Window gremlin - Mustang Evolution
Old 02-08-2013, 09:04 AM   #1
Pony_Boy's Avatar
Window gremlin
Driving into work today the passenger window decided to how down completely and stay there. The switch had no response until I turned the ignition off. Restarting the car caused the same problem. Pulled over turned off and locked the car after getting out. No problem since. Anyone else experience this? Worth a warranty appointment?
Pony_Boy is offline   Reply With Quote
Old 02-08-2013, 12:17 PM   #2
pamson's Avatar
sounds like it may be a switch actuator call your dealer and see if they want you to bring it in if still under warranty definatly have it checked out with electronics a problem comes and goes never know when it will happen again, but it will continue untill fixed
pamson is offline   Reply With Quote
Old 02-09-2013, 04:47 PM   #3
pwrby4d's Avatar
try this.
window reset procedure. should be in the manual under power windows.
Turn your key to the on position but dont start the car, roll your window down and when it hits the bottom continue to hold the button down for about 2 seconds. Now roll the window up and when fully up continue to hold the button for about 2 seconds. Do this with the door closed. That should fix it.
pwrby4d is offline   Reply With Quote
Old 02-09-2013, 05:20 PM   #4
curtin1991's Avatar
Send a message via ICQ to curtin1991
Originally Posted by pwrby4d View Post
try this.
Corey
curtin1991 is offline   Reply With Quote
Old 02-10-2013, 09:04 AM   #5
Pony_Boy's Avatar
Thanks! I saw that in the manual and on another thread. Tried it and nothing has happened yet, fingers crossed. It's still under warranty, so I'll take it in if it happens again.
04:39 AM
