Automatic 3.7 guys who have Dyno'd....come in - Mustang Evolution
Old 02-07-2013, 03:16 PM   #1
alludc's Avatar
so, im not so impressed with the dip in the dyno graph from 2900-3500rpm. Ive heard others talk about it and I can definitely notice it while driving (its a 7-10tq loss). Any discussion on what this is (other than a weird factory tune)? I cant see what it could possibly be purposely put in for other than annoyance.
2013 PP/MCA MY MPG SUCKS!!!HD Vid of Roush Axleback
http://youtu.be/kW-cuiZjAYE?hd=1
HD Vid of Roush Axleback + Glasspacks
http://youtu.be/FnXY-8iSujY?hd=1
alludc is offline   Reply With Quote
Old 02-07-2013, 03:47 PM   #2
jomcgui's Avatar
I imagine it has something to do with emissions and noise control. I think engines are tested at a certain rpm for this stuff and manufacturers put in a power dip right there. My last two motor cycles both had power dips that required after market tinkering. I plan on getting some tune soon to maximize low rpm power.
Manufacturers should just put in a fuse that activates this emissions map than leak out that if pulled the engine reverts to an "off road" only fuel map.
jomcgui is offline   Reply With Quote
Old 02-07-2013, 04:47 PM   #3
fordfan100's Avatar
This is my dyno graph from today
fordfan100 is offline   Reply With Quote
Old 02-07-2013, 04:56 PM   #4
alludc's Avatar
yours started later than mine. mine starts at 2400 and climbs for a sec then goes into a valleyfrom 2900-3500 and then climbs. if I started mine at 3100 like yours id have a straight line as well. mines also TQ that drops, not HP although you can see a small dip in the hp line in the same spot.
Old 02-07-2013, 05:02 PM   #5
alludc's Avatar
Old 02-07-2013, 07:49 PM   #6
JimC's Avatar
I hadn't noticed it but just checked the dyno sheets from when we did the intake manifold testing and you're right, there is a torque dip in that 3,000 - 3,500 range.
It is even there on the stock tune and stock intake (I was running 93 octane because we were testing out several different configurations and tunes - and it appears that the 3.7 will adjust for octane just like the 5.0 when we compared the dyno sheets that day).
Name:	Stock intake and tune0001.jpg
JimC is offline   Reply With Quote
Old 02-07-2013, 07:53 PM   #7
alludc's Avatar
surprised its there with the tune, guess if its a canned tune yea...but if custom should be able to get rid of that. I can easily feel it at WOT 0-60s and it def effects performance.
08:23 PM
