Will these rims fit? - Mustang Evolution
Old 01-26-2013, 08:02 PM   #1
Smokeyjoe's Avatar
I want to put the 2013 California special rims on my 2010 v6. They are 19 inch rims with Pirelli p-zero Nero 245/45-ZR19. Will they fit on my car?
Smokeyjoe is offline   Reply With Quote
Old 01-26-2013, 08:06 PM   #2
Doe_Rae_mi's Avatar
Pretty sure they will I don't see why they wouldnt
Old 01-26-2013, 08:16 PM   #3
CYCLON37's Avatar
Yes.
CYCLON37 is offline   Reply With Quote
Old 01-26-2013, 09:22 PM   #4
1slosix's Avatar
you won't have any issue
carving corners like a boss
Old 01-26-2013, 10:01 PM   #5
Gtzzoom's Avatar
they will fit...just have to have dealer, or someone reprogram your speed sensor so the speedo stay accurate....
"Slimer" 2013 V6 Premium 6MT
"What you have here sir, is a class 5 full roaming vapor, a real nasty fella!" Ray Stanz (Dan Akroyd) in Ghostbusters
Gtzzoom is offline   Reply With Quote
Old 01-26-2013, 10:26 PM   #6
1slosix's Avatar
Whats the diameter of both his current wheels and the 2013 wheels? Wont need a recal if the same
Old 01-26-2013, 10:28 PM   #7
Gtzzoom's Avatar
18" vs 19"......
Old 01-26-2013, 10:33 PM   #8
1slosix's Avatar
And? You forget tire size in that...a 99-04 v6 has stock 16's and has the same diameter at 99-04 GT stock 17s so we dont need a recal.
Old 01-26-2013, 10:37 PM   #9
Gtzzoom's Avatar
different sensor set up......more high tech in the 2010+....dealer will do it for free. techs come out and takes only 5 mins. 99-04 still has the tailsahft gear....
these have more than one speed sensor.....that much more cost if they go bad later.....
still thinking about taking mine up from 19" to 20" but matched all around....
Old 01-26-2013, 10:39 PM   #10
1slosix's Avatar
Nobody can answer the diameter question can they? Fancy speed sensor shouldnt matter if that is the same. When i get home on my comp ill try and hunt it down
Old 01-27-2013, 01:11 AM   #11
Aruiz42's Avatar
Did it on my 13... Went from the stock 17s to cs 19s I don't see an issue ... Didn't recal nothing!
Aruiz42 is offline   Reply With Quote
Old 01-27-2013, 06:17 AM   #12
Gtzzoom's Avatar
never mind.....guess the techs at my dealer are story telling...sorry
but....i wouldnt have had your kind of luck....
Old 01-27-2013, 08:32 AM   #13
curtin1991's Avatar
Send a message via ICQ to curtin1991
Did u have to get the speedometer fixed ?
Corey
curtin1991 is offline   Reply With Quote
Old 01-27-2013, 08:35 AM   #14
Aruiz42's Avatar
No... I've never heard of that...
Old 01-27-2013, 09:28 AM   #15
curtin1991's Avatar
Do the bigger wheels throw the speed off ?
Corey
Old 01-27-2013, 10:52 AM   #16
Aruiz42's Avatar
Not from what I've seen.. I've used my phone to track how fast I'm going and my speedometer said the same thing!
Old 01-27-2013, 10:54 AM   #17
curtin1991's Avatar
Ok good . I'm planning to buy some 19s this friday and was wondering if it would mess with the speedometer .
Corey
Old 01-27-2013, 11:03 AM   #18
1slosix's Avatar
Like i said unless your new wheels and tires are a different diameter your fine...
Old 01-27-2013, 12:32 PM   #19
Skulls98GT's Avatar
There are tire diameter calculators all over the web. You can put in the dimensions of your tire and it will calculate your diameter. That way you can compare sizes to get close to the same.
Example. 245/45/17 = 25.68" diameter tire.
Skulls98GT is offline   Reply With Quote
Old 01-27-2013, 12:47 PM   #20
curtin1991's Avatar
10-4 thanks man
Corey
Old 01-27-2013, 03:02 PM   #21
Skulls98GT's Avatar
10-4 thanks man
Welcome. Good luck and take pics when you get them.
Old 01-27-2013, 04:02 PM   #22
curtin1991's Avatar
I will for sure .
Corey
Old 01-27-2013, 07:45 PM   #23
Siber Express's Avatar
The 245/45 19's are 27.6 I do believe, while the Stock 17's are around 27.7 so the Speedo should be OK.
Put your stock tire size in here and then the new size and it will tell you how far off the Speedo is Tire size calculator
Old 01-28-2013, 05:55 AM   #24
bucko's Avatar
Plug in your original rim/tire sizes and new rim/tire sizes to find out how far off your speedo will read:
10:18 AM
