Rear diff opinions please - Mustang Evolution
Old 01-01-2013, 02:16 AM   #1
The Puma's Avatar
I want to change my gears again to 4.10 and while I'm at it, get a new limited slip rear diff. I have 14k miles, should I get all the extras or would just the gears do since it only had 14k on them? Also, anybody got advice on a good rear diff for a V6 that will eventually run F/I? Wanna buy one and leave it.
The Puma is offline   Reply With Quote
Old 01-01-2013, 09:32 AM   #2
03RedfireGt's Avatar
Imo I would just do the gears. The diff is going to be good for many more miles to come. Use the extra cash for a another mod
03RedfireGt is offline   Reply With Quote
Old 01-01-2013, 09:32 AM   #3
CYCLON37's Avatar
All rear diffs are different and have different goals in mind. Are you looking to go straight or turn? Our differential is already LSD btw. And if you're planning on running FI, I would not run too steep a gear. 3.31 would be the highest(#) I'd go personally. Otherwise, every time you touch the peddle on the street you'll leave some tire prints behind you.
CYCLON37 is offline   Reply With Quote
Old 01-01-2013, 09:59 AM   #4
Sanguin's Avatar
Pretty much what he said.
'13 'Stang V6 - MT82 - GHIG Ordered: 5/31 Pickup: 7/3
35% Tint, Homemade Intake (1, 2), GT500 Heat Extractor/Splash Guards, Custom Gas Cap
Barton Shifter Bracket, GHIG Shift Knob
'98 Grand Prix GTP - New Project for DD
Sanguin is offline   Reply With Quote
Old 01-01-2013, 10:10 AM   #5
pwrby4d's Avatar
For daily and occasional track use you are good to go. If you will be tracking the car heavy and launching the car at the track a lot then I would do Moser Axles and do the a diff as the T - Lock that is what is in your car now is prone to failure under really hard launches. I would also have the axle tubes welded, do a girdle and a CHE brace too if you are adding a lot of HP down the road. But if you are just doing street driving and not on slicks etc... I would keep it simple and have the upper and lower control arms done instead if you havent done that already. Driveshaft would be a good one too if you are doing gears as it has to be unbolted from the pinion flange to do the gears anyway.
pwrby4d is offline   Reply With Quote
Old 01-01-2013, 11:09 AM   #6
Charlie_santos's Avatar
If your gna do FI sooner or later your gna need lower gears like 3.55's 4.10's are ridiculous for FI and as for the LSD you don't really need it much. But would get it if u have the money for it. Your gna need the install kit sir and get the pinion bearing from autozone for 24 bucks instead of AM
Old 01-02-2013, 08:37 PM   #7
rebeltx's Avatar
lots of good advice here... if you do gears then you want the whole kit for sure.
rebeltx is offline   Reply With Quote
Old 01-02-2013, 10:25 PM   #8
The Puma's Avatar
Yup. Thanks for all the advice everyone.
Old 01-02-2013, 11:23 PM   #9
Aruiz42's Avatar
What's FI?
Aruiz42 is offline   Reply With Quote
Old 01-02-2013, 11:37 PM   #10
Originally Posted by Aruiz42 View Post
What's FI?
Forced Induction aka Super Charger or Turbo
02:33 AM
