Plasti dip - Mustang Evolution
Old 02-02-2013, 06:29 PM   #1
13stang901's Avatar
Plasti dip
Okay the spray can said 3 or 4 coats will cover it.
I'm on coat number 12 and still not done with my intake.
What am I doing wrong guys.
13stang901 is offline   Reply With Quote
Old 02-02-2013, 06:30 PM   #2
Loc: Austin,TX
Pics?
Old 02-02-2013, 06:35 PM   #3
13stang901's Avatar
Not till I'm done but this plasti dip is gonna be about an 8th of a inch thick.
Old 02-02-2013, 06:39 PM   #4
Loc: Austin,TX
Why are you dippin the intake. Isn't it already black?
Old 02-02-2013, 06:49 PM   #5
13stang901's Avatar
Doing the intake tube grabber blue and used plasti dip in case I don't like it
Old 02-02-2013, 06:54 PM   #6
Sanguin's Avatar
I'm confused. Check out dip your car on youtube and watch him. You do an initial light coat, the 2-3 heavy coats. If you don't do the last few heavy, peeling it off with be a pain.
'13 'Stang V6 - MT82 - GHIG Ordered: 5/31 Pickup: 7/3
35% Tint, Homemade Intake (1, 2), GT500 Heat Extractor/Splash Guards, Custom Gas Cap
Barton Shifter Bracket, GHIG Shift Knob
'98 Grand Prix GTP - New Project for DD
Sanguin is offline   Reply With Quote
Old 02-02-2013, 06:56 PM   #7
13stang901's Avatar
Thanks
Old 02-02-2013, 09:47 PM   #8
Gtzzoom's Avatar
obviously...you did wipe down the intake first with rubbing alcohol...?
you use traditional blue..or the new blaze blue.....
---------- Post added at 11:47 PM ---------- Previous post was at 11:46 PM ----------
is it bubbling like mad and running off? what is your area temperature...needs to be over 50 air temp to work cooperatively at least in my experience...tell me how it acted the first few coats...
"Slimer" 2013 V6 Premium 6MT
"What you have here sir, is a class 5 full roaming vapor, a real nasty fella!" Ray Stanz (Dan Akroyd) in Ghostbusters
Gtzzoom is offline   Reply With Quote
Old 02-02-2013, 10:38 PM   #9
Whitelightning's Avatar
I figured this out after spending 35 in dip thinkin it had gone bad. Put it in the fridge vent or floor vent and then spray a coat then come back in. That's how I did it last week lol but if not it just spits out in clumps.
Old 02-03-2013, 07:10 AM   #10
13stang901's Avatar
Used the blaze and it finally covered and looks good just gotta install and see how it looks.
Old 02-03-2013, 12:24 PM   #11
13stang901's Avatar
Well it turned nice and even now let's see what engine heat does to it
Old 02-03-2013, 02:55 PM   #12
Plasti tip melts at hot temp.. Good luck eith that.. I plastidiped the grills on my hood and it gets so hot that it melts and parts peel off
Andy714 is offline   Reply With Quote
Old 02-03-2013, 06:09 PM   #13
Gtzzoom's Avatar
Funny thing...what I have under the hood...is dupli color grabber green and rated to take the heat. Duplicolor old ford blue will match your grabber color...good luck and let's hope the dip like the 'kitchen'..but you did a great job...very nice!
Old 02-03-2013, 06:38 PM   #14
13stang901's Avatar
Thanks now that I know I like it I can paint it if it peels.
Old 02-03-2013, 07:12 PM   #15
Gtzzoom's Avatar
You may get lucky...but dipping exhaust tips (like mine) don't get the heat of the engine bay...
Have look at my pics and you'll see how the paint was used. Btw...same paint works great on the calipers
Old 02-04-2013, 05:31 AM   #16
bucko's Avatar
Whenever you are painting a black survace to another color, you should always use a primer first. With plastic, they sell a cleaner/prep spray, then primer, then your base coat color.
And all this is avalible for high temp parts. I think your blue intake tube is going to look poor in a few months.
Old 02-04-2013, 11:12 PM   #17
13stang901's Avatar
Guess ill go buy some paint then.
Old 02-10-2013, 07:52 PM   #18
Gtzzoom's Avatar
BTW....just tried the "Smoke" plasti dip on some items of my car. gives the appearance of tint on your 3rd brake light, side markers and such. the back end of Slimer looks a bit different now...LOL
Old 02-11-2013, 08:22 AM   #19
Gtzzoom's Avatar
pics in my album of the dipped lower rear bumper and trunk lip
Old 03-24-2015, 08:52 AM   #20
JRob27's Avatar
Region: Maine
I just ordered the painted one from JLT. Grabber blue.
All forged engine. Ford CNC Ported heads, Stage 2 Comp. Blower cams. 2.3 Whipple supercharger. Longtube Ceramic headers, Catted X pipe, Corsa Extreem Axelbacks.
JRob27 is offline   Reply With Quote
01:54 AM
