Take a mechanic for a drive.
Old 10-22-2012, 02:10 PM   #11
curtin1991's Avatar
I'll give that a try . Thanks for all the help man
Corey
Old 10-23-2012, 04:15 PM   #12
curtin1991's Avatar
The problem went away after driving a bit. Thanks man
Corey
Old 10-23-2012, 04:41 PM   #13
Sanguin's Avatar
It also wouldn't be the first vehicle to have a slave cylinder go out. Anyone else having problems in the future should always have the dealer take a look if it's under warranty.
'13 'Stang V6 - MT82 - GHIG Ordered: 5/31 Pickup: 7/3
35% Tint, Homemade Intake (1, 2), GT500 Heat Extractor/Splash Guards, Custom Gas Cap
Barton Shifter Bracket, GHIG Shift Knob
'98 Grand Prix GTP - New Project for DD
Sanguin is offline   Reply With Quote
Old 10-23-2012, 04:51 PM   #14
Dub9stang's Avatar
70 to 90 an hour? You talking about the 80s or now!? Lol
Dub9stang is offline   Reply With Quote
Old 10-23-2012, 05:25 PM   #15
pwrby4d's Avatar
I havent brought a car to a mechanic other than warranty work or a collision in a looooong time. lol. I do my own work. lol
---------- Post added at 06:25 PM ---------- Previous post was at 06:21 PM ----------
I have been having some issues with my car popping out of gear. very random. 2 times in 2100 miles. It happened with the stock shifter so I put in a SVE/JHR shifter that was in a friends car that he traded his car in and took out. I gotta say the SVE shifter... NO Bueno. At first I loved it but after a while I realized how notchy it was. That was the reason he got rid of it and also because he said when he had it in it grinded in reverse every once in a while. Anyway, It also popped out with the SVE in there within 100 miles so I pulled it out and went back to the stock shifter. I dug how the SVE/JHR/UPR shifter put the shifter up and back a little but it is so notchy, it isn't for me. Already have built cars that drove hard and I dont want this one to be that way.
I have the barton shift bracket in there still. I would not waste money the JHR shifter.
Old 10-23-2012, 05:40 PM   #16
pwrby4d's Avatar
Awesome.
Old 10-24-2012, 02:06 PM   #17
Flashjmg's Avatar
I feel like i can't really get it going from nuetral to first to second..takes me forever. if i do it too fast, it's all jerky. suggestions? I know it comes with feel, but I feel for me to make it smoothe it takes forever!! anyone else have this problem, or am i just a newb man tranny driver. haha tranny.
Flashjmg is offline   Reply With Quote
Old 10-24-2012, 03:19 PM   #18
pwrby4d's Avatar
You will get better at it. Come off the clutch a little slower and dont mash the gas so hard.
Old 10-24-2012, 11:58 PM   #19
Sanguin's Avatar
I've also found this car is slow to drop revs when disengaging the clutch. I can be smoother if I shift slower because it gives the engine a chance to drop revs to match the next gear. Annoys the heck out of me because I prefer to shift a bit faster, but the car likes "slow and lazy." I don't know if it's the factory tune or DMF causing rpms to hold for so long.
Old 10-25-2012, 09:16 AM   #20
Flashjmg's Avatar
is that because of that duel mass fly wheel? idk. i'm getting beat by people that aren't even trying to race me off the line. lol. maybe the tune will help, but i'm gonna first put on the CAI and exhaust and see how i feel before the tune.
Old 10-25-2012, 10:31 AM   #21
curtin1991's Avatar
+1 lol
Corey
Old 10-25-2012, 01:18 PM   #22
pwrby4d's Avatar
Great point Sanguin. I agree. DMF is the cause.
Old 10-25-2012, 03:48 PM   #23
MrMike's Avatar
Yeah I notice it to, drives me crazy! I have the stock gears, does it still happen with 3.73's? If it does, and it is the dmf, I be replacing that! Any suggestions?
MrMike is offline   Reply With Quote
Old 10-26-2012, 02:38 PM   #24
rebeltx's Avatar
I noticed the same on my automatic when I rev in neutral. So I would say it's a tune thing since auto's dont have the DMF.
rebeltx is offline   Reply With Quote
Old 10-27-2012, 09:27 AM   #25
pwrby4d's Avatar
With an auto it is computer controlled to rev match. That said if you are going 60 on the highway and put it in neutral you will see the revs hang. They wont fall off much. That is the computer rev matching so that when you put it into gear again you dont do a neutral drop.
07:39 PM
