Comparing the Drive Shafts - Mustang Evolution
Old 01-23-2013, 03:59 PM   #1
The one on the top is aftermarket aluminum.
The one on the bottom is stock V6
I wonder why the stock one's break???
Old 01-23-2013, 04:04 PM   #2
rebeltx's Avatar
I have seen the stock ds before but its interesting to see them side by side.....
way to suck Ford lol
rebeltx is offline   Reply With Quote
Old 01-23-2013, 04:09 PM   #3
Send a message via AIM to Borii
My Shaftmasters was around 17 lbs with bolts and my stock was 41lbs with U Joint. Feels great!
SOLD - 06 GT 371WHP/332WTQ
Sold - 1998 Camaro SS
Sold - 2001 Audi S4
Borii is offline   Reply With Quote
Old 01-23-2013, 04:15 PM   #4
DigitalBman's Avatar
They break because they are not meant to spin as fast as people want to drive them.
And I am guessing the joint in the center is the failure point that causes that problem.
DigitalBman is offline   Reply With Quote
Old 01-23-2013, 04:23 PM   #5
Sanguin's Avatar
Well, that small diameter joint on a big shaft doesn't exactly look the strongest thing in the world.
Still, I'm not calling it crap or otherwise. I have yet to see any evidence of this being a consistent problem. I bet there are tons of idiots running them without limiters after tuning because they haven't heard of the one horror story that exist.
'13 'Stang V6 - MT82 - GHIG Ordered: 5/31 Pickup: 7/3
35% Tint, Homemade Intake (1, 2), GT500 Heat Extractor/Splash Guards, Custom Gas Cap
Barton Shifter Bracket, GHIG Shift Knob
'98 Grand Prix GTP - New Project for DD
Sanguin is offline   Reply With Quote
Old 01-25-2013, 04:59 PM   #6
pwrby4d's Avatar
The '13 shaft looks much different.
pwrby4d is offline   Reply With Quote
Old 01-25-2013, 05:08 PM   #7
Sanguin's Avatar
When it's warm again I'll have to crawl under my car and take some pics. Maybe if I get a shifter bracket and install it, I can take pics then.
Old 01-25-2013, 05:13 PM   #8
pwrby4d's Avatar
The one on my car looks more like this
evolutionm.net - View Single Post - SmikeEvo's 2011 Mustang v6 Performance Package - HD Pics
But this car is a 2011 in the thread above.. So is the one in the OP a GT shaft or did they change them again? MZy 06 GT had one that looked like the one in the OP... I swapped it out as it was also prone to twisting but under a lot of torque load and I had steep gears in it so.. Anyway? Which one is it in the V6 or did they make a couple of different DS for them? I know the 13 shaft is supposed to be a bit different and lighter than the 11 and the 12 but the thread I posted has a DS shown that looks like the 13 in my car. Confused. ???
---------- Post added at 07:13 PM ---------- Previous post was at 07:10 PM ----------
Sanguin, I saw a bracket by JHR on Ebay I think it is 50 bucks and looks like the Steeda one FYI. It makes a huge difference.
Old 01-25-2013, 05:16 PM   #9
Sanguin's Avatar
I'm going to grab the Barton 2-post. Might as well get the best if you're getting one. I have no real plans for a short shifter or I'd be saving for an MGW.
Old 01-25-2013, 06:05 PM   #10
Both are 2011/2012 type Drive shafts.
They changed them in 2013 from the one on the bottom in the picture which is a stock driveshaft off of a 2011. A 2012 has that same one. The one on the top is an aftermarket aluminum one like American Muscle sells.
I'm trying to find a picture of one that they now put in the 2013's but not having any luck.
Rinnie
Old 01-25-2013, 06:08 PM   #11
pwrby4d's Avatar
I have the older barton but I drove a car with the new one and I could not feel the difference. The newer design is easier to install though. I will go.with the mgw as well if and when I do the shifter. I had issues with the sve one so I cant recommend it. The stock shifter with the bracket is a big improvement though and honestly I think I like the stock shifter enough to not swap it out.
---------- Post added at 08:08 PM ---------- Previous post was at 08:06 PM ----------
The 2013 looks just like the one in the thread I posted.. wider in the center with the grooves in the shaft on the front side.
Old 01-25-2013, 06:14 PM   #12
Sanguin's Avatar
Could it also be auto vs manual driveshafts?
Old 01-25-2013, 06:22 PM   #13
alrefire's Avatar
the driveshaft is the same for both the automatic and manual transmissions.
Old 01-25-2013, 06:23 PM   #14
UltArc's Avatar
Rinnie
I believe SOME 13s may have the old driveshaft also, sir.
And I remember seeing one on here, but I also have way too many threads to check for it.
2012 Mustang EPA: 19/29
2012 AeroStang: 40/46
My sponsor, Tokkyo Nutrition, offers 50% off your entire order with the code "PowerHouse"
UltArc is offline   Reply With Quote
Old 01-25-2013, 06:42 PM   #15
Whitelightning's Avatar
My driveshaft looks nothing like these two. And im in a 2012.
Old 01-25-2013, 06:44 PM   #16
MrMike's Avatar
I have a 13 manual and has the new ds.
MrMike is offline   Reply With Quote
Old 01-25-2013, 06:45 PM   #17
alrefire's Avatar
pics or it didn't happen
Old 01-25-2013, 06:48 PM   #18
MrMike's Avatar
Give me 5. I'll try to get one 4 u. Garage is cold! : )
Old 01-25-2013, 06:52 PM   #19
MrMike's Avatar
O.k not the greatest pic but proof enough.
Old 01-25-2013, 06:55 PM   #20
MrMike's Avatar
Manufacture date April 2012.
Old 01-25-2013, 06:57 PM   #21
Sanguin's Avatar
One of you guys with an older one crawl under and take a pic pls... lol
Old 01-25-2013, 07:05 PM   #22
MrMike's Avatar
I thought all 13's had the new ds?
Old 01-25-2013, 07:05 PM   #23
pwrby4d's Avatar
Thats what my 13 looks like.
Old 01-25-2013, 07:06 PM   #24
Sanguin's Avatar
No idea. My car was built 6/26/12 if I remember right, so it should have the new shaft.
I was to see an older '11/12 shaft on someone's car here so they can verify it's different. I find it suspect that the shaft in the picture has a carrier bearing.
Old 01-25-2013, 07:15 PM   #25
MrMike's Avatar
Rinnie
Hi Ronnie the one pwrby4d posted is the one I have in my 13.
---------- Post added at 10:15 PM ---------- Previous post was at 10:12 PM ----------
You should have it as you car is 2 months newer than mine. From what people say its supposed to be a little lighter,not sure if its true. But is it actually better? Still looks two piece. It might still have the same weak point as the older model.
Old 01-25-2013, 07:22 PM   #26
Sanguin's Avatar
It's going to be two piece, they're all two piece, even the GTs.
Old 01-25-2013, 07:48 PM   #27
pwrby4d's Avatar
Mine is in June as well if I remember correct.
---------- Post added at 09:48 PM ---------- Previous post was at 09:47 PM ----------
Attachment 87501
Thanks!
Old 01-25-2013, 07:54 PM   #28
MrMike's Avatar
Thanks!
Np. Do you know if they are actually better? Visually they look better! : )
Old 01-25-2013, 08:06 PM   #29
pwrby4d's Avatar
They are lighter which is better. I would think they changed the design because they needed to correct issues.
Old 01-25-2013, 08:08 PM   #30
MrMike's Avatar
Makes sense.
Old 01-25-2013, 08:13 PM   #31
pwrby4d's Avatar
I have read some threads of owners.of 11 and 12 cars diving.13's and.saying they feel smoother and less vibration and noise. So that is an improvement. I would still replace it if u are going to track your car though. 2 pc ds is just a bad design from a performance aspect. Ford uses them for less noise... Not because they are more stable.
Old 01-25-2013, 08:18 PM   #32
2013mustang5.0's Avatar
Is that like a CV joint or somthing in the middle lol. What is that?
2013 mustang 5.0 track pack(first mustang)
2013mustang5.0 is offline   Reply With Quote
Old 01-25-2013, 08:24 PM   #33
Sanguin's Avatar
Ok, after looking around, that is a GT driveshaft with the carrier bearing.
http://www.modularfords.com/threads/...-pc-Driveshaft
Here's the infamous '11 that broke, viewed from under the car. Looks just like the '13 unless I'm mistaken. Appears to have separated at the cv joint.
My 2011 Mustang V6's broken driveshaft aftermath. - YouTube
Old 01-25-2013, 08:25 PM   #34
Wait what's the difference between the 2-post and the short shifter? I was thinking about the Barton short shifter because I'm still learning how to drive a manual transmission and think that would help a bit
Old 01-25-2013, 08:29 PM   #35
pwrby4d's Avatar
Lol.. That is what I was saying before. Lol. Glad u cleared it up though .
10:01 AM
