Aluminum DS on lowered car - Mustang Evolution
Old 02-23-2013, 09:42 PM   #1
rebeltx's Avatar
Can someone tell me what I need to be aware of when installing a DS on my lowered car? I thought someone had mentioned that you need a certain kind of DS... Would that one that Bama sells work?
"Turn the mic back on" -Winston Churchill
rebeltx is offline   Reply With Quote
Old 02-24-2013, 04:25 AM   #2
fordfan100's Avatar
It should fit just fine. It sits just like your stock one.
fordfan100 is offline   Reply With Quote
Old 02-24-2013, 04:37 AM   #3
The Blue Dragon
GrabberBlue5.0's Avatar
No, nothing special is needed as far as the DS is concerned. It is recommended that you change uca to correct pinion angle however
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 02-24-2013, 05:42 AM   #4
rebeltx's Avatar
Do I just need a new UCA mount for that? I'm doing lower control arms next month with the DS so I will do it then.
Old 02-24-2013, 06:00 AM   #5
The Blue Dragon
I would get a new mount with uca. I got the UPR uca with tq mount and it took a lot of slop out of the drivetrain. Get an adjustable uca or a non adjustable made for a lowered car.
Old 02-26-2013, 08:38 AM   #6
AmericanMuscle.com
Sponsor
AMDanBailer's Avatar
I see GrabberBlue has already pointed you in the right direction. The Driveshaft it self is fine, lowered or not. But it is recommended to change the UCAs to adjust for the pinion angle! Going with the UCA and Mount's is always a good option, that will get rid of majority of the slop in your drivetrain, as well as fix the pinion angle.
I hope this helps! Let me know if you have any questions or need some assistance.
-Dan
Old 02-27-2013, 02:54 AM   #7
willb2305's Avatar
Like everyone else has said you could get the adjustable upper control arm to fix your pinion angle since your car is lowered. CV joint on driveshafts help with lowered cars I think thats what you were trying to get at. Dynotech and Driveshaftshop have cv joints on their driveshafts.
2012 V6
AirRaid CAI, BBK Ceramic LT Headers, BBK Catted X Pipe, Borla ATAK, MPT 93/97 Tune, Steeda LCA's and UCA, Steeda Relocation Brackets, 373 gears, WaveTrac LSD, Dynotech Driveshaft. Prothane Motor Mounts, Whiteline adjustable panhard bar & brace.Ground Control Coilovers with Koni's custom valved. Coming soon Circle D 3800 Stall and Lone Wolf Intake Manifold.
willb2305 is offline   Reply With Quote
Old 02-27-2013, 03:59 PM   #8
rebeltx's Avatar
I just snagged the last aluminum DS from CFM. There local and gave me a bit of a deal since I paid cash and picked it up. I wish AM had rear safety loops in stock. Now I have to decide if I want long tubes or just deletes and a new x pipe from BBK. I have not herd much about the new BBK x with cat delete so I'm very curious.
Old 02-27-2013, 05:32 PM   #9
rebeltx's Avatar
I need adjustable UCA's though to get the pinion angle correct rite? just swaping out the uca and mound wont do me any good because it is the same as stock?
03:55 AM
