SR lowering spring poping sound - Mustang Evolution
Old 02-24-2013, 09:28 AM   #1
rebeltx's Avatar
I installed these SE springs yesterday and just went on a short ride and i could hear what sounded like metal on metal popping noises. I'm thinking I need to tighten down the 21mm bolt on the strut to put more pressure on the spring but I'm really not sure.
"Turn the mic back on" -Winston Churchill
rebeltx is offline   Reply With Quote
Old 02-24-2013, 09:58 AM   #2
1slosix's Avatar
with or without iso's?
carving corners like a boss
Old 02-24-2013, 04:52 PM   #3
rebeltx's Avatar
Without
Old 02-24-2013, 05:01 PM   #4
rebeltx's Avatar
And for those thinking that I need the gt500 upper strut mount. I did some digging and found that they won't fit the factory strut... So that idea is out the window.
Old 02-24-2013, 05:10 PM   #5
1slosix's Avatar
popping can happen when you don't run iso's...i don't so i get the occasional pop when going on a bump
Old 02-24-2013, 08:29 PM   #6
rebeltx's Avatar
I put it up on stands and adjusted the rubber boot and tried to tighten the 21mm bolt a little. put her down and went out to eat.... the pop has stopped in the drivers side and happens allot less on the passenger side...... im not sure what gives
Old 02-24-2013, 11:51 PM   #7
rebeltx's Avatar
04:48 AM
