Looking at ramps - Mustang Evolution
Old 11-16-2012, 09:09 AM   #1
Gk1million's Avatar
Looking at ramps
I'm thinking about buying some ramps so I don't have to deal with jacks and stands for oil changes and such. What height should I be looking for and should I be worried about the steepness?
Factory wheels suspension and front.
Gk1million is offline   Reply With Quote
Old 11-16-2012, 01:26 PM   #2
Rhino Ramps are pretty good and cheap
Walmart, Pep Boy's and most places sell Rhino Ramps. They work great but be sure you get a rubber backed carpet to put under them. They do have a problem of slipping if they are just on the concrete garage floor.
I have them and used them for my 98 Corvette which was very low so I had to drive up on two by eight boards to get my front from hitting the ramps before the tires. They worked great for changing the oil.
I have not used them on my Mustang yet but I'm certain I will not have any problems at all.
Old 11-16-2012, 01:43 PM   #3
Gk1million's Avatar
Thanks ill check um out.
Old 11-16-2012, 02:17 PM   #4
It's not me, it's you.
primer2tone's Avatar
You could build some ramps. Stagger some 2X8's. that's what I need to do. My car is too low for traditional ramps. Hell, I can't even get the stock jack under the car. Lol
Old 11-16-2012, 04:13 PM   #5
Hey Primer2tone
My 1998 Corvette was very low and would hit the Rhino Ramps.
Easy safe fix was just to go to Lowes and buy a 2 X 8 and cut it into the length I needed for two pieces.
Drove the vette onto the 2 X 8's--- Put the Rhino's against the boards and the two inches were just enough to have the front end clear so my Vette would not scrape on the Ramps.
I went to a carpet store and they actually gave me a nice piece of carpet with a rubber backing that I put under the ramps to avoid them sliding on my smooth concrete garage floor.
My opinion is this:: If I'm getting under a car I think I would prefer the Rhino Ramps and not a bunch of wood piled up. I also block the wheels on the ground to avoid any rolling. ( Overkill,I know) but safty first. A set of Rhino Ramps are only about $25.00 or so.
Old 11-18-2012, 02:49 PM   #6
Gk1million's Avatar
Yep ended up needing some boards to get up the ramps. It was really close though, maybe a half inch higher bumper and it would have been fine.
Old 11-18-2012, 04:05 PM   #7
The boards work fine
Once you get the hang of using them it gets second nature.
Old 11-20-2012, 02:12 PM   #8
Flashjmg's Avatar
Anybody recommend ramps if I don't have a garage. Just a parking space outside? Lol no one parks in the spot next to me because they aren't there half the yeAr so ill have space lol just wanna work only car. What r ur thoughts?
Flashjmg is offline   Reply With Quote
Old 11-20-2012, 02:41 PM   #9
NewMtang's Avatar
Find a new girlfriend that has a garage.
Old 11-20-2012, 05:11 PM   #10
EASY
Rhino Ramps, You don't need a garage to use them. Go to Walmart and I'm pretty sure they sell them.
Check them out
http://www.amazon.com/RhinoGear-1190.../dp/B006EGAIII
https://www.google.com/search?hl=en&....1.oJ91Piyb7zM
Old 11-20-2012, 05:56 PM   #11
rebeltx's Avatar
I bought some metal one's that are powder coated today from harbor freight for 40 bucks, they work like they are supposed to, didn't slide or anything like that. they will work for now, not sure about once i nam lowered though. they had one of the "low profile" jacks at harbor freight for around $100 that looked solid, I might go back and pick it hp at some point.
rebeltx is offline   Reply With Quote
Old 11-20-2012, 08:01 PM   #12
Hi rebiltx
When you lower your car and if any part of the car hits the ramps all you need to do is get a couple of 2X8 boards to drive the front wheels on and then on to the ramps. Problam solved.
Those are some nice sturdy looking ramps you bought.
01:37 AM
