Muffler Allignment - Mustang Evolution
Old 02-06-2013, 05:15 PM   #1
Fax22's Avatar
Muffler Allignment
I just put on my mufflers again and my drivers side one keeps pulling over to the left when I drive. I can fix it when I stop but as soon as I drive on it again, it shakes back over. Any good way to keep it centered?
Fax22 is offline   Reply With Quote
Old 02-06-2013, 06:02 PM   #2
pwrby4d's Avatar
might have to tweak the mounts a little. what brand? pypes are known for having to have some fitment issues. ive had a set of m80's that the tips were like that and also a set of pype bombs that were also always moving around and never really got the drivers side right.
pwrby4d is offline   Reply With Quote
Old 02-06-2013, 06:04 PM   #3
Fax22's Avatar
Mac axel backs
Old 02-06-2013, 06:26 PM   #4
Charlie_santos's Avatar
Originally Posted by Fax22 View Post
Mac axel backs
Go to a muffler shop and have them add a extra hanger right behind the tip to the frame of the car and its fixed. I did it and i can kick and push my tips and they stay centered!!
Old 02-06-2013, 08:22 PM   #5
MrMike's Avatar
When I installed my roush the driver side was way off centered, I just loosened the clap just enough to be able to move and center the muffler, held it there and tightened the clamp back and perfect! It's been a week a still perfect!
MrMike is offline   Reply With Quote
Old 02-07-2013, 05:29 AM   #6
bucko's Avatar
If you (or road vibration) are able to have the axle back muffler move, then it's not tightened down enough at its flange connection.
Old 02-07-2013, 01:44 PM   #7
MrMike's Avatar
Just loosen the flange connection, center your muffler and hold it or have a friend hold it centered while you re-tighten. Work perfectly!
Old 02-07-2013, 03:17 PM   #8
Black on Boss's Avatar
Adjust your cat-back pipe and it will center. I had to do it on mine
Old 02-07-2013, 03:40 PM   #9
Fax22's Avatar
The problem seems to be when I drive, it vibrates out of the hanger closest to the back of the car, causing it to move to the left.
Old 02-07-2013, 04:07 PM   #10
Trust me mine did the same thing. Loosen everything including the cat back pipe then tighten them from the front to back.
Old 02-07-2013, 04:11 PM   #11
Listen to that guy ^^^
Old 02-07-2013, 04:14 PM   #12
MrMike's Avatar
Does that hanger have a stopper welded on the end of it? It really shouldn't vibrate out of the holder, but if it doesn't have the stopper on the end I can see it being a problem! Is it your stock mufflers or aftermarket?
---------- Post added at 07:14 PM ---------- Previous post was at 07:12 PM ----------
I just had to loosen the axel back to straighten it. But if it doesn't work for you do what black on black says.
Old 02-08-2013, 05:27 AM   #13
Fax22's Avatar
They are after market I've never had this proven before even without the stopper. I might need to take it off and just put it back on.
Old 02-08-2013, 10:30 AM   #14
+1000000,
06:19 AM
