2013 V6 top speed limited? - Mustang Evolution
Closed Thread
Old 11-12-2012, 07:08 PM   #1
mrkrabz's Avatar
I read that the top speed of the 13' v6 is 113mph, and that it can do more but Ford has it governed, is this true? WHY FORD WHY?
mrkrabz is offline
Old 11-12-2012, 07:19 PM   #2
NicholasP's Avatar
The drive shaft will blow up as well as the tires
NicholasP is offline
Old 11-12-2012, 07:33 PM   #3
BlackedStang's Avatar
The driveshaft part is true. Only the stock 17" tires would have problems above that speed. Others would be fine. Get a aluminum driveshaft+tune and I am sure you could get 140+.
2012 V6 Performance Package
BlackedStang is offline
Old 11-12-2012, 07:36 PM   #4
Charlie_santos's Avatar
Drive shaft fails at 136mph. The stock limit on my car was 120 I raised it to 125.
Charlie_santos is offline
Old 11-12-2012, 07:43 PM   #5
my advice is get an tuner to remove the speed governor and get an aluminum driveshaft from AM. you should be good to go on a track of course lol
winkawak is offline
Old 11-12-2012, 07:50 PM   #6
Yea once u get the drive shaft you can remove the speed limiter entirely
Old 11-13-2012, 12:02 AM   #7
mrkrabz's Avatar
So I found a aluminum drive shaft on AM for about $600, getting that would fix the speed issues? (I have v6 performance pack) What do you think my new top speed would be? It also states that the drive shaft would improve acceleration, which is a plus.
mrkrabz is offline
Old 11-13-2012, 12:07 AM   #8
Ur top speed will depend on any mods you've done. Prolly like 145 if you have my headers, xpipe, mufflers, CAI, tune possibly more
Old 11-13-2012, 07:31 AM   #9
rebeltx's Avatar
Even with the drive shaft you will still need a tune to get rid of the electronic governor...
rebeltx is offline
Old 11-13-2012, 08:06 AM   #10
A. You really have no business ever going that fast on a public road
B. The tires are probably not rated to go above that
SpectorV is offline
Old 11-13-2012, 08:42 AM   #11
A. When did he say he would be doing this on a public road.
B. He has the performance package with upgraded tires that are good for 150+ MPH.
Old 11-13-2012, 09:04 AM   #12
deadsp0t's Avatar
Where else will you be going faster then the top speed limiter allows
I don't recall any new 6's breaking that on the strip..
That's unimpressive
deadsp0t is offline
Old 11-13-2012, 09:05 AM   #13
mrkrabz's Avatar
Under your rules, there no point in any car that goes over 70mph. Is that correct?
Thank you, someone who understands.
Also, higher top speed is often accompanied with faster acceleration.
mrkrabz is offline
Old 11-13-2012, 09:06 AM   #14
deadsp0t's Avatar
Also, higher top speed is accompanied with higher acceleration a lot of the time.
Understands what?
That's unimpressive
deadsp0t is offline
Old 11-13-2012, 09:13 AM   #15
mrkrabz's Avatar
Originally Posted by deadsp0t View Post
Understands what?
Understands that just because I want to have a higher top speed on my car, doesn't mean that i'm going to be pushing that speed on the streets. I never said, "113 isn't fast enough for me on public roads", all I asked was why it was limited to that, and how do I get it to go faster.
mrkrabz is offline
Old 11-13-2012, 09:16 AM   #16
deadsp0t's Avatar
Answered and answered.
In the interest of your and the publics safety I suggest you contact a tuning expert locally or someone like AM to be sure you get the most up to date and accurate info available as there seems to be a lot of theories surrounding top speed and safety on the new 6's.
That's unimpressive
deadsp0t is offline
Old 11-13-2012, 09:39 AM   #17
Have you ever heard of a "race track"...
---------- Post added at 09:39 AM ---------- Previous post was at 09:36 AM ----------
When car and driver took the 2011 Mustang V6 around Virginia International Raceway they were hitting the top speed governor for more than 15 seconds per lap. A drag strip is not the only place you can go over 100+ MPH legally...
Old 11-13-2012, 09:49 AM   #18
deadsp0t's Avatar
I'm very familiar with VIR..
That's unimpressive
deadsp0t is offline
Old 11-13-2012, 10:13 AM   #19
rebeltx's Avatar
THIS... I cant say how true the statement "there seems to be a lot of theories surrounding top speed and safety on the new 6's" is... There are multiple theories about when your drive shaft will break and what tires are rated to. On the Evolution, most stick with 125MPH being a breaking point but as you can read some think it is more than this and others lower. On other forums people continue to disagree and to be honest Im not sure that anyone has put the real leg work in to find an answer backed by Ford. Honestly brother, your SAFE bet is to leave that governor be until you put in the leg work yourself and get an answer that you could have total confidence in. After all, if your drive shaft were to snap at 125, you have no safety hoop to keep that shaft from digging into pavement. There is a very real possibility that it will catch an edge and sent your car our of control... at best you snap a shaft and maybe do some damage to the rear end or transmission. At worst, you can kill yourself and anyone else near you on the road... I respect that you just want the best performance from your car, but please, everyone, take the safest route for yourselves and the other drivers on the road. None of us want to see any other person or car damaged in our never ending quest for positive G force.
You wouldn't put a gun to your head and pull the trigger because someone else told you it wasn't loaded, would you?
rebeltx is offline
Old 11-13-2012, 10:28 AM   #20
Adogg's Avatar
This is getting way to off topic all he asked was about his top speed and how to get it higher what he does with the information that was given to him we can only assume. There is no reason to accuse him of doing it on public roads cause that was never said. But just some quick advice I you do raise your top speed do it on the track an have some fun.
Don't hate....... appreciate
Adogg is offline
Old 11-13-2012, 11:04 AM   #21
deadsp0t's Avatar
Personal and public safety are very much on topic here. Anytime factory controls are removed or by passed it is of concern to anyone who may share a road. Just like it was not specifically expressed that the sole intent was on road use it was not expressed that the sole intent was off road use only. We have very clear rules and walk a tight line when these topics come up and in no way condone said activities on public roads. again we understand the query but we have a responsibility to advise members in the best interest of public safety.
That's unimpressive
deadsp0t is offline
Old 11-13-2012, 12:17 PM   #22
Midnight2012's Avatar
Regardless of saftey Ford should have put a speed limit in line with a V6 Sports Car. My daughters Fiesta is limited at 118. That car would be squirrely as heck at that speed. Ive had my mustang to 110 and it was very smooth.
At least out in a drive train rated to 150 and limit it to 120/125. There us no excuse for sny car to have a DS that will fall out at any speed. Un-acceptable. Even my wifes Flex boat anchor can go over 113.
Midnight2012 is offline
Old 11-13-2012, 01:15 PM   #23
Adogg's Avatar
I no it is unsafe I told him to do it on the track and not the road? He can raise his top speed if he wants to as long as he is using it in the right place. Trust me Iam all about safety and if he has gone that speed on the road or is planning to do so I urge him to reconsider cause any car can go fast with enough room of course lol but that beside that fact. One day my dad when he was young was in a mustang and thought it would be a good idea to speed he ended up splitting his mustang in half and breaking his friends arm luckily no one is dead so next time some thinks of speeding just think about how great ur car would be split in Half ill post the pic of his mustang when I find it
Adogg is offline
Old 11-13-2012, 02:33 PM   #24
Jayday20's Avatar
So from what I take from all this is that there is no definitive answer on whether or not the drive shaft will fail at speeds above 113? I only ask because I do plan on modding down the road and just curious as to whether or not a new drive shaft is a must sooner rather than later. I know on the American muscle v6 project car they take it to 140 on the dyno before replacing the drive shaft in there stage 3 or 4 mods I can't remember. If it was a real issue I guess there would be more info out about it. I have tried countless searches and read through them all but nothing says that this is a recurring problem, anyways if anybody comes up with some good info lets us know what u find.
Jayday20 is offline
Old 11-13-2012, 02:51 PM   #25
mrkrabz's Avatar
I 2nd this. I did find a video of someones shaft failing on a 11' v6 at 125, but again that may have been fixed with the 13's. I'll ask my dealer next time I am in for service, and post here to update you.
mrkrabz is offline
Old 11-13-2012, 05:16 PM   #26
NewMtang's Avatar
Video
For those who want to see the video.
2011 Ford Mustang V6 Driveshaft Fails At 135 MPH [Video] | AutoGuide.com News
NewMtang is offline
Old 11-13-2012, 05:43 PM   #27
rebeltx's Avatar
he got lucky his car was the only thing damaged.
rebeltx is offline
Old 11-18-2012, 04:38 PM   #28
UltArc's Avatar
Top speed SHOULD be 155-160 mph governed by stock power and aerodynamics.
Please note, this is calculated by power and aero data, not taking into note the governor or potential hazards/failures, such as the drive shaft.
2012 Mustang EPA: 19/29
2012 AeroStang: 40/46
My sponsor, Tokkyo Nutrition, offers 50% off your entire order with the code "PowerHouse"
UltArc is offline
Old 11-18-2012, 04:53 PM   #29
It's not me, it's you.
primer2tone's Avatar
That's one thing that doesn't make sense. Why couldn't Ford just put in the same driveshaft as the GT? Was it really that cost effective to skimp out on the durability of the V6's driveshaft? I don't get it.
primer2tone is offline
Old 11-18-2012, 05:00 PM   #30
deadsp0t's Avatar
Because its not cost effective and as bad as the owners don't want to hear it it's not designed to go past 118 or whatever.. It's a v6 commuter car, not a Gran Touring (GT) car.. It's a base model sports car.
That's unimpressive
deadsp0t is offline
Old 11-18-2012, 05:57 PM   #31
UltArc's Avatar
Don't call it a sports car, or the trolls will be here to complain about how the Mustang isn't good enough to be a sports car.
UltArc is offline
Old 11-18-2012, 06:17 PM   #32
deadsp0t's Avatar
Lmfao.. Call it how I see it.
That's unimpressive
deadsp0t is offline
Old 11-18-2012, 06:34 PM   #33
UltArc's Avatar
Yea, me too, but after so long of people who don't drive a Mustang, or even a rear wheel drive car at that, jumping on it to talk about how it isn't a evo or corvette and how price dictates the car itself, I have gotten tired of it.
Does anyone know the weight of the GTs drive shaft or if it will fit onto a v6? Weird question, but no one seems to know.
UltArc is offline
Old 11-18-2012, 08:34 PM   #34
alrefire's Avatar
i removed mine
I won't go faster than 120 untill i get new tires+d shaft
alrefire is offline
Old 11-18-2012, 08:41 PM   #35
rebeltx's Avatar
I really have no need to go that fast personally but I wanted to bring up how gearing may change the top speed at which your stock drive shaft breaks. Steeper gears mean more HP to hit top speed, meaning a mustang with 3.73 gears might snap a shaft at a lower speed than people think. Larger wheels could also cause extra stress on the drive shaft and cause pre mature failure.
"Turn the mic back on" -Winston Churchill
rebeltx is offline
Closed Thread
01:50 AM
