excessive wheelspin? - Mustang Evolution
Old 11-26-2012, 09:35 AM   #1
i seem to be getting a loot of wheel spin when shifting to second with full throttle (manual trans). is this my shifting? im new to the manual thing iv only had it roughly 3 months. am i shifting too late? or are my tires just not gripping enough? theyre getting sorta low on tread. but its almost always seemed to spin a little much
howsit stangin is offline   Reply With Quote
Old 11-26-2012, 09:54 AM   #2
TheStig's Avatar
Only problem you have is to much horsepower. Ease back on the throttle and you shouldn't light them up.
TheStig is offline   Reply With Quote
Old 11-26-2012, 09:54 AM   #3
Charlie_santos's Avatar
Get a LSD from ford racing
Old 11-26-2012, 09:56 AM   #4
ChrisMustangs's Avatar
Your tired wont grab because alot of horsepower, cold tires won't grip as much, and regular tires don't grip a lot to begin with.
-2011 Mustang 5.0 Premium Automatic-
Mods
SLP Loudmouth Axle-back Exhaust
BBK Cold Air Intake
ChrisMustangs is offline   Reply With Quote
Old 11-26-2012, 09:57 AM   #5
I solved that with wider tires lol 305/40/18 ^_^
Old 11-26-2012, 09:57 AM   #6
Black99Snake's Avatar
a little bit of both. if you get a better pair of tires and slow down on the revs you wont have that problem. if your just hard on your car like i am practice shifting and find your sweet spot. may take some time but you will get it down
1999 Cobra black with medium parchment interiorJLT CAI, RWR motorsports tune, Pacesetter Longtubes, o/r xpipe w/cutouts, Flowmaster Super 44s, built t56, Kevlar clutch, Nitto NT05R, Ford Racing 4.10 gears, MMR 900 rotating assembly, vortech v3 si, twin aeromotive 340s, aeroquip lines, 80lbs injectors
Black99Snake is offline   Reply With Quote
Old 11-26-2012, 10:03 AM   #7
yeah i was thinking of getting 20's on the back and 19as in the front like the gt500. maybe this will help with grip?
Old 11-26-2012, 10:56 AM   #8
That's what everyone needs to do better for the car and look freaking sick! Nice size BTW haha!
---------- Post added at 11:56 AM ---------- Previous post was at 11:56 AM ----------
Bigger tires will always help grip
Mods
BBK Cold Air Intake
Old 11-26-2012, 10:58 AM   #9
What really helps is the rear wheel size as in width. The larger the width the more traction you get. That's why my 18's are enough cuz I have massive rear tires!
---------- Post added at 10:58 AM ---------- Previous post was at 10:57 AM ----------
Thanks and yea the stang from the rear looks BEAST!
Old 11-26-2012, 01:02 PM   #10
what rpm do you aim for? cuz i generally shoot for around 6700 ish and that may be the issue
Old 11-26-2012, 03:02 PM   #11
bucko's Avatar
Do you have the performance package? If so, is the advancetrac/stability enhancement system off? Page 205 of my 2011 owners manual states (in brief):
ADVANCETRAC STABILITY ENHANCEMENT SYSTEM
Your vehicle is equipped with the AdvanceTrac system. The
AdvanceTrac system provides the following stability enhancement
features for certain driving situations:
• Traction control system (TCS), which functions to help avoid
drive-wheel spin and loss of traction.
• Electronic stability control (ESC), which functions to help avoid skids
or lateral slides
Old 11-26-2012, 03:18 PM   #12
or lateral slides
no i have the club of america edition. theres not much difference though is there?
Old 11-26-2012, 03:25 PM   #13
ebgonzalez1's Avatar
Would it be that as you shift you let go of the gas a tad bit and reduces the movement of the tire as you shift and wheb you get it to gear theres too much movement from the engine and trans compared to the tires? I mine wheelspins from wot when I reduce the gas pedal between shift but not when I power shift? Idk
"Just a lil Sixxer...."
ebgonzalez1 is offline   Reply With Quote
Old 11-26-2012, 03:33 PM   #14
i think you might be right. as apposed to letting go of the gas while shifting what are you supposed to do?
Old 11-26-2012, 03:40 PM   #15
Power clutch lol if done right it is better. But if you are going on a road course I doubt youd be going wot then letting go a tad bit then wot youll be on the ditch if you try that.... different shifting for different environments just depends on the driver to know what he is doing.
12:16 PM
