Burnt connectors? - Mustang Evolution
Old 11-26-2012, 09:42 AM   #1
syas07's Avatar
Send a message via Yahoo to syas07
Burnt connectors?
So, I was having an issue with the passenger headlights. So when I got my oil changed I had it checked.
The connector was burnt by the aftermarket bulb. I saw it charcoal black for sure. $200 fix since I put in the headlights.
Anyone else have this problem?
syas07 is offline   Reply With Quote
Old 11-26-2012, 09:52 AM   #2
Black99Snake's Avatar
sounds like you got some bad wiring. you have any blown fuses?
1999 Cobra black with medium parchment interiorJLT CAI, RWR motorsports tune, Pacesetter Longtubes, o/r xpipe w/cutouts, Flowmaster Super 44s, built t56, Kevlar clutch, Nitto NT05R, Ford Racing 4.10 gears, MMR 900 rotating assembly, vortech v3 si, twin aeromotive 340s, aeroquip lines, 80lbs injectors
Black99Snake is offline   Reply With Quote
Old 11-26-2012, 10:11 AM   #3
syas07's Avatar
Not that I saw. Connector is def burnt tho. Lmao
Old 11-26-2012, 10:21 AM   #4
bucko's Avatar
What aftermarket bulb did you install?
Old 11-26-2012, 10:23 AM   #5
Sirtat's Avatar
could have been a loose connection, loose connections cause resistance, resistance causes heat and that "could"be the sole reason for the burnt connector..
IBLT IT
2005 Promar Performance forged long block
Kenne Bell 2.8L LC mammoth supercherger
and and and I DRIVE IT LIKE I STOLE IT !!!!
http://www.youtube.com/watch?v=_K_QJ...ure=plcp<br />http://www.youtube.com/watch?v=NWfvYVYlfio&feature=plcp
Sirtat is offline   Reply With Quote
Old 11-26-2012, 03:06 PM   #6
bucko's Avatar
Good point. If it's still under warranty, have it checked out; just re-install the factory bulbs, then Ford will replace the connector. Don't tell them you used an aftermarket bulb though!
Old 11-26-2012, 03:15 PM   #7
syas07's Avatar
Unfortunately too late :-/. Stupid me. Lol
04:56 PM
