Can any owners of 11 plus V6 models of installing the BBK throttle body tell me if this mod was worth it. I am currently running a 91 Hybrid tune along with a Airraid CAI. The tune is bad a$$ killer and the throttle response is much better than stock. I do notice there is still a slight delay in acceleration when flooring the pedal. Slight delay before thrusting me back. Has anyone noticed since installing the BBK throttle body there acceleration delay is no more. When hitting the pedal the car immediately responds.
If not, any thoughts on how to get instant throttle response?
I would personally not advise purchasing the TB until you get full length headers and xpipe bro. That will waken up ur car trust me I have headers. Then that TB will work better
The delay your feeling is the standard throttle response delay. Its there so you don't slip your rear wheels by accidentally punching on the gas real quick. It is made as more of a safety than anything.... i bet bama can adjust it in your tune but you will want to be careful, especially when it is wet out. you also have to remember that there is going to be a slight delay caused by the time it takes that surge of air you need for WOT to get from your intake, down the tube, into the TB and intake manifold. it may sound bogus but air flow is not constant or instant, there is almost always going to be a slight delay. A good example is while your in neutral smash the gas to the floor real quick and then let off. You will hear the "pop" of the TB opening all the way but you wont rev all the way up to the limiter because the TB closed somewhat before that surge of air got the the engine. A short ram intake will help and the larger TB will also but if your shooting for instant max power your going to look at other options... like NO2... and that still wont give you instant max power.
A new driveshaft is definitely on the to do list of mods but that is on my low priority list right now. Perhaps the delay is the automatic transmission down shifting. Perhaps with some 3:55 gears that will also help with the delay. Headers, X pipe and gears are my top mod upgrades.
You are wrong. A aluminum/carbon driveshaft does help quite a bit with throttle response/acceleration. The aluminum/carbon driveshaft weighs quite a bit less then the stock driveshaft so you are decreasing the rotational mass of your driveshaft that your motor and trans have to turn, hence quicker acceleration. There are no "gains", just like gears, but that doesn't mean it's not a good modification for performance. You would be very happy with a new driveshaft, feels like a new car.
Everyone has different preferences...I would rather have a new driveshaft then headers all day and tomorrow. Some people just are not as informed as others...All I was saying is what you posted was incorrect and you shouldn't be spreading false information.
---------- Post added at 09:17 AM ---------- Previous post was at 09:16 AM ----------
I'm not. A drive shaft will not make your car feel like a totally different machine like you stated. You will feel just as good of a kick as if you tuned a new car. It will wake it up a bit but without other supporting mods that one drive shaft will not by itself make your car feel like a new car. My friend is about to invest in one since he has nothing else to buy except a pro charger and I will personally test your theory of it being a completely new car. If it does I will admit it and apologize if it doesn't Ill simply say I told you so
If you are serious and have a lot of $$$$$ to spend you need to start with the headers all the way back to the mufflers. Get the High performance cats and an X-pipe. A good Cold Air Intake is a must have. The drive shaft is mandatory because you just ain't gonna go to far with a broken driveshaft. It is also much,much lighter then the stock 43 pound two piece crap that Ford put on these cars. After you get all of that put on you need to get a good tuner. If you get one from American Muscle they would want a list of everything you have done to get you tuned properly. Unless you are going to put in larger injecters I would think the stock throttle body will work fine for the street. (My Opinion) It will flow more air then your engine needs anyway with the stock injecters.
As far as a throttle delay I can't help you. I know my V6 automatic has no throttle delay at all. All I have is Magnaflow streets and a Drop in K&N air filter. It is very responsive and goes like hell when I punch it.
If I had lots of money I wouldn't be driving a V6. Lmao. I would be driving a Gt500 but still, I do love my sixer. I really appreciate all the advice on here. Great place to learn about our cars. Hopefully, in the not to distant future I can upgrade to a shaft master driveshaft. Not that I plan on driving 140 plus on a regular basis but would like to be able to have the confidence and option of doing so without taking any chances of the stock one exploding through the floor board.
I already have the Flowmaster Axle back Force II exhaust system. I have a Airraid cold air intake. I'm currently running a 91 Hybrid tune. My major priorities of upgrades for spring are to get rid of the gas saving 2.73 gears purchase BBK Headers and X pipe.
Going to a lower ratio gear set will be a great way to get the acceleration your looking for. The headers are good if you also go to high flow performance cat's. I think you will have one super quick V6 3.7 when you are done. Along with the less expensive V6 insurance.
I was wondering about your lag when you step on it though. Is your car an Automatic or Manual????
Thanks bro. I hope it it really throws me back. I have a feeling the lag is what some people on here were saying. Its the gears downshifting which I guess takes a tenth or so. Its not really a big lag just a slight before it explodes. I have auto sir
Related Threads
Mustang Evolution Forum
2.1M posts
50.8K members
Since 2003
