Airaid TB spacer diameter - Mustang Evolution
Old 02-01-2013, 02:41 AM   #1
Marc3.71994's Avatar
What is the diameter of the airaid throttle body spacer? Is it smaller than the bbk throttle body diameter?
Marc3.71994 is offline   Reply With Quote
Old 02-01-2013, 08:31 AM   #2
Charlie_santos's Avatar
It's meant to be used with the stock TB so I'm assuming it's gna be smaller than the larger BBK TB.
Old 02-01-2013, 04:26 PM   #3
That's True
Old 02-01-2013, 05:49 PM   #4
NicholasP's Avatar
Pics on AM show people using both together
NicholasP is offline   Reply With Quote
Old 02-01-2013, 06:40 PM   #5
The bbk 73mm throttle body is the same size as stock throttle body except for the diameter of the hole. The spacer hole which you can't see in the pics could be wider but its probably stock size.
Old 02-01-2013, 08:24 PM   #6
Ill check my tb spacer
Old 02-01-2013, 08:29 PM   #7
That would be great thanks man
10:48 AM
