Tuning for higher octane? - Mustang Evolution
Old 12-23-2012, 12:19 AM   #1
NicholasP's Avatar
WHats the point in tuning for a higher octane gas?
NicholasP is offline   Reply With Quote
Old 12-23-2012, 12:53 AM   #2
tc x 4's Avatar
Better performance and gas mileage.
Old 12-23-2012, 10:52 AM   #3
Higher octane gas can be compressed more, so that means if you are tuned for it you get bigger combustion which = more power... That's just the basic principle behind it.
Old 12-23-2012, 11:15 AM   #4
tc x 4's Avatar
? Your not making sense.
Old 12-23-2012, 11:32 AM   #5
A higher octane gas has the ability to be compressed more (or higher, whichever word you want to use). So when your cylinder compresses say 93 octane it can compress more than say 87 octane. What happens when something is compressed more and ignited? It makes a bigger explosion, and a bigger explosion means more power. But if you are not tuned for it then your car will still compress the same amount, which means that it wont matter if it is 87 or 93 because the compression is the same. Simple Chemistry and Physics
Old 12-23-2012, 11:35 AM   #6
Venomouz831's Avatar
+12378
)02 Gt, Founder of WE2G
Old 12-23-2012, 07:12 PM   #7
tc x 4's Avatar
It makes a bigger explosion because of the higher octane rating. The only way to compress it more is by changing the pistons, or milling the heads.
---------- Post added at 09:12 PM ---------- Previous post was at 09:11 PM ----------
Your lost son
Old 12-23-2012, 07:44 PM   #8
Sanguin's Avatar
You're both right, but he is more so. Higher octane allows more compression of the fuel. More compression equals more release in power when it's combusted.
Yes, you can't add more static compression, but when you play with timing, you can change at what part of the piston stroke the fuel is ignited. That is what tunes do. The more detonation prevention to the fuel, the more timing can be advanced and previously untapped power can be utilized. Advancing timing increases cylinder pressures and you need the extra octane to prevent detonation.
What does it mean to advance timing? You're making the fuel combust before the piston has reached the top of its stroke. This means you have to actually compress the expanding gases, increasing cylinder pressure and thus the resulting pressure against the piston on the down stroke. This extra pressure on the pistons down stroke generates more power.
'13 'Stang V6 - MT82 - GHIG Ordered: 5/31 Pickup: 7/3
35% Tint, Homemade Intake (1, 2), GT500 Heat Extractor/Splash Guards, Custom Gas Cap
Barton Shifter Bracket, GHIG Shift Knob
'98 Grand Prix GTP - New Project for DD
Sanguin is offline   Reply With Quote
Old 12-24-2012, 01:15 AM   #9
tc x 4's Avatar
I'll give that an A+
Old 12-24-2012, 02:47 AM   #10
Charlie_santos's Avatar
Nerd mode activated!! Jk that was informational actually thank you
Old 12-24-2012, 06:56 AM   #11
davidcseifert's Avatar
Region: Arkansas
Hit up Luis at Ortizperformance, he'll set you up with a great tune!
blower/new cam soon
Old 03-07-2013, 03:08 PM   #12
Fintile's Avatar
Do they sell high compression pistons for the 3.7?
“anybody driving slower than you is an idiot, and anyone going faster than you is a maniac”
-George Carlin
Fintile is offline   Reply With Quote
04:10 PM
