Lethal Performance Cyber Monday H-Pipe - Mustang Evolution
Old 11-26-2012, 02:14 PM   #1
Black on Boss's Avatar
Lethal Performance - Midpipes - Exhaust - 2011-2013 Mustang V6 3.7L
I was just browsing around and stumbled on this. Enter TENOFF in the discount code at check out and receive 10% off on entire purchase.
Anyways I went ahead and ordered the h-pipe for myself as I have yet to start on my exhaust and this was $206.99 out the door after rebate.
Anyone on here with the h-pipe? I'm hoping for a deeper tone vs the raspy x-pipe.
Old 11-27-2012, 11:08 AM   #2
You will be removing your Cat's
What year is your car ? If A late model you will sure throw some codes without the Cat's.
I would do some research and ask some of our Forum members what would be involved to get your car's codes clear when you remove the converters.
I'm thinking your gonna need a tuner.
This should be interesting.
Old 11-27-2012, 11:15 AM   #3
It will throw a code bc of the cats but its a simple fix with a tuner. It want hurt anything to run it without a tune you will just have a check engine light as far as I know. Trust me I do quite a bit of research before I even think about modding my car.
Old 11-27-2012, 11:19 AM   #4
Good
I kind of miss the old day's before the computer.
I'm glad you did your homework before taking the plunge. I think your car will sound pretty nice with the "H" pipe.
Old 11-27-2012, 11:27 AM   #5
Charlie_santos's Avatar
I had the uncatted H-Pipe myself before I did headers and everything and I had a Roush Axleback and it sounded awesome!
Old 11-27-2012, 12:01 PM   #6
That's good to know. I couldn't find any "good" vids on the h-pipe so I'm gonna do everyone a favor and make my own. but I think it will sound better than the x-pipe. I will find out and I will post up a link when I get it.
Old 11-27-2012, 12:28 PM   #7
It will if u want a deep sound not a rasp sound
Old 11-27-2012, 01:25 PM   #8
That's exactly why I went with the h and not the x. There really isn't enough performance difference between the two to make me go with the x.
Old 11-27-2012, 01:48 PM   #9
The Blue Dragon
GrabberBlue5.0's Avatar
Having an offroad exhaust will cause more fuel to be dumped into the exhaust and foul out o2 sensors.
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 11-27-2012, 01:57 PM   #10
Lol what sensors? Hahaha no catts no sensors
Old 11-27-2012, 02:08 PM   #11
WIN
Old 11-28-2012, 09:57 AM   #12
The Blue Dragon
Umm... what? Do you know what oxygen sensors are or where they go? There are no sensors in the catalytic converters so by removing the cats you are not necessarily removing sensors. You will still have them and you will still be throwing CEL codes and you will still be causing damage without a tune
Old 11-28-2012, 10:13 AM   #13
Does it really matter tho? If we go off road exhaust then we don't care about the O2 sensors and we just disable the codes.
Old 11-28-2012, 10:21 AM   #14
The Blue Dragon
This here is why it matters, it's not a big deal, I'm just trying to inform the OP that there is damage to be done. And if the sensors are damaged then they are damaged, there is no way to tune around a broken o2 sensor in the copperhead ecu. They must be working properly or cel will stay on and will cause running issues and get worse over time.
You cannot break something and just forget about it, even if there are no immediate repercussions over time something else will fail, be it an injector or the motor, only time will tell
Old 11-28-2012, 10:22 AM   #15
The Blue Dragon
I'm not saying to not do an offroad exhaust, I'm runnin and ORX on mine, just trying to help prevent damage and having to spend money on frivolous repairs
Old 11-28-2012, 11:41 AM   #16
Repairs on what tho? All we gotta do to pass a inspection is use a tune to disable the the O2 sensors they don't do the sniffer on our cars because they are too new so they don't bother as long as the ECU passes then no worries. I personally have BBK Long Tubes and. HighFlow Catted Xpipe. It's almost the same I lost 2HP adding the Cats
Old 11-28-2012, 11:41 AM   #17
The Blue Dragon
You didn't read my post above that one you quoted did you?
Old 11-28-2012, 11:57 AM   #18
No sir I did not. You do have a point. I don't have to worry about that but a friend of mine just replaced the sensor with a piece of metal piping so his exhaust is all flush nothing in the way of airflow. I like my catted x pipe
Old 11-28-2012, 01:18 PM   #19
The Blue Dragon
On an 11+ mustang?
Old 11-28-2012, 01:21 PM   #20
On an 11+ mustang?
12 sir. He has headers xpipe no sensors at all nothing to restrict any air flow at all.
Old 11-28-2012, 01:22 PM   #21
Sanguin's Avatar
Removing the cats does not make you run richer. All they do is super heat the exhaust after the front oxygen sensor to remove unburnt fuel and make the emissions cleaner. The rear oxygen sensor reads the difference in the exhaust and its compared with the reading at the front. The difference between these two sensors is what throws a code (if emissions aren't scrubbed its going to tell you your cat isn't working).
It isn't voodoo science. Most tunes just delete this code as erroneous and you go on your merry way. Any changed in rich/lean will be due to the ability of the engine breathing better.
'13 'Stang V6 - MT82 - GHIG Ordered: 5/31 Pickup: 7/3
35% Tint, Homemade Intake (1, 2), GT500 Heat Extractor/Splash Guards, Custom Gas Cap
Barton Shifter Bracket, GHIG Shift Knob
'98 Grand Prix GTP - New Project for DD
Sanguin is offline   Reply With Quote
Old 11-29-2012, 05:50 PM   #22
Santa finally came to my house ! Lol I want be able to get these on til Mon or tues :'( I gotta work all weekend
Old 11-29-2012, 05:53 PM   #23
NICE!!!!! post pics and vids!!!
---------- Post added at 05:53 PM ---------- Previous post was at 05:52 PM ----------
Also do you have stock mufflers?
Old 11-29-2012, 05:56 PM   #24
Yes I wanted to see what I sounded like with stock and that's why I will be posting a vid bc I know others would like to know too. Lol
Old 11-29-2012, 05:58 PM   #25
Exactly what I was thinking lol. I have a full BBK exhaust and Roush mufflers but they are too loud so I was thinking of putting my stock ones on to see what it sounded like lol
Old 11-29-2012, 06:12 PM   #26
LOL I just found your car on YouTube lookin for another vid is that just a blue bulb in you license tag or is that a led or somethin .... I want that
Old 11-29-2012, 06:18 PM   #27
LMFAO!! Does it sound ****en loud or what bro lol I installed some take off resonators from a 11 GT to make it deep. As for the Lights, it's just blue LEDs you can get them cheap on eBay bro! I got the interior dome lights and license plate lights for 6 bucks lol
Old 11-29-2012, 06:21 PM   #28
LMFAO!! Does it sound ****en loud or what bro lol I installed some take off resonators from a 11 GT to make it deep. As for the Lights, it's just blue LEDs you can get them cheap on eBay bro! I got the interior dope lights and license plate lights for 6 bucks lol
Nice and BTW this is the vid I was looking for to show you ..
http://m.youtube.com/#/watch?v=QFreq...%3DQFreqKK_ry4
I just realized that is a mobile url .. this is the reg url
http://www.youtube.com/watch?nomobile=1&v=QFreqKK_ry4
Old 11-29-2012, 06:26 PM   #29
That's how loud my car was but I tamed it with the resonators. Even that guy said his exhaust was too loud hahaha
Old 11-29-2012, 06:28 PM   #30
That was my point but he put he stockers back on with the BBK longs and xpipe
Old 11-29-2012, 06:29 PM   #31
And my stock exhaust shouldn't be too loud since I have the resonators on it....ima put my stock ones on this weekend and see how it is.
Old 11-29-2012, 06:39 PM   #32
Post a vid I'd like to here it with the resonators
Old 11-29-2012, 06:51 PM   #33
Yea man will do!!
Old 12-03-2012, 05:21 PM   #34
So I go to take the stock x off from the exhaust manifold and instead of the nut coming off the stud, the nut was seized to the stud so the whole stud came out. Then I put the stud in a vise to get the nut off and broke the vise. I should've just taken this sh1t and had it installed for the $75 I was quoted. So now I have to go buy a stud and nut to put back on because these ain't coming apart . ARGGGGGG!!!!!!!!
Old 12-03-2012, 05:23 PM   #35
LMAO!!!!!!!!!
04:06 AM
