Anyone Retrofit Projectors themselves? - Mustang Evolution
Old 12-18-2012, 04:57 AM   #1
Charlie_santos's Avatar
Okay so I'm in the process of purchasing a complete Projector kit with angel eye and devil eye all in one deal for 139.99.
http://item.mobileweb.ebay.com/viewi...d=150901085130
I've read on here about ppl paying to get them retrofitted but never anyone do it them self.
I have the basic idea
Remove the headlights
Bake headlights to pry open the headlights
Mount the projector
Figure out how to wire it lol
Test
Install
Test
Test
Test
And done lol
Anyone have some tips for me? I've read dipping the seal of the headlight in gasoline makes the glue super pliable?
Old 12-18-2012, 09:22 AM   #2
curtin1991's Avatar
Send a message via ICQ to curtin1991
If you do it take lots of pics been thinking of this my self
Corey
curtin1991 is offline   Reply With Quote
Old 12-18-2012, 03:54 PM   #3
Ima do it next week.
Old 12-18-2012, 04:20 PM   #4
Sanguin's Avatar
Gasoline might eat the plastic. I would never dip a plastic item in a solvent.
Use the oven bake method. If that doesn't work, cut it open with a dremel.
'13 'Stang V6 - MT82 - GHIG Ordered: 5/31 Pickup: 7/3
35% Tint, Homemade Intake (1, 2), GT500 Heat Extractor/Splash Guards, Custom Gas Cap
Barton Shifter Bracket, GHIG Shift Knob
'98 Grand Prix GTP - New Project for DD
Sanguin is offline   Reply With Quote
Old 12-18-2012, 04:52 PM   #5
peterzard's Avatar
If you are thinking about doing the retrofit project on oem headlights, they might not be able to be baked to open, because they are permanent sealed, and you might have to cut them. And from what I learn, besides using Morimoto Mini projecter, you might need to cut the original housing in order to install the projecter. Not sure about the projecter you bought from ebay.
Also, you can get lots of tips and helps from theretrofitsource.com
Here are two threads of retrofit project on 2010+ mustang.
2010 Ford Mustang FX-R Retrofit
MY First RetroFit 2011 Ford Mustang
peterzard is offline   Reply With Quote
Old 12-18-2012, 04:59 PM   #6
Originally Posted by peterzard View Post
If you are thinking about doing the retrofit project on oem headlights, they might not be able to be baked to open, because they are permanent sealed, and you might have to cut them. And from my what I learn, besides using Morimoto Mini projecter, you might need to cut the original housing in order to install the projecter. Not sure about the projecter you bought from ebay.
Thanks for the links!! And my friend was able to bake open the oem headlights to install his oracle kit so I'm sure that part can be done
11:54 AM
