Originally Posted by FastV6 ---------- Post added at 02:46 PM ---------- Previous post was at 02:45 PM ----------
what else can I do without FI to beat a 5.0 |
Complete bolt on of every mod less force induction... Here's the list to give you around 400 horse power and the way to put the power down this will give you a better pound per horse power than the 5.0. The V8's torque will probably keep it even with you. It will come down to a drivers race.
CAI, tune, throttle body & spacer, set of eccel coils, bigger feul injectors, long tube headers, x pipe, catback, 3.73 or 4.10 gears, aluminum or carbon fiber drive shaft, lowering springs, lower and upper control arms. Larger rear tires 275mm minimum. That should rocket you to under 13 seconds in the 1/4 there is a car on drag radials with half these mods and a stock suspension on youtube that runs 12.9.[/QUOTE]
where can I get the fuel Injectors? and how much are they?
