painting valve covers. - Mustang Evolution
Old 02-02-2013, 08:48 PM   #1
formulaDstang's Avatar
Ive seen a couple of people with theres painted. Has on one painted theres, And was it hard pulling the covers off?
formulaDstang is offline   Reply With Quote
Old 02-02-2013, 08:59 PM   #2
Sanguin's Avatar
The 5.0s have coil covers that can paint or get painted. I've yet to see a 3.7 with painted valve covers... sounds interesting.
'13 'Stang V6 - MT82 - GHIG Ordered: 5/31 Pickup: 7/3
35% Tint, Homemade Intake (1, 2), GT500 Heat Extractor/Splash Guards, Custom Gas Cap
Barton Shifter Bracket, GHIG Shift Knob
'98 Grand Prix GTP - New Project for DD
Sanguin is offline   Reply With Quote
Old 02-02-2013, 09:47 PM   #3
fordfan100's Avatar
Let us know if you do it
fordfan100 is offline   Reply With Quote
Old 02-02-2013, 10:35 PM   #4
Whitelightning's Avatar
I like how he says you (sanguin) do it lol that would be interesting. Too bad white is the napkin color :/
Old 02-03-2013, 07:48 AM   #5
fordfan100's Avatar
I meant if anyone reading this forum does it I would like to do it to mine but not sure how it would turn out
Old 02-03-2013, 09:32 AM   #6
Wouldn't it melt? I understand engine paint but geez that's alot of heat lol
Old 02-03-2013, 09:37 AM   #7
forceflow2's Avatar
You can buy high heat paint. Usually good for upwards of 1000 degrees or so.
2013 V6 Premium GHIG purchased 01/16/13
forceflow2 is offline   Reply With Quote
Old 02-03-2013, 10:15 AM   #8
Sanguin's Avatar
The paint I put on the valve covers of my Grand Prix has been fine for years. Typical hi-temp engine paint.
Old 02-03-2013, 10:26 AM   #9
Ubnbit's Avatar
I've seen engine paint rated for 500 degrees or hotter, run like water.
---------- Post added at 12:26 PM ---------- Previous post was at 12:24 PM ----------
Definitely go with 1000 or hotter
Old 02-03-2013, 05:11 PM   #10
I was wanting to paint mine like how this guy did his. Just not sure how hard it will be to pull them off to paint.
ID:	89025   Click image for larger version
Old 02-03-2013, 05:18 PM   #11
fordfan100's Avatar
I know you have to remove the manifold but that's about as much as I know
Old 02-03-2013, 09:05 PM   #12
That driver side scares me honestly. Idk what those round looking things are. These engines are foreign looking to me. I'm used to old school and new edge motors I guess. It looks tedious to get to them
Old 02-03-2013, 09:07 PM   #13
fordfan100's Avatar
Those round things are the coils they connect to the spark plug.
Old 02-03-2013, 09:24 PM   #14
Sanguin's Avatar
Round looking things? Wut? lol
Are you talking about the coil packs?
Old 02-04-2013, 05:28 AM   #15
bucko's Avatar
On our 3.7 V6's, painting the valve cover would make the engine look lopsidied, as the passenger side cover is hidden behind the air intake runners; you don't see the cover. The only side you can visually see is the drivers side.
Painting it would give the impression of a straight 3 cylinder.
Old 02-04-2013, 06:21 AM   #16
alrefire's Avatar
lol
maybe when they come with an aftermarket intake manifold it won't look so bad
Old 02-04-2013, 07:19 AM   #17
Gtzzoom's Avatar
someone had a post of a high performance V6 intake that resembled the 5.0s......if they make that later on, and when my warranty runs out...i'll upgrade and paint it to match or the valve covers..both would be too much im thinking...
"Slimer" 2013 V6 Premium 6MT
"What you have here sir, is a class 5 full roaming vapor, a real nasty fella!" Ray Stanz (Dan Akroyd) in Ghostbusters
Gtzzoom is offline   Reply With Quote
Old 02-04-2013, 10:37 AM   #18
Sanguin's Avatar
JimC dynod testes it. Utter failure. The runners weren't sized right or something and it made less hp than the stock mani. No idea if they're adjusting it or what.
Old 02-04-2013, 02:11 PM   #19
bucko's Avatar
Last time I checked that site, they were porting the holes to match the intake holes of the head. In his photos, they were way off from the head intake holes.
I too like the cosmetic look of that intake, but it's gotta at least match stock flow and HP/TQ readings. And be reasonable in price.
Gotta wonder if the Ford engineers got this one right too.
Old 02-04-2013, 02:12 PM   #20
Gtzzoom's Avatar
exactly! $ and performance..or no buy!
Old 02-04-2013, 06:43 PM   #21
alrefire's Avatar
^It better be $ performance and some looks
What's the website?
Old 02-04-2013, 10:21 PM   #22
Driver side, got three of them. Kinda glossy. Spark plugs are lower and always a pain. Idk what a cool pack is? That like a distributor or something?
---------- Post added at 11:21 PM ---------- Previous post was at 11:19 PM ----------
That's because of the type of engine. That's how the timing works. One is a few degrees lower so in theory they can be independent. I just read up on our type of motor. You probably already knew just thought I would share my joy of learning
Old 02-05-2013, 05:22 AM   #23
bucko's Avatar
Not sure what you meant by how the timing works, but maybe you are refering to the Ti-VCT (twin independent, variable cam timing)?
I was actually refering to painting the valve covers (or their close representation of one) would look goofy, because only one can be seen; the other (passenger) is covered by the long tubes of the air intake tubes. It will be interesting to see if anyone can make a center type air intake arrangement that can work as well as stock. Lots of V6 owners want an intake like the GT or better, the Boss. If ity could have been done, I'd think Ford or someone else would have had it by now.
But, there's always a better mouse trap to be made.
Old 02-05-2013, 06:17 AM   #24
Sanguin's Avatar
A distributor has a coil and coil wire running to the center right? Our motor has a coil for each individual spark plug. By design, they sit in the middle of the head (not the lower side near the exhaust) and the coils sit directly on top of them.
Old 02-05-2013, 06:43 AM   #25
Yes I am talking about the ti vct engine. One side sits lower a few degrees and the manifold is like it because of the type of engine.
---------- Post added at 07:43 AM ---------- Previous post was at 07:43 AM ----------
You learn something every day.
Old 02-05-2013, 06:55 AM   #26
Sanguin's Avatar
Btw, the timing works by small little actuators moving the cam shaft to alter their timing and durations with regard to valve control.
Old 02-05-2013, 08:45 AM   #27
So the guys at Motor trend are idiots in a way?
Old 02-05-2013, 08:31 PM   #28
alrefire's Avatar
So I'm looking at my engine
If he manifold didnt look so weird, it wouldn't look like a strait 3?
---------- Post added at 09:31 PM ---------- Previous post was at 09:30 PM ----------
Or would I have to remove the manifold to see what you're talking about?
Old 02-05-2013, 08:47 PM   #29
Sanguin's Avatar
More than one type of variable timing system. I'd have to see the one they're talking about.
Probably should clarify I meant the cam timing... ignition timing is all computer related. It knows where the crank is on its rotation and increases or delays the sparks timing depending on conditions.
Old 02-05-2013, 08:58 PM   #30
I just saw 2011 mustang first ride motor trend. I'd link but I do all my stuff on my iPhone. It's alot easier navigating on the app than the site
Old 02-06-2013, 05:18 AM   #31
bucko's Avatar
The valve timing (TiVCT) is how Ford designed the 3.7 to keep a smooth HP/TQ curve all the way up to it's max RPM. It uses several management inputs, along with oil pressure and oil temp. This way, they can adjust the intake and exhaust opening for a range of RPM's. This replaces the need for using cams that are usually designed to work within the 'sweet spot" of the engines RPM range that builds the max HP/Tq. With the Ti-VCT, you get this at all RPM ranges. Best of all worlds.
Old 02-06-2013, 09:53 AM   #32
JimC's Avatar
It is being re-worked and they said it will be sent back to me for more testing. I haven't heard any ETA on the new intake yet though.
JimC is offline   Reply With Quote
Old 02-06-2013, 01:01 PM   #33
bucko's Avatar
Subscribed. If this can get stock numbers (or better as a bonus), I'm on the list to buy!
Old 02-06-2013, 06:30 PM   #34
alrefire's Avatar
Is there a website or something we can look at?
Old 02-06-2013, 08:31 PM   #35
Sanguin's Avatar
Awesome. Keep us up to date. I'd love to buy something like that if it offered gains. Looks way nicer than what we have and would make plug changes easier too.
05:02 AM
