do you NEED to return to stock before loading new tunes on tuner? - Mustang Evolution
Old 01-28-2013, 11:53 AM   #1
rebeltx's Avatar
Bama always tells you to return your car to stock before uploading new tunes onto your tuner. Is this just in case something happens to your tuner? that way your car is at least set to stock... or does the tuner know what the last tune loaded was and needs to be set to the stock setting? just curious, I fallow bama's directions pretty much exactly but I dont want to load my stock tune on my car just to put another tune on the tuner that I wont use until I get on the dyno anyhow.... AM staff, what say you?
rebeltx is offline   Reply With Quote
Old 01-28-2013, 03:25 PM   #2
2011 Kona Blue's Avatar
Prior to loading your new tunes from AM you need to return your car back to its stock mode. Once that's done, connect your performance tuner into the computer, check for updates and after load your tunes onto the tuner. Then upload your new desired tune back into your awesome pony
Old 01-28-2013, 03:30 PM   #3
rebeltx's Avatar
I know how to do it, just wondering if returning to stock is really necessary... I guess I'll just keep doing what Bama says and stay safe
"Turn the mic back on" -Winston Churchill
Old 01-28-2013, 03:35 PM   #4
emery2483's Avatar
I mean, I would keep returning it to stock because the tuner could crash and you could possibly loose your stock file somehow? I dunno, just my .02 lol
emery2483 is offline   Reply With Quote
Old 01-28-2013, 03:35 PM   #5
I would assume it is necessary being that AM says it needs to be done in order to make sure the transfer is completed properly.
Old 01-28-2013, 03:37 PM   #6
Sanguin's Avatar
Well, some tuners do partial writes and only modify things needed. If you don't return to stock and the tune you're overwriting modified something the new tune doesn't touch, it may combine them and create issues.
'13 'Stang V6 - MT82 - GHIG Ordered: 5/31 Pickup: 7/3
35% Tint, Homemade Intake (1, 2), GT500 Heat Extractor/Splash Guards, Custom Gas Cap
Barton Shifter Bracket, GHIG Shift Knob
'98 Grand Prix GTP - New Project for DD
Sanguin is offline   Reply With Quote
Old 01-28-2013, 03:44 PM   #7
redstang10's Avatar
I'm guessing you need to return the car to stock because before the tuner puts the new tune on the car it saves the current tune as the stock tune. Which means if you didn't return your car to the stock tune first you are going to lose it because the tuner saved whatever was on your car as the stock tune. Just my guess lol.
redstang10 is offline   Reply With Quote
Old 01-29-2013, 05:29 AM   #8
bucko's Avatar
It has happened in the past that a tune has caused problems, and flashing to another tune without going back to stock tune first caused the engine to not start; now you have a dead vehicle that either has to be towed to a dealership for a complete ECM load, or you call the tech support group of the tuner manufacturer you have to get them to help.
And if this is the case, make sure you plan ahead: are they open on the weekends for help with your dead car?
Follow the directions of the tuner manufacturers: go back to stock prior to installing a new tune.
Old 01-29-2013, 07:10 AM   #9
rebeltx's Avatar
yea. not worth turning my car into a pumpkin over..... I'll just do as suggested
Old 01-29-2013, 07:37 AM   #10
BlackedStang's Avatar
I have never returned my car to stock and have had zero problems.
2012 V6 Performance Package
BlackedStang is offline   Reply With Quote
Old 01-29-2013, 08:22 AM   #11
Aruiz42's Avatar
Maybe Dan from American muscle can chime in... I did it by accident before and haven't had a problem... But I don't want to have problems later...
Aruiz42 is offline   Reply With Quote
Old 01-29-2013, 10:18 AM   #12
bucko's Avatar
If the manufacturer recommends going back to stock prior to changing to another tune, I'd do it. Look at it this way, if you follow directions and something goes wrong, who's to blame? The manufacturer. If you don't follow directions and something goes wrong, who's to blame? You are, and you can only hope the manufacturer will continue to support your mistake, at a price you can live with.
Old 01-29-2013, 12:22 PM   #13
Aruiz42's Avatar
I said I did it by accident so that's why I'm asking.... The question remains what are the consequences if any? Can someone with some knowledge of the subject answer?
Old 01-29-2013, 12:26 PM   #14
For my 2003 I dont have to revert back to stock, I can just upload a new tune to the vehicle. The factory tune is backed up in the programmer
Old 02-08-2013, 05:47 AM   #15
GrabberBlue305's Avatar
Exactly
2011 Mustang 3.7 * Grabber Blue * 3.55 FRPP GEARS *20" Dyno in BF G-Force TA KDW * BBK CAI * Roush Axelbacks * BBR 93 Race Tune
GrabberBlue305 is offline   Reply With Quote
07:51 AM
