Idling issue - Mustang Evolution
Old 02-11-2013, 05:38 PM   #1
Smokeyjoe's Avatar
Idling issue
About 2 weeks ago I put a 93 octane bama race tune on my 2010 v6 and whenever I stop driving and put my car into park theirs a small shudder that comes from my engine for about 2 or 3 seconds then it goes back to normal. Any ideas on whats causing it?
Smokeyjoe is offline   Reply With Quote
Old 02-11-2013, 05:56 PM   #2
It's not me, it's you.
primer2tone's Avatar
Is it idling higher then usual?
Maybe you should Data log and send your results to Bama so they can fine tune your tune.
Old 02-11-2013, 07:07 PM   #3
Smokeyjoe's Avatar
It seems fine until those 2 or 3 seconds come and then it makes this shudder noise and the car kinda shakes and the rpms slightly rise. I think ill try the data log since this wasnt happening when I didn't have the tune. Sorry I'm new to tuners but how do I do the data logging on the tuner?
Old 02-11-2013, 09:22 PM   #4
Whitelightning's Avatar
Mine does this and its stock. Weird
Old 02-12-2013, 07:54 AM   #5
AmericanMuscle.com
Sponsor
AMDanBailer's Avatar
Hmm, I have seen some Automatics do some odd things when throwing them in the park, stock or tuned! We can definitely look into this for you and make sure it's not within the tune and if it its, fix it quickly. We send out thousands of tunes and build them all from the ground up for your PCM code and your mods. They're not just "canned" tunes, they're built custom by our team, so every once in a while it's possible we mess one up! We'll definitely get it straightened out for you, though! Give one of our Bama Tuning Specialists a call and they'll work with you to figure out exactly what's going on.
Our Bama Performance tuning specialists are here in the building Monday-Friday from 9AM-5:30PM EST and Saturday 9AM-5:30PM EST
-Dan
Old 02-12-2013, 07:55 AM   #6
Bballing0416's Avatar
Check your TPS (throttle position sensor)
Bballing0416 is offline   Reply With Quote
Old 02-12-2013, 10:47 AM   #7
SaintSancho's Avatar
did you recently install an intake by any chance? my friend was having this problem threw back on the stock intake and it went away
|Short Throw Shifter| RtR Splitter| SR Lowering Springs| Roush Exhaust| Ford Racing Midpipe| Raxiom Headlights| 2013 V6
SaintSancho is offline   Reply With Quote
Old 02-12-2013, 10:56 AM   #8
Old 02-12-2013, 11:56 AM   #9
Smokeyjoe's Avatar
I did install a bbk cai the same time I put on the tune
Old 02-12-2013, 12:12 PM   #10
bucko's Avatar
Check the CAI install for any unmetered air leaks, such as around the throttle body connection, the cone filter connection, and the mass air flow sensor. That should only screw in one way on the tube, but remove it and check for damage anyway.
Old 02-12-2013, 01:07 PM   #11
this is what was going on with his. leaking air led to unmetered air going passed the censor which was most noticeable when he was idling but sometimes he would also feel bogging while driving I believe. can't hurt to check
Old 02-27-2013, 05:25 AM   #12
willb2305's Avatar
how do you check for mass air sensor damage?
2012 V6
AirRaid CAI, BBK Ceramic LT Headers, BBK Catted X Pipe, Borla ATAK, MPT 93/97 Tune, Steeda LCA's and UCA, Steeda Relocation Brackets, 373 gears, WaveTrac LSD, Dynotech Driveshaft. Prothane Motor Mounts, Whiteline adjustable panhard bar & brace.Ground Control Coilovers with Koni's custom valved. Coming soon Circle D 3800 Stall and Lone Wolf Intake Manifold.
willb2305 is offline   Reply With Quote
04:26 AM
